ugly grill? and tire question..
Old Sep 29, 2004 | 11:49 PM
jeehee's Avatar
hi
i got my 05 max se like 2weeks ago..
smoke/black leather
i just viewed paintshopped maxima pics(sticky posts) in the forum.
there does exist grills like that from somewhere?
another question is
i live in boston,
where rain/snow is a big problem..
which tire would u suggest?
will the stock tire work fine?
thanks in advance.
Old Sep 30, 2004 | 06:19 AM
Souljourner's Avatar
There are a few places online that sell replacement grills, since so many people dislike our stock grill (I don't think it's all that bad, personally).
I'm in the Boston area and the stock tires are fine. Not great, but fine. I've driven my max for 13 months now and this is what I've seen from the tires - they tend to spin if I'm not careful when I take off in the rain, but I'm a little aggressive, and it's front wheel drive, so that's to be expected. Also, they tend to squeal a little too easily on turns. I swear I'm not turning that hard, and I'll hear a little "eep" out of the tires. Feh.
In snow they're fine... no real problems. They're not top of the line snow tires, but I didn't have any trouble last winter. Of course, I've never driven top of the line snow tires, so I don't know what I'm missing.
-Nate
Old Sep 30, 2004 | 11:00 AM
RaTgoesMaX's Avatar
The stock RSA`s will get you through at least one winter,(still lots of tread), the weather here is much like yours. If you are an automatic you probably have Traction Control or Vehicle Dynamic Control so there should be no problem.
My SE is 6 sp manual so I have the Helical limited-slip differential and it works fine.
Old Sep 30, 2004 | 04:32 PM
carcus's Avatar
Originally Posted by jeehee
hi
smoke/black leather
another question is
i live in boston,
thanks in advance.
Stock tires should work fine for you in the weather....
Grill, that is a matter of taste, few ones out there...again, personal taste and they are cheap to buy. I got mine shipped to my house for about $180 bucks and installed it in 5 minutes. You just have to sort through the pics of other Maximas and see what style you like or if you are content with the stock plastic one that will peel and chip.....up to you. Hope this helps. For ideas on a new grill, check Ebay and look at the different ones. Your stock tires should be fine again. Also depends on you if you want a different set of rims and studded tires for winter to swap on. When I drive in snow, even when I was running Nitto 555 on my LS1 Z28, I drove slow....REAL SLOW...never had a problem and those were worse for traction than what your Max had....I did OK, and that was a car with a RWD V8 putting over 300HP to the pavement. You will be just fine in the FWD Max. Just my 2 cents. Unless you are upgrading rim size, keep the stock tires until they wear out.
REDinLV
Aug 15, 2024 12:30 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
ricky7780
Sep 24, 2015 06:50 PM
