Factory keyless entry with aftermarket alarm/remote start
Old Jan 31, 2005 | 05:37 AM
Roshan
does anyone know if its possible to still be able to use the factory keyless entry remotes after installing an aftermarket remote start with keyless entry? i plan on gettin a viper remote start kit with keyless entry... but i still want to be able to use the factory keyless entry fobs.... is it possible?
Old Jan 31, 2005 | 06:01 AM
froMax's Avatar
Try this thread...http://forums.maxima.org/showthread.php?t=367856
Old Jan 31, 2005 | 07:48 AM
Automonjama's Avatar
I just bid on the Viper 791 I hope that it is a good one, if you have one let me know how you like it?
Automon
Old Jan 31, 2005 | 03:29 PM
JayMAX22's Avatar
I just had the Viper 130XV installed. It's remote start without the keyless entry. It works fine. I wanted everything the original fob did (trunk, window control, keyless entry, etc) but the dealer told me that wasn't possible. So I just got the remote start since I was going to have to use the original fob for all the other items.
Old Jan 31, 2005 | 03:44 PM
Roshan
jaymax22... i just went to the dealer in laurel.. Tisher.. and they sed it is possible.. but u have to know the right wires to connect it to. they refused to tell me which wires. they sed u have to bring it to the dealer for install... which runs about 700.00
install30's Avatar
Use a Automate 561T....it's a remote start that can be added to your existing remote....it's a DEI product so it's easy to install....
Old Jan 31, 2005 | 05:35 PM
jsmithsole's Avatar
*moderator*
I have the Clifford Matrix with remote start and my stock keyfob still works as well. Not sure why you would even need the stock key fobs after going aftermarket but they do work...
Old Feb 1, 2005 | 09:43 AM
Roshan
i want the stock keyfob just incase the aftermarket doenst work.. had experience with my civic and 99 max when aftermarket keyfobs wouldnt work properly... and the automate 561t? where can ifind that.
Old Feb 1, 2005 | 10:14 AM
MaximaPolak's Avatar
I have Valet'd nissans with original key fobs and aftermarket starters/alarms installed...(aftermarket alarm was controlled on the original fob.)
Press the Lock 3 times - starts the car....
Press the panic 2 times (i think) - and the alarm would sound.
The aftermarket alarms/starters bypass the factory alarm.
MR2 T'd
Jul 9, 2021 05:06 AM
MaxLife17
Jun 27, 2019 01:37 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
trungg86
Sep 4, 2015 04:58 AM
Hailstatejig
Sep 2, 2015 06:52 AM
