How To Install The Injen Cold Air Intake?
Old Jan 6, 2005 | 07:04 PM
maxxoutt's Avatar
I Just Tried Putting On The Injen Cold Air Intake ,and It Was A *****.the Guy At The Shop Is Telling Me That I Need To Take Off The Bumper.is This True.any One Install It Yet?
Old Jan 6, 2005 | 07:07 PM
jrod1014's Avatar
I've heard of the bumper having to come off on the Z's but not the Maximas... I guess it would have to come off for ease of installation...
Old Jan 6, 2005 | 07:25 PM
CanadianMoFo's Avatar
Don't take off the bumper. The instructions say you have to, but you don't.
You need to get access to behind the wheel well liner to install the cone filter. This can be accomplished by removing the wheel well liner, and turning the wheel inwards. The first time I did it, I took off the wheel entirely, and the wheel well liner. The second time I went in there. I just undid the wheel well liner a bit at the front, and turned the wheel in.
There is a resonator that is inside that area. I would suggest for the install you remove the wheel well liner entirely, and the wheel. Then when you go in to clean the filter in 20,000 miles don't bother taking anything completely off.
And WTF are you paying a shop to do that for? Do it yourself man. Its like a 2/5 in terms of complexity. All you need are some screwdrivers and maybe a 10mm wrench.
CM
Old Jan 6, 2005 | 07:28 PM
maxxoutt's Avatar
Imma Do It Tomorrow.good Looks On The Info.
Old Jan 6, 2005 | 07:37 PM
BigCat44
When i did mine, I pulled just the driver side bumper out a little. Drop the 2 screws that you can see once you pull the liner out a little. Once I dropped those 2 screws and moved the bumper a bit I had real good access to everything needed. Install didn't take very long at all.
Old Jan 6, 2005 | 07:38 PM
Just make sure you leave room in the hose connectors for flex. You don't want the parts to butt up against one another and wear inside the intake. Leave a small bit of space between each one so the whole unit can flex as the engine rocks on the mounts under load.
95Maxi
Aug 29, 2015 09:38 PM
bc992164
Aug 26, 2015 12:19 PM
Dasmith
Aug 25, 2015 10:15 PM
cheftoo
Aug 20, 2015 05:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
