Clock runs fast.
Old Oct 4, 2004 | 02:09 PM
burkjb's Avatar
Clock runs fast.
I"ve had my Max since Jan. and I wonder if anyone else noticed that their clock runs fast. Mine is 5 minutes fast every month. Is ther anything simple Nissan can do to fix it without tearing my car apart?
Old Oct 4, 2004 | 02:19 PM
NismoMax80's Avatar
SuPeRmOd
that's a new one. my clock is fine. sure they would have to tear out everything for that one. seems the simplest things take the most work nowadays.
Old Oct 4, 2004 | 02:29 PM
koreanmaximan's Avatar
I've had the same problem ever since last year... Mine is running about 16 minutes now after resetting it about 5 months ago. I just live with it... It's no big deal for me. On the upside, I'm never late to any meetings...
Old Oct 4, 2004 | 02:39 PM
prostock53's Avatar
Mine too, 2 minutes a month. Oh well. Gives me something to complain about.
Old Oct 4, 2004 | 04:35 PM
DougJones's Avatar
Well, I guess I'm not alone. The wife pointed out that mine was 5 mins fast as well.
Old Oct 4, 2004 | 04:36 PM
PhxBlue's Avatar
MK3 Supra and Focus ST
My 2k2 does this as well, i just reset it every so often.
Old Oct 4, 2004 | 05:47 PM
MAXSE-RIOUS's Avatar
Yup... mine too... 2-3 minutes a month, but the bright side, as koreanmaximan said.... it helps you to not be late!
Old Oct 4, 2004 | 06:18 PM
2k4MaximaSE's Avatar
.......I've noticed this in my navi system, never had complaints about it though. I find it a bit comforting as a matter of fact. Actually makes me consider the time even more, especially when it comes to going to work.
Mine's only 3 minutes ahead of time though so nothing big
Old Oct 4, 2004 | 06:42 PM
jsmithsole's Avatar
*moderator*
I think the faster we drive our Maximas the further ahead the clock gets!!!
Theory:
1 Minute per month = no problem
2-3 minutes a month = bit of led foot, just like taking out those civics!!!
4-5 minutes a month = simply loving to DRIVE the Max.
More than 5 minutes = you just want to see how much time you can add to your clock!!!!! (go burkjb!!!)
ps my clock is between 2-5 minutes per month...
Old Oct 4, 2004 | 07:40 PM
CanadianMoFo's Avatar
I never noticed that. Now I'll have to keep any eye out for it. Of course I'll have to tell you guys mine gains at least 6 minutes per month to show I have bigger ballz than you.
Old Oct 4, 2004 | 08:14 PM
Tvetti's Avatar
Even my other electronic clock that run on battery does that. Guess it is a a hidden bug....
another reason for lemon law, well eh?
Old Oct 4, 2004 | 08:17 PM
WHEELMAN_03_SE's Avatar
Theory:
Nice try, actually a clock in a moving vehicle will run slower than actual time, but who really cares time is what you make it not a number that some human came up with, that aside i think the people whose clocks are running fast need to drive their maximas more frequently...... vehicle clocks are probably designed to run slightly fast to keep them at "real time" with average usage
Just my $.02
WHEELMAN
Old Oct 4, 2004 | 09:30 PM
akaxmrxhammer's Avatar
hmmm... i never noticed that. that's something new
Old Oct 4, 2004 | 10:57 PM
Definately add that to the lemon law complaint list. And the fact the cruise control can't be set for more than 149KPH.
Old Oct 5, 2004 | 05:49 AM
RaTgoesMaX's Avatar
My clock is about 2 min. a month fast same as my 02 Altima was. I just reset the damn thing.
How did you find out the cruise didn`t work beyond 149kph?
Old Oct 5, 2004 | 08:20 AM
lzee1's Avatar
MaxLover
Yeah, mine runs a little fast too...but I like it that way since it makes me get to work on time!
Old Oct 5, 2004 | 08:43 AM
Because one fine day I was rocketing up a divided highway and kept holding down the accel button. Eventually it stopped just shy of 150. I kicked it up over 150 and tried to set it, and suprise suprise it wouldn't work. I guess it makes sense to have a limit on the upper end that it can be set at.
CM
Old Oct 5, 2004 | 08:55 AM
RaTgoesMaX's Avatar
Hahahaa good one, U R brave. I never had the ***** to set it beyond 140kph.
