factory motor oil
Old Sep 24, 2003 | 05:28 AM
lobewiper's Avatar
factory motor oil
What kind of motor oil is the 04 delivered with? I'm down half a quart at 1100 miles and don't want to switch brands until the first recommended change at about 3500.
Old Sep 24, 2003 | 05:39 AM
VQ35DE's Avatar
I change at 500,1500 and 3000 mi on ALL new engines, and for sure in my VQ35DE!!!! You better get that drain plug OUT now.
Old Sep 24, 2003 | 05:49 AM
lobewiper's Avatar
People I respect say that frequent oil changes in a new car will delay break-in. Any thoughts?
Old Sep 24, 2003 | 06:02 AM
VQ35DE's Avatar
Let me add that my 500 and 1500mi change is with dino oil, then I change over to MOBIL-1 at the 3000 change. I have used this method for many NEW ENGINES over the years and I am very pleased with the results.
Old Sep 24, 2003 | 08:42 AM
MaxPilot's Avatar
I switch to Mobil 1 at around 1000 on all my cars. Modern engines don't need much of a break-in. If you are not using oil, then the rings have seated. Mobil says you can use Mobil 1 right from the get go. I believe it. None of my cars have ever used much if any oil between changes.
I think the reason Nissan says to run your car easy for 1200 miles or so it to break-in not only the engine (which like I said, is most likely broken in at the factory) but the transmission, drive-train, tires, brakes, shocks, springs, etc.
Old Sep 25, 2003 | 11:25 PM
SSurfer's Avatar
Theres nothing better for an engine(any engine) than clean oil!
MaxLife17
Jun 27, 2019 01:37 PM
RWCreative
Sep 21, 2015 11:01 AM
Vistance
Sep 17, 2015 05:17 AM
ag90fox
Sep 9, 2015 12:22 PM
