Will a 5th gen SE 17 fit on a 6th gen?
retired moderator
Hey guys,
Wanted to see if anyone had put the 5th gen SE 17" rims on a 6th gen. I am retrofitting some 6th gen rotors/calipers onto my 5th gen soon, and want to make sure the rotors/calipers will clear my stock rims (used in the winter).
btw, I am already running 6th gen rotors with 5th gen (smaller) calipers, so I know the rotors will clear.
thanks!
thanks!
Originally Posted by eLMo
I've Seen a 5th Gen with 6th Gen SE rims. Looked pretty hot.
retired moderator
Originally Posted by Tek-Niq
irish want's to know if the 5th gen rims fit our brake set up cause he is thinking bout putting 6th gen disk and caliper on a 5th gen.......
Originally Posted by irish44j
exactly....I know the 6th gen SL comes with 17's, but I believe they are a different offset (35mm) than the 5th gen SE 17's (45mm)......that's why I want to know. A centimeter can mean alot wrt brakes/wheels!
maybe I can get one of the 5th gen guys to try the idea out at the RI meet..
Tek-niq....don't worry about it...I'm pretty sure I'll be ok. Just wanted to see if anyone had tried it, but not worth you playing with wheels out in the cold!
Will a 17x7.5 wheel with a 45mm offset (from a newer G35) with a 225/55/17 tire fit a 2004 Maxima ? I currenly have 18x8 245/45/18 and they look great but the ride it too stiff and Im thinking about getting a smaller wheel/bigger sidewall.
pktaske
05-06-2016 07:49 AM
pktaske
09-04-2015 08:40 AM
