Can Satellite Radio be Added to Original ?
Good evening all...
Does anybody know if satellite radio (XM?) can be retrofitted to the original factory radio set up? I'm talking about "factory" stuff, not the Circuit City "add on" gear.
If so, what's the approximate cost?
Thanks,
Thanks,
Good question!
Originally Posted by Rob
...Does anybody know if satellite radio (XM?) can be retrofitted to the original factory radio set up? I'm talking about "factory" stuff, not the Circuit City "add on" gear....
Any info would be much appreciated.
Good evening all...
Thanks,
Thanks,
Quoting from the 04 Max brochure "late availability/retrofit unavailable".
I have a sneaky suspicion that the XM is built into the "head unit" since we have such a spread out setup. The "radio" is probably a box somewhere that contains all the audio electronics(as well as the nav electronics probably), with just the changer, tape deck, and controls on the console. That box most likely also houses the XM/Sirius tuner since all of it uses the nav screen, so you'd essentially have to replace the entire electronics for the audio/nav to retro the sat radio in.
I'll know more next month when mine arrives and I disect it to do a few mods. I did order XM , so I'll know for sure whether it's a seperate "module" or a complete replace job.
Originally Posted by Glude
I also would like to know the answer to this, I have the lil satelite button so does that mean I have to just get it activated or what?
I was curious about his myself and called my local dealership and spoke to the parts department manager, he had me read him off my vin number and said that he would call me back. After a while he gave me a call and said that unfortunately I did not have the proper harness in my vehicle to install XM, he said that it wasn't until after a particle manufacturers date that nissan started installing these harnesses into all factory systems and that all that is required is the actual xm tuner unit and antenna. I belive that he told me the manufacturers date had to be 07/04 and later. He told me that nissan would be releasing a harness to upgrade cars that didn't come with it and that the harness would cost around $200 and that for cars that already have the harness and wanted to upgrade to XM the tuner module would run for about $400 not including labor.
I recall this being discussed previously. There should be an Infinity kit that will work. I seem to think it was in the $200-$300 range. There was an Infinity parts site that was advertising them a while back. Do a search in this forum and see what turns up.
CM.
CM.
CM.
CM.
http://www.infinitiwholesaleparts.com/en_US/
The install only takes a few hours. Works great.
Originally Posted by bradshaw46
Yes, it's very possible and very doable. Several of us here (myself included) have done it. You can buy the parts from Grubbs Infiniti here:
Quick question.... Using the kit from Grubbs, does the XM info display on our current screen. I don't have nav.
Thanks again for the info.
![ThumbsUp](https://maxima.org/forums/images/smilies/thumbsup.gif)
Originally Posted by MAXSE-RIOUS
Wow! This is excellent news! Thanks so much for the info, I'll be contacting Grubbs Infiniti today.
Thanks again for the info.![ThumbsUp](https://maxima.org/forums/images/smilies/thumbsup.gif)
From one of the discussions.....
Picture of pre-wired satellite harness
http://www.nationhost.com/maxima/sat...s_location.jpg
Picture of mounted xm receiver
http://www.nationhost.com/maxima/mounted_xm_rec.jpg
Picture of xm antenna placement
http://www.nationhost.com/maxima/xm_..._placement.jpg
Originally Posted by pocketrocket
I can confirm it next week for you. I believe that all 6th gen with "SAT" button on their headunit may come prewired.
Thanks!
Originally Posted by peetah
BTW, I wanted to thank you for the info last time. I got the kit, installed everything. Took several hours to do it.
Thanks!
Thanks!
Now if I could only find a source for those blackout taillamps....
![GrinNo](https://maxima.org/forums/images/smilies/grin_no.gif)
Does mounting the kit in th back window like that affect the reception. Also do wire have to be run all the way to the front or do they hook in the back. You can easily find if you car is prewired by calling up nissan and giving them your vin number. Mine was made in september and came prewired. I am thinking of getting the kit.
![slant](https://maxima.org/forums/images/smilies/slant.gif)
I'd also be curious about the possible adverse affect on reception if the antenna is put on interior rear deck, vs exterior roof. I don't want to put the antenna on roof.
Most, if not all Maximas are already pre-wired for Satellite Radio. You can order a kit from Nissan to add to the vehicle. The install should take less than a half an hour. I installed a Sirius tuner in my 04.
