Navigation -- Legal Disclaimer
Old Jun 16, 2004 | 05:51 AM
2002 Maxima SE's Avatar
Wonder if this would work on our cars?
http://www.bmw-accept.com/
Old Jun 16, 2004 | 06:00 AM
dfurlano's Avatar
somone posted a long time ago on how they did a mod for the 2004 Maxima nav system.
Old Jun 16, 2004 | 06:11 AM
Max Cat's Avatar
That particular module would not work on our Nav unit.
Basically, what you have to do to bypass the message is create an "enter" signal about 10 seconds after you start the car. The Max's nav keyboard is multiplexed. That is to say, that it's just like your computer keyboard with just a few wires controlling all the keys. There is no "enter" wire in the harness. To affect this mod, you have to first pull the keyboard and attach (I just tack-soldered to the board) a set of wires across the "enter" key switch contacts. Then, you have to build a circuit that waits 10 seconds after you start the car (to allow the nav to boot up) and then close a relay across those two wires from above for one second (simulating pushing the enter key). This mod works like a charm, and I've done it on both our Armada and the Max. For those of you who can read schematics, here is the circuit that I used:
http://ourworld.compuserve.com/homep...wden/page9.htm
Scroll down to "generating a delayed pulse using the 555 timer". The only changes you have to make is adding another small relay to the trigger part of the circuit that closes when it sees ACC power and changing the 22uf cap on stage one to a 220uf to make the first pulse 10 seconds. All the parts are available at your local RadioShack. The circuit itself must be on constant power (only draws about 5 milliamps at idle).
For those of you who are NOT able to read a schematic (since I know this question is coming)- after considering it for a few months, I've decided not to go into mass production for a few reasons:
1) Liability- I really don't want to get sued when one of you runs into a tree because you weren't "warned".
2) Technical install- even if I made the box for you, you'd still have to remove your center stack and do some soldering on the nav keyboard.
3) Time- I work 6 days a week and really don't have much spare time.
There it is folks! If anyone has any questions, I'd be glad to answer them.
Old Jun 16, 2004 | 09:03 AM
dfurlano's Avatar
Well I'm impressed. But I have a question. Do you know how to make a RCA connector that will attach to the back of the 6 CD/tape deck that has a satellite receiver connected.
I always thought that it would not be that difficult to create a connector that would tie everything together.
I'd pay for that.
Old Jun 16, 2004 | 09:41 AM
Max Cat's Avatar
I'd pay for that.
Supposedly, Blitzsafe (www.blitzsafe.com) has or will have shortly a line-in adapter for the Bose factory system. That being said, I will look at the FSM and see what I can come up with. Not sure how plug-n-play I could make it since those connectors are kinda hard to find, but it shouldn't be more than a 3 wire spice job at worst.
Old Jun 16, 2004 | 12:41 PM
Monotaur's Avatar
Ahh.. I think dfurlano was asking about having an RCA input in addition to having the sat tuner installed. Could we just use some sort of switch?
Old Jun 16, 2004 | 04:59 PM
dfurlano's Avatar
I dont blitzsafe is going to have anything soon... and Monotaur is correct i want both so there is a need for a switch.
I think if its easy enough there is some money in it for you.
litch
123
Jan 4, 2024 07:01 PM
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
