Remote Starter
Old Dec 15, 2003 | 03:50 PM
TailgateJeff's Avatar
Remote Starter
Has anyone had a remote starter installed on their new Maxmia? I was thinking of buying one as a Christmas gift for my wife. Any suggestions for brand and model?
Old Dec 15, 2003 | 06:57 PM
cannonscreation's Avatar
I would suggest on useing the Valet 561T it works right off of your factory keyless entry. This is the brand I use at work and haven't had any problems with it. It's the same company that makes Viper(DEI) so it's a brand u can trust
Old Dec 15, 2003 | 10:36 PM
limsandy's Avatar
I agree with cannon. The Valet 561T is a nice addition of remote starter to existing keyless entry. But if you consider getting alarm system for your car also, then I'd recommend Viper 791XV. It costs more but does everything. It also comes with LCD remote control. Good luck. Ask Don aka Pearl96Max for more information, he is a professional and certified DEI installer.
~limsandy
Old Dec 15, 2003 | 11:10 PM
Ammi's Avatar
350 Detroit Muscle
if you are just looking for remote door lock/open and remote starter, Valet 561T is the way to go. If you want a toy to play with, Viper 791XV
Old Dec 16, 2003 | 03:26 PM
Thanks everyone for your help. I have a Viper alarm/remote starter on my truck and I have been very happy with it. I'm leaning towards the Valet 561T. I'll check out both models at my local DEI dealer.
Old Dec 16, 2003 | 05:34 PM
OpTi's Avatar
So the Valet 561T uses the stock keyfob? On the site it doesn't say anything about using the stock keyfob.
Old Dec 17, 2003 | 12:17 PM
98MAXNY's Avatar
How much did you get it for? I found 1 place that sells it for 69.98
Old Dec 19, 2003 | 03:42 PM
OpTi's Avatar
If you remote start the car then the stock keyfob won't work. How can we get around it?
Old Dec 19, 2003 | 06:32 PM
HEMP177's Avatar
Remote Start
I had a remote starter put in my car a few weeks ago. For some strange reason the heater will work unless the key is in the ignition. so for now i can warm my engine up, but it still takes a few minutes for the car interior to get warm.
Old Dec 19, 2003 | 06:34 PM
HEMP177's Avatar
remote start
correction on my last reply. The heater will "not" work unless the key is in the ignition.
Old Dec 19, 2003 | 06:41 PM
OpTi's Avatar
I think that there is a wire that you have to connect for it to work. I'm not sure which one, i've read it somewhere on this forum about that same problem.
Old Dec 19, 2003 | 09:02 PM
bigcozz's Avatar
i Heard that nissan is coming out with a sremote strter unit. Alos I have had them and when it drops really cold they dont work to great. The Coolstart works pretty good.
Old Dec 21, 2003 | 12:06 PM
jsmithsole's Avatar
*moderator*
I just talked to my local installer and he said that the Valet 561 T won't work with the stock keyfob. Can anyone tell me for sure if it can or can't? Also he said that the stock "keyless entry" isn't really even an alarm just door triggers and entry, is this true as well???
Old Dec 21, 2003 | 05:15 PM
trust me the 561T will work Install them everyday on these cars I work at a dealer and I also have it installed on my own car.
The reason the heater will not work is because whoever installed it used the radio accessory wire upon remote stat instead of the blower motor so you should take it back and have them check it for you
As far as the factory security it covera all doors and trunk for some reason nissan didn't put in a hood pin as in the 5th gen
Old Dec 21, 2003 | 05:51 PM
OpTi's Avatar
The keyless entry doesn't work when the car is started. So how do you open the door?
Old Dec 21, 2003 | 07:47 PM
bluemaxx's Avatar
Moderator GT-R
My keyless entry works if the engine is running, lock or unlock. I can't lock the doors with keyless or the lock all button if the key is in the ignition and the driver's door is open (maybe all doors, havent't tried) but that's a good thing.
Old Dec 21, 2003 | 08:00 PM
OpTi's Avatar
When my key is in the ignition and the car is running, i can't use the remote to lock/unlock the door. It's different for you?
Old Dec 21, 2003 | 08:10 PM
bluemaxx's Avatar
Moderator GT-R
Yes mine is different. You have an 04? Mine is a 6spd if that matters.
Old Dec 22, 2003 | 06:30 PM
OpTi's Avatar
I have a 98, hmm. That's weird
Old Dec 22, 2003 | 06:36 PM
bluemaxx's Avatar
Moderator GT-R
Who says they aren't getting better every year?
Old Dec 26, 2003 | 04:11 PM
Bosjoe's Avatar
Whats a ballpark figured (Cost) of having this sytem installed.
and does the keyfob work with this starter?
Old Dec 28, 2003 | 01:37 PM
OpTi's Avatar
Bosjoe, I will be getting it done for $180 installed.
Old Dec 29, 2003 | 04:05 PM
mxp1l0t's Avatar
Any one know about the Automate 562A starter (also made by DEI)?? Is it any good?
My dealer recommends this one.
Old Dec 30, 2003 | 08:54 AM
OpTi's Avatar
I've never heard of automate by DEI. Is it canadian thing? checkout www.directed.com
Old Dec 30, 2003 | 12:26 PM
mxp1l0t's Avatar
I don't think that it is a Canadian thing.
Listed on the web site that you mentioned they have Automate owner guides there but they don't seem to be be advertising the product on their main page. Maybe it is a non-retail branding? Any way here is the link I refer to:
http://www.directed.com/guides/ogs.asp
Since the dealer is warrantying this install, they are proceeding with the installation. It is supposed to come with 2 full feature remotes.
