Lowering Springs..?
Old Jan 19, 2005 | 12:20 AM
jonniewaka
Lowering Springs..?
if anyone got the lowering springs done from eibach..was it a hard job to do??how much was the labor cost??any info??handling wise??pros and cons??warranty?
Old Jan 19, 2005 | 02:42 PM
dirtysouthmax's Avatar
I’m a huge fan of the Eibach springs; I have had them on several cars including my A4 which I had b4 the Max; I am having the Max lowered this ( or next ) week from a place in South FL called California Customs, the total cost including the alignment was just over $600.00. its probably a little over priced, but these guys have a great reputation and they know what they are doing, that’s worth the extra money.
GET YOUR CAR LOWERED AND ALIGNED AT A CUSTOM SHOP!!!!!
As far as handling, I had a mustang and the Audi, both with Eibach’s the ride was just perfect… not so stiff that you felt every bump in the road, but tight enough that the steering response was, especially around corners, noticeably improved… in my opinion, you can’t go wrong.
Warranty is a good questions, if you go to eibach.com I’m sure you can find that info..
Old Jan 19, 2005 | 07:49 PM
jsmithsole's Avatar
*moderator*
I've always been told by dealerships that the warranty is only voided on the suspension, but if something else happens and it was caused by the car being lowered you could run into problems.
I was just running all of my cars through my head and I've never had a car with stock suspension, I have some kind of addiction!!
3 raised trucks, 1 lowered and 2 lowered cars...
Old Jan 19, 2005 | 08:15 PM
jonniewaka
do you have to get it alligned and does it cost like 600 bucks..?i was thinking 160 for install nearby ..not alinged..did every pay for allinging there car too or only install..prices?
Old Jan 19, 2005 | 08:22 PM
SSurfer's Avatar
Took me about five hours and I was taking my time with no air tools & hoist.
Old Jan 19, 2005 | 08:27 PM
Ammi's Avatar
350 Detroit Muscle
Springs you can probably install at home. Air tools help alot. Make sure to get an alignment but I say drive around maybe for a week for your springs to settle first.
Old Jan 20, 2005 | 04:58 AM
BigCat44
Do the springs yourself if you have access to a lift, really easy to do job and no you don't have to do a wheel alignment if you don't want to.
Old Jan 20, 2005 | 06:17 AM
Ammi's Avatar
350 Detroit Muscle
You don't need a lift. You can just use jacks at home.
Old Jan 20, 2005 | 12:53 PM
jonniewaka
some body in my town try doing oil change at home with a jack and killed himelf instanly..the jack came down on him while changing his oil filter.s
Old Jan 20, 2005 | 04:36 PM
Ammi's Avatar
350 Detroit Muscle
That's his fault. We all know we are not suppose to go under the car w/ a jack alone. You are suppose to use supports. Plus, you don't need to go under the car when you are doing suspension work
Old Jan 20, 2005 | 04:53 PM
roll4life's Avatar
btw whoever is getting eibach lowering springs..are you getting struts too?
Old Jan 20, 2005 | 06:43 PM
BigCat44
It's a lot easier to drop all the wheels and do it on a lift, not that you need a lift but waaaaayyy more convenient. Also I'm pretty sure you need a spring compressor though this was used on a previous car not the Maxima. I wouldn't see how anything would be different.
Old Jan 20, 2005 | 06:52 PM
serpentkilla's Avatar
You don't need a spring compressor, just loosen the center bolt before the other 4. It will compress itself, you will hear a poping sound. After that loosen the 4 bolts and your good to go.
Old Jan 20, 2005 | 06:55 PM
Ammi's Avatar
350 Detroit Muscle
All I'm saying is that if you got access to a lift and powertools, great but most of us don't have access to them but it can still be done at home; it will just take longer. I did mine at home but took me like 5-6 hours since I didn't have power tools. Most time consuming was compressing springs w/ a rachet!
Old Jan 20, 2005 | 08:34 PM
DeusExMaxima's Avatar
How much does a garage charge for changing the springs? It may be worth letting them do it if its not much. Course I do my own work but I have power tools and a compressor, but no lift.
Old Jan 20, 2005 | 08:52 PM
Ammi's Avatar
350 Detroit Muscle
Anywhere between $80 - $200 I hear. $80 isn't that bad but most of the places I called wanted $150.
