Rattle in arm rest
Old Oct 28, 2003 | 10:38 PM
nukecat's Avatar
Rattle in arm rest
Has anyone noticed a rattle coming from the arm rest that sits between the driver and front passenger? It only rattles when the arm rest is extended or in the raised position. I've also noticed that the arm support , when raised, seems very flimsy...it shifts back and forth very easily. Think that it may need to be tightened down??
Thanks for the help.
Old Oct 29, 2003 | 03:06 AM
CanadianMoFo's Avatar
Yeah. Mines pretty solid. No shifting in it. Take it in for service.
CM
Old Oct 29, 2003 | 09:18 AM
MaxPilot's Avatar
It's the armrest button vibrating up and down. I had my armrest replaced because it would not latch properly, and on the new one, the button has much tighter tolerances.
Old Oct 29, 2003 | 12:38 PM
nukecat's Avatar
Rattle in armrest
It isn't the button but the whole arm rest. When it is raised the arm rest can be freely moved back and forth (jiggled). So, if your arm is not resting on it, it will rattle. The problem with the button is that it takes several attempts to close as if the button is not catching
Old Oct 29, 2003 | 02:37 PM
MaxPilot's Avatar
That was exactly my problem, and I had the whole thing replaced under warranty. My center console is good now.
Old Oct 29, 2003 | 03:14 PM
MaxMaybe's Avatar
Mine only closes easily if you press on the REAR section. Put pressure anywhere else and you really have to hammer it.
Old Oct 29, 2003 | 07:54 PM
m00se's Avatar
Are you talking about the '03 or '04 Max? I am not aware the armrest extends in my '04 though it did in my '00. I did have to slam the lid a couple times to engage the catch in the lowered position on the '00.
Old Oct 30, 2003 | 05:58 AM
MaxPilot's Avatar
There is a wide button on the front of the armrest. Press this and the armrest will extend up.
gigabyte
Jan 6, 2017 06:05 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