Old Dec 31, 2003 | 12:42 AM
kassryan's Avatar
Remote starter
Just tried to have a remote starter (Ultrastarter) installed by a local electronics store. Apparently the installers got in way over their head with the new 2004 Maxima and ended up taking down half of my electronics (power mirrors, locks, heater controls,etc.). Finally had to take to the dealer to repair the damage at about $800.00. The dealer does not install remote starters and recommends against installing these in the 2004 Maximas. Does anybody know of a good installer that has some experience with the 2004 Maximas in the upstate NY area? Had the remote starter installed in my old 1996 Maxima and have been spoiled.
[FONT=Arial]
Old Dec 31, 2003 | 09:03 AM
OpTi's Avatar
[FONT=Arial]
Just go to a reputable place and you should be fine. Aren't they responsible if they break your car?
Old Dec 31, 2003 | 10:30 AM
kassryan's Avatar
I guess I am somewhat apprehensive to have just anyone install the starter. I was hoping for a place and if possible an individual who has sucessfully installed a remote starter in the 2004 Maxima. Yes they said they are responsible and have filed a claim with their insurance company. Should be contacting me within the next few days. Supposedly this is the first time this has happened to them in the last nine years.
Old Dec 31, 2003 | 11:23 AM
jsmithsole's Avatar
*moderator*
I'm having the same problem in So Cal, nobody ssems to have the knowledge to install it, I think I'm going to just upgrade the whole system to the Viper 791VX, any alternate suggestions/comments to this system??
Old Dec 31, 2003 | 06:10 PM
OpTi's Avatar
Any professional remote starter installer can do it. The only difference between using the oem remote and dei's remote is that it uses the door lock pulse to start the car. All the wires are the same except one wire. You just need to tap the green wire(depends on alarm) to the door lock pulse. 3 negative pulse will start the car.
Old Dec 31, 2003 | 06:11 PM
mxp1l0t's Avatar
I got my car yesterday with the DEI Automate AM6 model unit. It works fine but the installer did a poor job I think. He installed it by striping the wires and covering with black tape. Also he drilled a 1/4" hole in the firewall to run 2 wires through without any grommet or anything. The wires would probably rub through with the rough hole. All things that I can fix.
But the installer did not include the Valet switch and LED so I can not change any of the settings. That I'm going to have fixed. The remotes work fine and even open the trunk, etc......
This guy is in Canada. Can you track down an installer from the www.directed.com web site? They are the ones that have Viper, too.
Old Dec 31, 2003 | 07:23 PM
hofb99's Avatar
What "dealer"? Nissan dealer, DEI dealer, etc...? I know that Automate did my paint interior/exterior protection @ the car dealership I bought it... Is that the same company?
Old Dec 31, 2003 | 08:31 PM
OpTi's Avatar
Get the LED and Valet switch on, You need those. Also put a grommet on and run the wires through. They used electrical tape!? WTF! It should be soldered together or using a better method. Electrical tape isn't gonna hold it for long. How much USD was the installation with the unit?
Old Dec 31, 2003 | 09:24 PM
hofb99's Avatar
I got an upgrade to the factory "alarm" system. The dealer contracted it and I ended up getting a PURSUIT alarm system upgrade installed that works w/ my current keyfob. Can any one of the products you guys are speaking of work w/ the upgrade as it's installed now?
Old Dec 31, 2003 | 09:33 PM
mxp1l0t's Avatar
The Nissan dealer, Brasso Nissan. They subcontract the work but they told me that if anything went wrong that I'd just have to go back to them and they would look after it. No running around looking for the install guy.
Automate is a brand of remote starter by DEI www.directed.com that makes Viper and Valet brands.
Old Dec 31, 2003 | 09:41 PM
hofb99's Avatar
Cool. Thanks, mxp1l0t... I looked on the DEI site and didn't see the Automate 562A anywhere. Is it not offered online?
mxp1l0t's Avatar
Yes sir.
As I mentioned, I'll be getting the valet switch and LED installed. Without the Valet switch, you can't do any programming of the features. I'll also be ensuring the firmware hasn't been locked by the installer using the "bitwriter" to program the eprom directly. It's nice of DEI to publish the install manual AND the owner manual on the Internet so we can check up on these installers and make sure we get it the way we want it. If they don't do the grommet and soldering, I'll do that myself. At least they didn't blow up my new car before I got a chance to drive it. Everything works just fine, starting, locking, trunk release, etc.
As for the valet switch and the LED, does anyone have any suggestions for location? I may as well be specific when I get it fixed up.
I spoke to the general manager today and he will have all my concerns addressed in January and he will give me a nice car to drive for the day. Brasso Nissan is pretty good at customer service.
Old Dec 31, 2003 | 09:48 PM
mxp1l0t's Avatar
hofb99,
It may be called a 562A but it is called an AM6 on the DEI site and on the manual that you get. They don't seem to advertise it on the products page but if you look on the manual page you can find the owners and install guide for the AM6. The install guide has the programming of the features in it. It has some nice features and it is a security system too.
It doesn't look like it is sold online but hey, who knows. I'm guessing that it is a non-retail brand. They probably have a retail brand with a different name that is the 562 in the background. I think I saw a Valet model with the same model number.
Cheers......
Old Jan 3, 2004 | 11:03 AM
jsmithsole's Avatar
*moderator*
Thanks, OpTi I'll look into it...
Old Jan 8, 2004 | 08:23 AM
jsmithsole's Avatar
*moderator*
I ended up getting the Clifford Matrix RSX 3.5 with remote start and all kinds of nice features beyong the stock keyfob job. Digital Tilt/ Motion Sensor and Shock sensors. http://www.clifford.com/matrix/responder/default.asp
I'm happy with my purchase...