That was a good speed on the I95 going to NH. Ever been to the races in Loudon?
Old Oct 5, 2004 | 09:34 AM
NismoMax80's Avatar
SuPeRmOd
In the manual it states the Min Max speeds for cruise control. IIRC it's set around 30-90mph? somewhere around that range.
My time machine is broken? I've hit triple digits more than once and the clock is still accurate. Man I got jipped with just a plain-superfast Max. I want to time travel too!
Old Oct 5, 2004 | 04:47 PM
mikey0120's Avatar
Mine does the same thing.
Old Oct 5, 2004 | 07:58 PM
rnupetroop's Avatar
mine too is 5 minutes fast, least I know I'll get to work on time.
Old Oct 6, 2004 | 06:15 PM
kenny's Avatar
Easy fix and you don't even need to dismantle anything. If your clock is fast by 2 minutes monthly, in 30 months it will be fast by one hour. In that case, all you need to do is drive to another time zone and you will be ok!! Simple and expedient :-)
Old Oct 6, 2004 | 07:12 PM
NismoMax80's Avatar
SuPeRmOd
well, that time zone would be in the Atlantic Ocean for me. Also, what about daylight savings?
Old Apr 25, 2005 | 08:56 PM
tubells's Avatar
clock time
MInor problem with my 04 Se ... does not bother me much but just want to know if anyone else has this problem
My clock keeps gaining a minute or two every couple of weeks... keep setting it right .. only to find out its racing again!.. I dont know maybe trying to keep up with the engine:-)
Old Apr 25, 2005 | 10:23 PM
boone's Avatar
You gon' pay what you owe
I'm not seeing this problem in my '05 but my '02 used to do the same thing. I ended up getting in to the habit of just resetting it every once in a while. Also, since it was getting faster, I didn't have to worry about being late.
Old Apr 25, 2005 | 10:31 PM
jsmithsole's Avatar
*moderator*
Same problem, there was a thread a while back about this and others had the same problem, just reset mine today actually!!!!
Old Apr 26, 2005 | 12:18 AM
eLMo's Avatar
On my 04 I had this problem but on my 05 no problem. Haven't had to set the time since I bought it.
Old Apr 26, 2005 | 03:44 AM
ramberg's Avatar
GrandPa
Elmo, how are you doing?
Old Apr 26, 2005 | 08:31 AM
clayman88's Avatar
Yep..mine is constantly runnin' fast.
Old Apr 26, 2005 | 10:00 AM
Joseph Zheng's Avatar
can't complain, gets me to school on time.
Old Apr 26, 2005 | 12:51 PM
VTmaximaVT's Avatar
same problem with mine, it kinda bothered me at first, but i got used to it now.
Old Apr 26, 2005 | 06:02 PM
eLMo's Avatar
Hey wat up, nun u?
Old Apr 26, 2005 | 07:04 PM
Monotaur's Avatar
Yep, mine is a bit fast too.
Old Apr 27, 2005 | 12:30 PM
Edify11's Avatar
I added a Powered by Casio sticker and a wing on my clock and it's 5 minutes faster now.
Old Apr 27, 2005 | 08:48 PM
tubells's Avatar
Old Apr 28, 2005 | 12:55 AM
MaxMus's Avatar
interestingly enough, my 05 keeps the time perfectly, while my 5th gen was generally up to 10 minutes faster.
i wonder if this problem is isolated to non-nav maxers?
Old Apr 28, 2005 | 02:51 PM
Monotaur's Avatar
Could be, I'm an 04 SE non-nav.. and mine is fast.
Old Apr 28, 2005 | 03:00 PM
SilverMax_04's Avatar
I'm the same (no Nav) and have the same problem. I would say my clock gains about 2 to 3 minutes a month. Looks like the '05s don't have this problem. Must be a better clock chip in the newer Maxes.
Old Apr 28, 2005 | 08:02 PM
tubells's Avatar
or a crappier one in the 04's
Old Apr 28, 2005 | 10:31 PM
lightonthehill's Avatar
My '04 SL clock must be close to accurate, as it seems to coincide nicely with the hourly beep on the radio station where I catch the news.
Of course, I reset the clock whenever the battery is disconnected for whatever reason, so I haven't had a really long stretch of months in which to measure the clock's accuracy.
