Going from 17 inch to 18 Inch
Old Oct 2, 2003 | 09:10 AM
I Hack 4 U's Avatar
I have a question. Can you go from the stock 17 inch rims on a 2004 nissan maxima to a low profile 18 inch rims without recalibrating the speedometer? Anyone have good places to go for rims and tires in the central florida area? Thanks so much. I have a 2004 Maxima SL.
Old Oct 2, 2003 | 09:21 AM
heems27's Avatar
You shouldn't have a problem because the 04 SE Maxima comes standard with 18 inch rims.
Old Oct 2, 2003 | 10:03 AM
Sprint's Avatar
just make sure you get the right tire size
go here http://www.miata.net/garage/tirecalc.html
put in your stock tire size and it will tell you what size 18's will make your speed accurate or off
Old Oct 2, 2003 | 11:08 AM
CanadianMoFo's Avatar
The stock 18" size is 245/45/18 and I believe the stock 17" size is 225/55/17. The calculator shows the speed is reading 0.2% higher with the 18's compared to the 17's.
CM.
Old Oct 2, 2003 | 10:34 PM
Driver72's Avatar
CM.
I'd just get a nice set of lightweight 17" rims instead.
The 04 Max SL doesn't get the 5 speed auto so it's a bit off the pace because of that already.
Adding heavier 18 inch wheels will just give you a rougher ride with slower acceleration.
A nice set of 17" would make the car look nice, increase it's performance, keep the ride softer (the reason you probably got the SL) and wouldn't hurt your mpg either.
Just my duce!
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Garrettz459
Sep 28, 2015 02:50 PM
Luigi623
Sep 21, 2015 01:42 PM
Maxboy23
Sep 4, 2015 06:04 PM
