Resetting ECU after mods
Old Jan 16, 2005 | 02:58 PM
DeusExMaxima's Avatar
How do you reset the ECU after you make mods to the car?
Old Jan 16, 2005 | 03:07 PM
Glude's Avatar
Im sure SR20DEN could answer this one for us. Anyone else who knows it please post.
Old Jan 16, 2005 | 03:10 PM
Hey Glude, DO you know how to remove tail lights on 05 Max?
Old Jan 16, 2005 | 04:59 PM
Willster's Avatar
Great question!
Old Jan 17, 2005 | 12:16 AM
Edify11's Avatar
Is this really neccessary after you mod your car?
Old Jan 17, 2005 | 01:00 AM
Glude's Avatar
Some say it is. I dunno because I have never done it. I believe it has something to do with the ecu being obd2. Before 95 it was obd1 and cars would adjust to mods.
Old Jan 17, 2005 | 05:07 AM
msoemax's Avatar
Pull the negative battery lead and wait 5 mins. Then put it back on. This should put the car back in to a "learn" mode for the first ~20 min of opperation. And there's also this way.
I thought about this some more and have to ask why do you need to reset the ecm? Is the SES light on? Any way use this process at your own risk!
1.Start engine and warm it up to normal operating temperature.
2. Turn ignition switch OFF and wait at least 10 seconds.
3. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
4. Repeat the following procedure quickly five times within 5 seconds.
---Fully depress the accelerator pedal.
---Fully release the accelerator pedal.
5. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops
blinking and turned ON.
6. Fully release the accelerator pedal within 3 seconds after the MIL turned ON.
7. Start engine and let it idle.
8. Wait 20 seconds.
9.Rev up the engine two or three times and make sure that idle speed and ignition timing are okay.
Old Jan 17, 2005 | 11:06 AM
kevin7r's Avatar
Remove the positive cable from the battery. The negative cable alone will not reset the ECU.
Old Jan 17, 2005 | 11:13 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
I don't like the fact of removing the neg with the positive still attached.... I would do both and remove the pos first...... removing the neg only ok to do?
Old Jan 17, 2005 | 11:55 AM
kevin7r's Avatar
All you have to do is remove the pos post only. remove the pos and your ECU is reset automatically. I know this because I had to reset mine last week.
Old Jan 17, 2005 | 12:08 PM
Ceasars Chariot's Avatar
Old Maxima Legend
im still yet to come to a conclusion for myself if this is fact or myth ? i would like to believe it is true and this is speaking from the 4th gen information i have gathered. the a34 ecu could be different than the a32 ecu ?
many think that the ecu adjust to driving styles, mods, and octane rating. many maxima owners swear by it and many say its a load of crap.
Since I have little automotive knowledge I had the same nissan mechanic working on my car who has done every mod and all maintance. he swears up and down the ecu will adjust here are some examples:
(same car example)
granny drives to walmart and back then off to the pet store for bird seeds and doggie vitamins, young buck flys around town in the same model max ,stomping the gas, and pushing the car to the limits. if these two cars were to meet up and race, because the ecu learns the driving habits of each driver, the young gun in his maxima would win the race ( all things same ) just because the ecu has learned how the heavy footed maniac drives around.
i use to experiment with race fuel just some 100 octane. i told my mechanic and he says he man, the ecu has to adjust to the fuel, your wasting money. put the stuff in way ahead of time.
with mods, he also says the ecu will adjust to the mods, run the car and you will see
again im willing to say this sounds right, but here comes the big question. other guys have tested these theories out at the 1/4 mile strip and see no different in there times. this is done by taking 2 ecus and swapping them out, there is also dyno proof that even by swapping an ecu that has been in the car for a period of time, and then putting in an extra ecu, there is no difference.
so again, im lost.... im still leaning towards the ecu learns but with all the post and info on the boards and elsewhere it may be wishful thinking.
edit: sorry about the spelling, i must be drunk and not know it ?
Old Jan 17, 2005 | 04:13 PM
msoemax's Avatar
When you swap an ecu you have removed power from it. My understanding is that it will loose the stored data from your driving habbits and thus needs to relearn it. Now if you changed the lookup table values that's a different story. You might be running a tweaked ECM intended for mods on a specific car. When you swap that to a differently modded car of course it will run different. Just my thoughts. I know that after I got my new battery installed my maxima seems more sluggish.
Old Jan 18, 2005 | 03:43 AM
maxmale's Avatar
dont know if this helps but when i made my intake my ses light came on and then went away about a week later. hasnt come on sense.
Old Jan 18, 2005 | 06:42 PM
carcus's Avatar
After doing a few resets on my OBD2 LS1 after mods, seemed a tad stronger than adjusted back to normal. I think with the Maxima.....my opinion, the ECU will just revert back to normal. Now, if there was ever a programmer for the ECU, that you could lock in the program. This is just from my experience. The ECU will adjust for knock retard....not sure on the benifit of a new exhaust or just a simple HAI intake. Than again, the only mods I like for the Max are a CAI not a HAI and a pulley. I doubt a reset will do anything for them though. Technosquare is working on some new ECU programs.....kinda expensive, and I imagine that will void the warranty if and when Nissan finds out about a swap....that would be the only time I would do a reset. Stock ECU should find out most minor mods....very small adjustment. Not like we are doing a head and cam swap that will reqire a reprogram...or a SC or Turbo. Again, just my 2 cents. None of these mods we have for the 6th gen should require a reset. Tell you the truth.....seems like some of the high dollar exhaust mods or HAI do little for gains.