I just like to work on my car so time goes by really quickly. It's fun but if you are pushing for time, maybe it's better if you have a shop do it
Old Jan 21, 2005 | 07:07 AM
04RedOpMax's Avatar
Maxima of the Month Winner
Bzzzzzz! WRONG!! You do need to use spring compresser on the front struts. Trying to remove the springs without a compresser could result in injury (or death). The stock springs are compresssed and are under tremendous pre-load. They are held on the strut assembly by one nut that threads on to the end of the strut shaft.
You remove the strut by first taking out the two large bolts at the bottom, then remove the three nuts at the top of the strut tower. Once you have the strut/spring assembly out, you can use the spring compresser to dissassemble the rest of the unit. Do not remove the nut on the end of the strut shaft untill the spring compresser is in place.
You're welcome.
Old Jan 21, 2005 | 09:06 AM
04RedOpMax's Avatar
Originally Posted by NAGADOIT
they arent under THAT much compression!
To your Mama: Yes they are.
You will need to compress the stock springs a good 2 inches before they can be removed from the strut. I know this from experience: I installed the Eibachs on my car.
Old Jan 21, 2005 | 10:00 AM
Automonjama's Avatar
I live in Detroit and our roads are so bad that I am considering a 3" lift kit anyone tried this yet
Old Jan 21, 2005 | 10:13 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
listen to this member here, he has done the unthinkable to this car. just look at his home page. I love what he has done. and I'm considering those mufflers as well also.
Old Jan 21, 2005 | 11:08 AM
04RedOpMax's Avatar
Hey Tek-Niq, Thanx for the "ups".
Here's a link to my site, if anybody is interested:http://www.cardomain.com/id/04redopmax
The thing I want to stress is safety. Be smart when you are working on your car. Always use jack stands to support the car when you are working under it or even near it. If you don't have the proper tools or equipment to work on struts, get a pro to do it.
Old Jan 22, 2005 | 06:13 AM
You're welcome.
I'm not gonna get into a pissing contest with you, i say you don't need a compresser and you dont. If you lossen that one bolt first without lossining the 2 on the bottom, where is the spring gonna go? If you try this with the strut assembly out of the car then your asking for it. I've done this numerous of times once with the compresser but that s*** took to long. You have your methods and i have mine. Don't act like you know it all.
Old Jan 22, 2005 | 08:36 AM
SSurfer's Avatar
I hope you're joking????
Old Jan 22, 2005 | 11:08 AM
Glude's Avatar
I almost said the exact same thing yesterday but held back my comment. I really wanna know if this guy is serious.
Old Jan 22, 2005 | 01:02 PM
SilverBelle04's Avatar
I think he's just being sarcastic about Detroit road conditions.
Old Jan 22, 2005 | 10:13 PM
BigCat44
Yeah I am kind of spoiled living on base and all, we have a garage called the Auto Hobby Shop. They have them at most bases and you can rent the bays or lifts or paint bays and do all of your own work. The have licensed mechs running around helping but most of the time they do free-lance work to make some extra money! I have used a spring compressor everytime because that spring is under very heavy loads and even if you yourself stay safe, something about physics just makes me not want to put that much strain on one bolt and the tech manual doesn't specify any deviation in the removal or replacement of the springs.
Old Jan 22, 2005 | 11:45 PM
04RedOpMax's Avatar
Have you actually used your dumb-a$$ method on a real car, say a 2004 Maxima? You may have gotten away with not using a spring compresser on some little ricey Honda or Toyota, but I guarantee it will not work on a bigger car with heavy duty springs.
Old Jan 23, 2005 | 08:34 AM
Ok pops, why don't you go and rest your old ***. How can you sit there bash me about something you've never done. Just drop the ****, cuz this is not helping the original poster and i don't want to get of on the wrong foot with you. I don't even know you. Later mr know it all
Old Jan 23, 2005 | 08:37 AM
Oh and i have done it on mazda's, maxima's, mustangs but no toyota or honda, sorry.
Old Jan 23, 2005 | 08:49 AM
Okay guys...everybody's points have been made.......time to move on to something more constructive !
Thanks,
Bob
Old Jan 23, 2005 | 10:11 AM
jsmithsole's Avatar
*moderator*
OK, everybody stop take a deep breath and count to ten...OK now go argue in PM mode!!!
MaxLvr21
Oct 17, 2015 12:11 PM
JonBlz
Oct 5, 2015 06:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Garrettz459
Sep 28, 2015 02:50 PM
