TSB Available - 2004 Maxima - Dust In Cluster (Not Radio)
Old Sep 24, 2003 | 02:07 PM
studman's Avatar
For documentation and search purposes:
New TSB Available:
TSB: NTB03-053a
Year(s): 2004
Transmission(s): All
Problem: Dust In Cluster (Not Radio)
Old Sep 24, 2003 | 02:19 PM
BRB's Avatar
BRB
New TSB Available:
TSB: NTB03-053a
Year(s): 2004
Problem: Dust In Cluster (Not Radio)Location: http://maxima.theowensfamily.com/tsb/
That's interesting. So you can now remove just the LCD cover for cleaning. The way it's worded suggests that earlier versions were not built so that just the cover can be removed.
Old Sep 24, 2003 | 06:00 PM
XMan's Avatar
New TSB Available:
TSB: NTB03-053a
Year(s): 2004
Do you have the service manual.....can someone post how to remove the cluster D....
X
Old Sep 24, 2003 | 06:09 PM
CanadianMoFo's Avatar
X
I saw a service manual CD on Ebay today starting at $9.99. If I knew it would work as a stand-alone product I'd buy it.
CM.
Old Sep 24, 2003 | 08:10 PM
studman's Avatar
Removal Instructions:
1) Remove shift ****
2) Remove transmission boot/plate
3) Remove 2 screws from bottom of radio trim plate
4) Pull trim towards rear of car to release clips
5) Disconnect electrical connectors
6) Remove 2 screws from bottom of Nav/AC trim
7) Remove Nav/AC trim
Reassemble in the reverse order.
Old Sep 25, 2003 | 07:55 PM
XMan's Avatar
How do you remove the transmission boot plate????
X
Old Sep 25, 2003 | 08:33 PM
KJSmitty's Avatar
X
Also,
I read that the shifter **** comes off a little different, not just unscrewing etc. Any descriptions of the shifter plat removal and or **** would be great... I'd rather do this than the dealer clowns
Old Oct 4, 2003 | 02:25 PM
XMan's Avatar
Originally Posted by KJSmitty
Also,
Ok...I did it...I cleaned up the LCD Screen myself. Here are the instructions:
1. Open the cup holder compartmenr by the parking brakes...and remove the actual cup holders.
2. Put up the parking brakes.
3. Pull up the edge of the pewter plastic boot...this is the edge you see from the cupholder compartment.
4. you will have to play with the stick and change gears (turning the car on) in order to remove the base pewter plate mentioned in 3 (the one that has the hazard blinking ligths).
5. Disconnect the cables and completelly remove the base plate.
6. Right now the next plate to remove is the pewter one that has the opening for the CD changer, casette player and AC. To do this, remove the 2 screws onthe base.....andpull it out.....you will need to disconnect the cable the powers/controls the A/C to completelly remove this plate.
7.Remove the screws that hold in place the dashcluster....and pull the plastic casign out....and boila!!!....you can now clean the screen.....
Old Oct 4, 2003 | 09:10 PM
KJSmitty's Avatar
Did you have to remove the shifter ****? If so how??
Thanks for the narrative.. :-)
Smitty
Old Oct 5, 2003 | 12:11 PM
XMan's Avatar
Smitty
Yes I had.....note that the NSA (Nissan Service A$$holes) already changed my Nav System Screen twice. So when I wanted to remove the shift ****, I found really easy to do it just because they broke the locks that hold that plastic part of the ****.
In any case, this is how is supposed to be removed.
1. Turn the plastic piece of the **** clockwise (looking atthe shift **** from the rear view mirror). Once it unlocks, push it down.
2. Now look under the leather part of the ****, you will find another lock....pull it out.....and boila.....remove the leather and plastic parts of the shift ****.
Slamrod
Apr 10, 2016 05:24 PM
Maxilano
Aug 31, 2015 07:33 PM
soon2ownmax
Aug 13, 2015 02:19 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
MikesChevelle
Aug 9, 2015 11:50 AM