Old Feb 18, 2005 | 06:56 PM
2K4EliteSE's Avatar
[QUOTE=Ceasars Chariot other guys have tested these theories out at the 1/4 mile strip and see no different in there times. this is done by taking 2 ecus and swapping them out, there is also dyno proof that even by swapping an ecu that has been in the car for a period of time, and then putting in an extra ecu, there is no difference.
edit: sorry about the spelling, i must be drunk and not know it ?[/QUOTE]
I may be wrong but going from my experience from my Grand Prix GTP which also was OBD2. Simply swapping the ecu's alone most likely won't improve performance and may also hinder it. See the ecu has a crankshaft position sensor which it relies on to achieve the proper timing. changing the ecu will throw off the accuracy of the crankshaft position sensor, thus throwing off your timing. An example of what i'm talking about would be to take off a distributor ignition, crank the engine and simply put the distributor back in. The timing would be all out of whack. It could be advanced of retarded in the end result. After removing the ecu and replacing it with a different one you would need to get a "case learn" ( as it's called on GM cars) to relearn the crankshaft position. Keep in mind this won't be an issue if you remove the ecu and put it back in say if you sent your ecu to get reprogrammed, without starting the car. Maybe someone with more insight into this particular unit can shed some more light on this as i'm not familiar with this unit, i'm just going by the way the americans did things.
Old Feb 18, 2005 | 07:04 PM
There doesnt seem to be a definitive answer as to how to reset the ECU!
Old Feb 19, 2005 | 05:42 PM
Glude's Avatar
The instructions are listed above. If you perform them acurately then it will reset the ECU. Timing is the key when doing this.
Old Jun 22, 2005 | 03:23 PM
SLuxury's Avatar
The ECU is ALWAYS learning... it adjust timing, fuel, etc... according to all the variables that are sent to the ecu from all the sensors.
If you have a CEL, try disconnecting the terminal and stepping on the brake pedal and turning the key to the start position. It has worked for me.
Old May 19, 2011 | 12:55 PM
MiamiMaxima's Avatar
Question, gentlemen, wont the radio ask you for a code tho if you disconnect the battery??
Old May 19, 2011 | 01:15 PM
xorbitman's Avatar
3. Confirm that accelerator pedal is fully released, turn ignition switch ON (without running the motor of course) and wait 3 seconds.
5. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL blinks.
6. Fully release the accelerator pedal within 3 seconds after the MIL blinks.
7. Remove key then turn to first position again and wait 3 secs then start engine.
8. Wait 20 seconds.
I edited this procedure for more accuracy.
BTW - When you press and release the accelerator pedal you can do it at a fair pace...and count while you do it to help you....1,2,3,4, 5. then count one one thousand, two one thousand, three one thousand, four one thousand..until you reach seven...then fully press the accelerator pedal (for about 20 seconds) until you see the SEL light blinking. Then wait three seconds and remove your foot...and key from ignition. And follow the rest of the instructions....
Once you get the knack of it you can do this with your eyes closed in under two minutes of getting in to your car. I do this every time I do fill-up. In winter I use low grade gas...sometimes mid grade...however in the summer I use the highest grade gas available. In Canada we have Petro-Canada that has 94 octane...after I do ECU reset that 94 Octane feels like rocket fuel! Of course , I have a lot of mods too which does help! Very easy to do once you get the feel of it.
Old May 19, 2011 | 01:31 PM
officerfrasher's Avatar
No.
Old May 19, 2011 | 02:20 PM
NmexMAX's Avatar
dot dot dot ...
Jesus, is it me or did 2005 call and ask for their thread back?
Old May 20, 2011 | 05:25 AM
the macedonian's Avatar
- awesome
Old May 20, 2011 | 05:34 AM
321VQ35MAX's Avatar
Old May 20, 2011 | 06:49 AM
NismoMax80's Avatar
SuPeRmOd
um so i reread this from 05 and wondering if there was an ultimate conclusion?
and no your radio will not ask you anything
Old May 20, 2011 | 08:35 AM
QwikKota's Avatar
"After reset...check ignition timing."
Too funny, what diagnostic software and laptop OBDII to Serial port cable should we use?? This may be like the people who taste wine for a living, there are those who can tell if the timing is correct by revving the engine in neutral.
Old May 20, 2011 | 03:00 PM
NmexMAX's Avatar
dot dot dot ...
No reason IMO to reset it. I never do.
Old May 20, 2011 | 05:55 PM
NismoMax80's Avatar
SuPeRmOd
what I figured. Only ever seen it useful to clear a code or CEL, and if it returns you have a problem.
but now since the car is always learning and adapting... would resetting erase all that for whatever reason and start like from factory? maybe if you change owners?
Old May 20, 2011 | 06:16 PM
xorbitman's Avatar
Interesting news: There are now a few different companies out there that sell moded ECU software that can reprogram your ECU! Some as inexpensive as under $300! Of course you should have this done by a qualified shop/tech and you should have a baseline dyno then you can reprogram the ECU then Dyno run again then finetuning of the results. This is similar to what Technosquare was doing except better and way less expensive and/or risky.
Old Jun 22, 2012 | 09:16 PM
coolsun's Avatar
Hi, sorry to bump this. I currently have a low idle issue where it idles below 500 and does not stall. I tried brake pedal relearn process and no success. Is this the only way to adjust idle? I have a NISMO CAI and a Vias plate.
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
