Call me stubborn, but I killed one of my pet peeves today!
Old Mar 21, 2004 | 06:31 PM
Max Cat's Avatar
No more NAV safety message!! Well, I still have the message, I just don't have to deal with it anymore. My alarm does it for me. I was getting really tired of hitting "enter" each time I started the car up. So, I pulled the NAV switch panel, soldered a set of wires to the "enter" key circuit (after a bit of testing with a meter to find the correct two traces on the board), and wired these two up to a relay triggered by the lock pulse from my alarm system. My alarm has auto locking which hits a lock pulse 5 seconds after you start the car. This turns out to be the perfect time to slap the "enter" key as well.
After looking at the switch they used for the "joystick", I'm glad I did this. I don't think that thing would have 100k miles worth of "enter" key pushing every time I start up. To see what I mean, those of you with Nav just pull the joystick handle off the switch shaft and look at how tiny it really is!
Old Mar 21, 2004 | 07:06 PM
Mike_TX's Avatar
Mmmmm. Makes me glad my new Garmin 2620 displays the safety message for a second before searching for the satellites, then goes on with life. It also lets me go into "Setup" and disable the beloved "rolling lockout". They figure a passenger might very well be manipulating the NAV while you're rolling, so they let you authorize all functions while underway!
Sweet.
Mike (Gloat, gloat.)
Old Mar 21, 2004 | 07:36 PM
Max Cat's Avatar
Sweet.
Yeah, the rolling lockout is my next attack. It might be difficult in the OEM system because it seems to be keyed off the gyroscope sensing motion. I could be wrong, but it goes into wide open mode if you just stop at a stoplight. No putting it in park required. As soon as you start to drive, it goes back into rolling lockout. I will be getting the service manual online soon and will check out the schematics to see if it is keyed off the speedo or something else, but I doubt it.
Old Mar 25, 2004 | 12:51 PM
bigcozz's Avatar
I owuld rather push the button 1000 times than ride around with one of the doffy Garmin things on my dashboard! Great Idea putting it on your alarm... Average joes definately cant do that. You should start charging for the service I am sure alsot of people are sick of pushing enter not just with the max!
Old Mar 25, 2004 | 03:26 PM
dfurlano's Avatar
I have a question. When you pulled the nav out where you able to get to the plastic screen covering the nav monitor. I would like to change that piece of plastic out with a coated piece of polycarbonate, which will be clearer and can be cleaned without any scratching or clouding.
If so, can you go step by step on how did the unit to get plastic screen?
Thanks.
Old Mar 25, 2004 | 04:03 PM
Max Cat's Avatar
Yeahbut, then people would start sueing ME when they run into stuff because I took away the warning msg that told them not to play while driving......
Old Mar 25, 2004 | 04:11 PM
Max Cat's Avatar
Thanks.
Well, there appears to be two different versions of this. I've seen the TSB on how to clean the lint and fingerprints from the inside of the screen, and it appears to me that the screen cover is actually attached to the dash panel on the earlier Maxes. In other words, when you remove the panel, the cover comes with it.
On my 1 mo old Max, there is no cover attached to the panel. Only the screen itself with no additional layer of "cover". I did not have to remove the screen to do my mod, so I'm not sure if the screen has a removeable cover or not.
IF your Max has the cover attached to the panel though, you just start at the bottom of the console by popping the shifter bezel off, then the entire shifter panel. Once that's removed, you'll see 2 screws to remove that will enable you to remove the CD/Tape/Climate panel. Once that is popped loose, you will see two more screws that once removed will allow you to pry the Radio *****/Nav Screen cover/center vents panel loose. Work slowly and carefully to avoid scratches. The vents are actually attached to the panel, so you'll have to remove it all as one unit.
Old Mar 27, 2004 | 08:01 AM
gmc74's Avatar
Nice mod!
Does the Nav lock you out when you are moving? I know the menus on the non-nav do. Seems odd that a Nav would lock you out.
I still think Honda makes the best Nav for cars, that thing was sweet... too bad their cars suck.
Old Mar 27, 2004 | 09:23 AM
Max Cat's Avatar
Originally Posted by gmc74
Nice mod!
Yep, many of the Nav, and many of the "setup" features are disabled while rolling. That is another one that I want to attack once I figure out how they're doing it. Seems to be tied to speedo or gyroscope since you can access everything while you're stopped, yet in gear. Why couldn't they make it easy to mod by looking for the tranny to be in "P"
Old Mar 27, 2004 | 03:59 PM
gmc74's Avatar
lol
I know the Accord allows you to access it all the time. When I was test driving it, my buddy was sitting next to me bringing up strip clubs on the Nav
I am sure the next person that drove it thought it was strange... lol
Old Mar 27, 2004 | 06:49 PM
Max Cat's Avatar
lol
Heh heh.... should have set them as "home" and "work". THAT would have been funny!
Old Apr 9, 2004 | 09:38 PM
unrealii's Avatar
Knowing how manufactures integrate everything these days, if you were to disable the speed sensor to the nav/radio or something like that, other things could be affected such as the speed sensitive volume control and maybe the navi itself (It could be using current car speed to help track, but I'm sure its 100% satelite based.).
Old Apr 10, 2004 | 05:17 AM
Max Cat's Avatar
Actually, I've been following a thread over on Freshalloy by a few folks who have installed switches on their "VSS" speed sense wire at the nav unit. Works like a charm to bring back the menus, but DOES make the nav stop "moving". You have to flip the switch back to normal when you're done with the menus to get the nav back to normal. I think that the VSS feeds separately to the radio, wiper, and other circuits that use it, so this mod shouldn't affect those circuits. It appears that all Nissan units have the same connector on the nav and that the VSS is in the same position on all of them, but that they use different colored wires on different cars. Trying to find someone with the FSM for a Max so I can confirm which pin/color is the VSS. Once I do, and try the mod, I'll post here how it went.
howardis
Dec 11, 2019 06:10 PM
bigfrank
Oct 1, 2015 12:51 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
