how do you know if your struts are bad??
Old Jan 24, 2005 | 01:14 AM
jonniewaka
i was wondering how you would really know if your struts are bad...i drove my car pass 120 mph alot of times..but now when i go over 120 it kinda gives me a bad vibration in the streeling wheel that didnt happen before..anyway..whats a good way to find out if your struts are bad..does 2005 models have bad struts??
Old Jan 24, 2005 | 01:18 PM
x X CLoud X x's Avatar
Symptoms = squeeky noises when going over bumps/up driveways/gas-stations/ or press the back end of the car, if it bounces up and down several times, its out.. if it feels kinda firm, its still good.. or excessive wheel hop...
check to see if alignment is off, usually when it is or when ur bushings are out, steering wheel shakes over high speeds.. could also be wheel bearings.. use process of elimination
Old Jan 24, 2005 | 01:22 PM
Jeff92se's Avatar
I'm needing a caw
Wow nice. WTF kind of technical babble is that?? You really have no effin' idea what you are talking about. Please try to refrain yourself from constantly talking out of your ignorant ****. Maxima.org would appreciate it.
Old Jan 24, 2005 | 01:25 PM
ThunderMaxi's Avatar
If you are going over 120 mph, the last thing you should worry about is a lil vibration. Worry about how hard you are going to go splat when you hit the concrete. This is the reason why I am not a huge fan of used cars.
Old Jan 24, 2005 | 02:21 PM
deezo's Avatar
Bhahahaha!!!!!
Especially if your on lowering springs, the car doesn't bounce at all.
Old Jan 24, 2005 | 02:44 PM
pae1215's Avatar
what good is driving at 120, no one will see you when you pass by. drive real slow so they can check out your ride
and why would you drive that fast, unless you were on a closed course?
Old Jan 24, 2005 | 04:31 PM
Atomic_Ed's Avatar
Actually most of the time vibrations as you describe at higher speeds are indicitive of the wheels being out of balance or changes to the tires themselves such as flat spots, belt shifting, etc.
I doubt it is your struts.
Old Jan 24, 2005 | 05:14 PM
jonniewaka
ok thanks for the info..and the reason i go those speed is becuase i go to race tracks alot and have performance test with my friends rides..maybe because i have 4000 miles so it kinda means i n eed to rotate the tire??
Old Jan 25, 2005 | 01:34 AM
jeff obviously you have no real experience in cars... i've gone through bad struts, those are symptoms when there out.. think before you speak, or when u have an actual car
Old Jan 25, 2005 | 02:16 AM
Sprint's Avatar
actually jeff has more experience in cars than you could ever dream of...
Old Jan 25, 2005 | 11:22 AM
Jeff92se's Avatar
I'm needing a caw
Yes, "squeaky", "kinda firm" "could be suspension". Wow your technical knowledge is massive!!!!! I especially like the one where you ask about what octane to use. I might not have a "real" car, but at least I'm not "real" stupid.
Old Jan 25, 2005 | 09:21 PM
Glude's Avatar
I may try out the altima seR front struts. From what I have been reading is that they are stiffer than stock springs and a good price too. Not adjustable though. What do you guys think?
Old Jan 25, 2005 | 11:17 PM
NismoMax80's Avatar
SuPeRmOd
why would the ser struts being stiffer than maxima springs make you want to get them? so what if the alti struts are less stiff than your eibach springs? (if that even has anything to do with their desireability) or do you mean the maxima struts? I feel very right about now reading this thread... see what happens when I work 8am-10pm... I miss everything.
hey cloud, what exactly do you drive? the 6th gen has had a bad batch of struts, so I assume jonnie was asking those that had the bad ones what they experienced.
j-waka, tire rotation isn't due until 7500.
Old Jan 25, 2005 | 11:19 PM
i never implied i had an exorborant amount of knowledge but he simply stated how do u know if your struts are bad" i simply answered, so jeff
Old Jan 25, 2005 | 11:23 PM
Glude's Avatar
My stock front struts are blown. Koni inserts cost 375. The altima SeR struts are 57.00 each at mynismo.com. Someone on altimas.net also has been through all the struts listed here plus the nismos and said he has had noise problems. Now he has the seR struts and says they arent as stiff as nismos and dont make noise. Just a cheaper alternative to try before buying the adjustables.
Old Jan 25, 2005 | 11:33 PM
DeusExMaxima's Avatar
I drove an SE-R alti and the suspension seemed mushy compared to the Maxima. The whole car seemed mushy and did not impress me. I think if u can save, the Konis will be worth it in the long run.
Old Jan 25, 2005 | 11:37 PM
NismoMax80's Avatar
SuPeRmOd
now you have my interest. (just threw me for a loop comparing different parts). so do you know if the alti struts are w/in spec for ours? i like the koni ones for down the road if the $ ever comes around (adjustability factor mostly as I'm sure u know). but of course we have to use our/or someone else's questionable oem ones to get them made. (or is the important part replaced by koni?)
if the SER ones work, I'm sure they will be a good alternative for you instead of swapping your springs back to get Nissan to warrant you new ones. (unless D-Max^^ is right about the mushy SER)
Old Jan 25, 2005 | 11:48 PM
Glude's Avatar
Im at 40k so no more warranty work for me. I figured I might just try these springs first. I know some of the seRs are running the Eibachs now so im sure the ride is good.
Old Jan 26, 2005 | 12:06 AM
Glude: I think EIbachs are a good choice if U dont want to invest in struts.
Old Jan 26, 2005 | 01:04 AM
RideTuner's Avatar
so if my struts makes a squeaky noise when i go over bumps, does that mean my struts are bad?
Old Jan 26, 2005 | 09:00 AM
Glude's Avatar
I already have the eibachs on my car. i just need new front struts because mine are blown. and YES, you will have to invest in front struts if you are on eibachs. The stocks will go eventually.
Old Jan 26, 2005 | 09:13 AM
04 maxse's Avatar
I have the koni's up front and guess what.. I still have noise. Good luck guys.
Old Jan 26, 2005 | 09:21 AM
Jeff92se's Avatar
I'm needing a caw
Dude you don't even have common sense. You shouldn't have even posted at all.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
maxima-junky
Oct 7, 2015 06:13 PM
Andy29
Sep 29, 2015 05:32 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
