HID Headlight Pattern
Old Jun 26, 2004 | 10:33 AM
Willow's Avatar
I've notice on my 04 that the patten that the HID lights through out looks like this:
......____
___/ <---- Rough drawing, but close.
Has anyone else noticed this? Is this normal. Been trying to find out that answer for awhile. One service advisor send it is normal for the HID to run a little high. I every called Nissan and they had no answer for me.
I personally think something is wrong. With the upper part of the beam like that, it blinds everyone that I am driveing behind.
Anyone have any ideas?
Old Jun 26, 2004 | 11:44 AM
ethorn's Avatar
I think they designed it this way to illuminate the signs on the right side of the road. I have never had a problem when driving in front of my own max (my brother was the first to drive it after I bought it, he drove it home while I drove the rental I had had since my previous car got totaled). I have noticed that people who are oncoming during a right hand curve don't appreciate me much... but if they drive correctly and look at the outer edge of the road and not my headlights it shouldn't bother them either.
Old Jun 26, 2004 | 05:20 PM
Mike_TX's Avatar
HID's are required to have what the DOT calls "cutoofs" to keep them from blinding oncoming drivers. So, instead of a pattern that just kind of fans out like a halogen or tungsten, they have sharp lines separating the light and dark areas. And the area to the left side is purposely chopped off so it doesn't hit the oncoming driver in the eye. This can be a little hard to get used to, but you will.
If your lights are blinding other drivers, it's not because of the cutoff, it's because they aren't adjusted right. Your dealer should take care of any adjustments.
Mike
Old Jun 26, 2004 | 09:13 PM
kmoney56's Avatar
This is completely normal...for more info, check out this site - http://www.hidforum.com/
Old Jun 27, 2004 | 03:57 AM
NismoMax80's Avatar
SuPeRmOd
Mike
Even though the cut off is below drivers I'm following, and on coming traffic, the HIDs are so bright (gotta love them) that I've been flashed (lights) the last 3 nights. I just flash my hi's back to show I am using lows. Some people, usually older, just can't stand bright lights and it ****es them off.
Just don't look at them!
Look away at the white line. I do when the big trucks are coming at me and lights are eye-level. I think HIDs are less blinding on-coming because of the cut offs. Many halogen lights are aimed too high and are duller but right in your eye.
Old Jun 27, 2004 | 07:22 AM
Joseph Zheng's Avatar
i dont know if this is what you guys are talking about, but on my halogens the right headlight illumination is higher than the left, but i dont have the dots.
Old Jun 27, 2004 | 12:59 PM
lightonthehill's Avatar
In my experience, all headlight systems of the past forty years or more have the left headlight beam lowered (or cutoff) noticably more than the right beam for two reasons:
1. - The left beam, being closer to the oncoming lane, is more likely to be in the oncoming driver's face.
2. - When approaching oncoming traffic at night, we are supposed to focus our eyes on the right edge of the road. To better see the right edge, the right beam is not lowered as much as the left beam when lights are dimmed.
Some systems not only lower the beams when dimmed, but redirect the beams slightly more to the right (away from oncoming traffic).
When it comes to hilly/curvy roads, however, all existing dimming systems become meaningless.
Old Jun 27, 2004 | 07:19 PM
Mike_TX's Avatar
You're spot on, lightonthehill. I think most people (myself included) are surprised the first time they drive with HID's. The cutoff on the upper edge of the light pattern is so sharp - and the bright part of the pattern so bright - that it is really dramatic.
I gotta tell you ... the first HID's I got a few years ago really turned me off. I actually looked into getting them changed back to halogens. When I saw the cost, and then again when I got used to them, I learned to enjoy them.
It just takes a little getting used to.
Mike
Old Jun 28, 2004 | 06:50 PM
Willow's Avatar
Mike
Thanks for the input. I think mine are running a little high. I guess its off to the dealer.
Old Jun 29, 2004 | 03:04 PM
ethorn's Avatar
I love all of your input on this forum... You are one of the best, if not the best, source of information. But just for my information I was under the impression that the headlight beams cross each other on all cars. So the left light actually points a little right, and the right light points a hair left. So doesn't it make since that the right light would be cut lower, and appear it is actually the left being cut?
And for non HID owning people, the HIDs are both cut like that. On my car neither light is really aimed higher than the other. The light's cover that flips up when you goto high beams have the cut.
Old Jun 29, 2004 | 08:59 PM
kmoney56's Avatar
They do intersect or at least they're supposed to...however, the passenger side should not point to the left or drivers side, it points straight and the drivers side points towards the right...
Old Jun 30, 2004 | 06:56 PM
ethorn's Avatar
ok... that makes since.. my bad
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