Antenna should go on the roof. If it is anywhere else, you have a higher probablility of losing signal and having "mutes" which could be annoying.
[QUOTE=mikey0120]Most, if not all Maximas are already pre-wired for Satellite Radio. You can order a kit from Nissan to add to the vehicle. The install should take less than a half an hour. I installed a Sirius tuner in my 04.
What do I need to look at to find out if mine is pre-wired. I bought it in July and have the GPS. If it is not pre-wired what is it going to take to wire it up using the existing controls on the audio system. I have the SAT button.
Also if it is pre-wired does it matter if I choose XM or Sirrus, or will the plug accept both.
Originally Posted by mikey0120
Most, if not all Maximas are already pre-wired for Satellite Radio....
'04 Max's with build dates prior to approx June -July '03 are most likely not pre-wired. Many cars were built prior to June. If your car is pre-wired, you will have a sticker inside your driver door stating so. Or, you can call Nissan with your VIN, they will tell you if you are pre-wired.
Not true...
You can get either the Sirius or XM tuner. The plug will accept either system.
You are probably better off calling to see if you are Pre-wired for satellite. I bought my car on March 27th and it was already pre-wired.
From the info I've gotten so far, if your car is pre-wired, you will not have to run anything to the radio itself, just mount the receiver in trunk, plug in the wiring harness which will already be there, and run antenna lead to receiver. I'm sure bradshaw46 can verify this. A much easier job that running the wiring harness in early cars without pre-wiring. Unfortunately I'm not pre-wired! ![slant](https://maxima.org/forums/images/smilies/slant.gif)
Reception has been ok, but the standard XM antenna leaves alot to be desired in my opinion. I plan on upgrading my antenna soon - mine is mounted on the rear deck by the high stoplight. I do get dropouts and mutes on occasion, but not much more than my brother gets on his Delphi unit with his antenna mounted on the roof of his pickup. Some areas simply have more interference with the XM signal than others. The technology is by no means perfect yet.
Antenna?
I too would rather NOT use the huge ugly standard antenna that comes with the OEM XM kit. I'd much rather use the much smaller Terk XM3 low profile antenna or the Delphi micro antenna, however, they both have single input lead. I believe (but not sure) the standard kit antenna is double input. Does the OEM receiver accept only double input antenna, or can single input be used?
Thanks for your help.
Reception has been ok, but the standard XM antenna leaves alot to be desired in my opinion. I plan on upgrading my antenna soon...
I'd like to get the Terk XM3 low profile antenna or Delphi Micro antenna, but need to know if OEM XM kit receiver will accept single input antenna?
Hello bradshaw46
My car is not pre-wired.....it is EZ Installation pre-wired...and you're have the pic help how to pre-wired kit...and factory receiver how much is cost.....some dealer is cost $315
Thank for your help
Thank for your help
From what I have gathered, there are a few ways to find if your car has been prewired:
1. Call Nissan corp, or talk to your service department to see if your VIN is among those built after the prewire start date.
2. Look for a sticker that says your car has been prewired for satellite. It is located in one of two places: Inside the center console with other car information or inside the drivers door.
I chose option 1, and was told that I was not prewired based on my VIN. Since I work out of town, and did not have access to my vehicle to check, i took them at their word, and ordered the prewire and xm kit from Grubbs Infiniti. When i got home, i did double check the inside of my center console, but did not see anything mentioning prewire, so I waited for my kit to arrive.
Once I received everything, i dropped my glove box, pulled away the panels, and lo-and-behold: The satellite was already plugged in. Turns out i was already prewired (Sticker was in the door, which i found out about after I looked some more on more forums). From what I understand, if your vehicle was made before the date they started prewiring all Maxima's, the dealer could request that it be prewired. If that was the case, they put the sticker in the door (at least that is my assumption).
Needless to say, I've got the extra prewire harness with no use for it now, so if anyone is interested in buying it, just let me know.
Other than that, I have installed the XM receiver, Went through the headache of trying to get the Nissan Promotion code that gives 2 free months of XM (had to call Nissan corp), but now it works wonderfully. I've had a couple of times with dropped signals that didn't return until I restarted my car, but i figure that may be more because the antenna is in the back panel instead of on the roof.
