VDC Has anyone pushed IT?
Old Oct 31, 2004 | 06:19 PM
licnyc's Avatar
Please reply to this thread! Thanks>>>>>
Old Oct 31, 2004 | 06:30 PM
Loe max's Avatar
don't push it, VDC stands fer Very Dangerous Cshat Whats your reasoning behind asking if anyone as pushed the VDC botton? It just shuts off your vehicles' stability system, so no throttle or brake will intervein when you oversteer or understeer. BUT, in daily driving, the only time you'd probably notice this is when its wet on the ground or the ground has a layer of fluffy stuff. Its OK to have it shut off
Old Nov 1, 2004 | 12:48 AM
licnyc's Avatar
Reason is if one has expierenced the wonder of vdc by pushing there max to the limit. Just wanted feeback on there expierence.
Old Nov 1, 2004 | 11:08 PM
MaximusX's Avatar
I don't even have a button for VDC......unless I'm retarted
Old Nov 1, 2004 | 11:20 PM
lightonthehill's Avatar
I haven't intentionally pushed my SL yet, but I do leave the VDC and TCS systems on at all times. I was delayed for months in getting my Maxima because I was not interested in buying one without VDC/TCS.
There was one time when I did an extremely quick lane change to the left, then back to the right (a driver pulled out in front of me as I was bearing down at 55 mph), where I had the feeling the system may have kicked in very briefly.
The only other two times I felt something unusual was going on both happened when I was backing up at a fast clip (around 30 mph) and cut the wheel sharply. Made all kinds of clunking noises underneath.
I have been babying my Maxima so far, but the time is coming when I will find out how well the VDC/TCS can compensate for my miscalculations . . .
Old Nov 2, 2004 | 03:08 AM
SilverBelle04's Avatar
Its on the bottom of the dashboard to the left of the steering wheel.
Bob
Old Nov 2, 2004 | 05:58 AM
jasonjm's Avatar
I have pushed it, and pushed it hard. There is a delay when vdc comes on and when the indicator light comes on. By the time it says slip, it has already been working for a while. The trick is to feel when it's going to bite and adjust your throttle so it doesn't slow your exit speed down but still hang on the edge to get vdc to kick in just a tad;-) . Trail braking works real well with it too. Suprisingly it's quite effective. Obviously not as effective as my old racelogic unit but it does alright.
Old Nov 2, 2004 | 09:00 AM
licnyc's Avatar
Thanks jasonjm just wanted feedback on other max vdc user dry pavement wet and snow. Pushed my vdc on my max was very impressed with my feedback (dry pavement) the max handled very well. thanks again....
Old Nov 2, 2004 | 09:03 AM
licnyc's Avatar
Bob
Thanks silverbelle04 I know where its at. Just wanted to know who has pushed there max with vdc on? looking for user feedback. Thanks for your reply.
Old Nov 2, 2004 | 10:12 AM
MAXSE-RIOUS's Avatar
I don't have it to 'push' Wanted it, but none of the early production 04's were coming thru with it in my area... when I took delivery back in April '03
Old Nov 2, 2004 | 10:14 AM
Zeke's Avatar
What kind (if any) of mileage difference do you get with VDC turned off?
Old Nov 2, 2004 | 12:54 PM
Zeke - VDC should have absolutely zero effect on gas mileage. Even though it is 'on' control switch wise, it is actually in a 'wait state' monitoring car movement, etc, looking for any indication the car may be nearing an out-of-control or unstable situation.
For many drivers, VDC may never actually do anything. But for aggressive drivers, or non-aggressive drivers in an emergency control situation, it may operate a few seconds every now and then. But it does little things like applying the brakes on one wheel for intervals as low as a tenth of a second. Just tries to keep the car from skidding out of control. VDC has nothing to do with gas mileage.
Old Nov 2, 2004 | 01:41 PM
04SEelite's Avatar
Bob
Bob - those pedals look GREAT!
Old Nov 2, 2004 | 03:01 PM
jasonjm's Avatar
Yeah, where did ya getem? :-D
Old Nov 2, 2004 | 06:16 PM
05Max's Avatar
I would like to get a dead pedal like the one in the pic. What and where? Thanks, JB Lewis
Old Nov 3, 2004 | 02:17 AM
The brake cover:
The gas pedal:
The dead pedal:
You should be able to get everythnig form the dealer for about $70. The dead pedal is from a 350Z and the other 2 are from the 20th anniversary Maxima.
These are not a perfect fit. They need to be made to fit with a dremel tool.
Before doing this, i would check out the new pedals on the new Altima SE-R. They are very similar to these and probably fit right into the Max.
The Altima SE-R pedals:
Bob
Old Nov 4, 2004 | 06:12 PM
jasonjm's Avatar
Please keep in mind that if you decide to take some turns when it's either snowing or raining VDC will help...UNTIL... you start to hydroplane. At this point NOTHING...I repeat...*NOTHING* will help you. Traction, VDC, awd, whatever.... your hydroplaning and you ain't stoppin till your *tires* (key word here...tires) decide to grip the tarmac. Another reason why one of the most fundamental and crucial upgrades are tires.
SO...VDC is great as long as you got some contact with the road.
Old Nov 5, 2004 | 03:06 PM
licnyc's Avatar
Thanks jasonjm I understand that on hazardest enviorment pavements vdc works? We hope! But HAS anyone pushed it on dry road ways like 80 deg. curves (dog legs) MPH not specified, to see what this vdc computer can do? Can the vdc handle it? that was my orginal question! Is vdc a working option or is it a buy this it works? I would also like to say, Like your peddals belle>>>> Thanks for your reply jasonjm. licnyc
Old Nov 5, 2004 | 07:55 PM
MaximusX's Avatar
Bob- That specific area of my dashboard to the left of the steering wheel is empty. There's a plastic cover over the button where the VDC button should be.....I believe VDC is an option that I didn't get.
Old Nov 5, 2004 | 09:09 PM
jasonjm's Avatar
VDC as i said will handle it. Equivalent to about 15-20 percent slip on my old Racelogic. Only problem is that the traction control is primative, which is why I also said with practice and the right line VDC and not traction will bite. YOu don't want the primative traction control cutting throttle and re applying it suddenly. With this in mind I have initiated 4 wheel slides on WARM tires in 90 + degree weather into turns that will *not* trigger vdc or traction control. The same turns on Cold tires for a couple of laps produced unpredictable behavior. I would say that Nissan has configured the slip quotient to allow a slight degree of aggressiveness. And again, VDC works even if the SLIP light doesn't show. So there, hope that answers your question.
I will revisit this question, once I have my entire suspension re-done soon along with some slicks.
Old Nov 5, 2004 | 09:15 PM
jasonjm's Avatar
by the way, Dec 11-12 for Road Atlanta. Bring your max if you want to test VDC for yourself or test your skill and try to keep up ;-)
c u there
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Mar 29, 2016 11:08 AM
homewrecker
Sep 23, 2015 03:41 AM
RWCreative
Sep 21, 2015 11:01 AM
