Rumbling in Rear, help!
Old Feb 5, 2005 | 02:46 PM
unclemax's Avatar
This just started yesterday (fri) in my 2004 SE with about 7k miles:
Whenever I go over bumps, I'm now getting a low rumbling sound and vibration in the read. It appears to coming from the right rear.
Anyone experience this?
It's making me crazy! I've gotta appointment with dealere service center first thing monday morn, but I can't keep thinking I really damaged my car and it will never be right again. Aaarghhhh!!!
Old Feb 5, 2005 | 02:54 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
it might be that strut problem we have.. we have some faulty struts on some models I guess.
Old Feb 5, 2005 | 05:27 PM
VTmaximaVT's Avatar
i couldn't imagine what "rumbling sound" exactly is....but I had some
noise coming from rear when i went over speed bump.
I had rear sway bar bushings replaced at the dealer and the noise is gone.
Old Feb 8, 2005 | 05:27 AM
unclemax's Avatar
Here's a follow-up, my car is now fixed and back to normal.
I took it into Freehold Nissan here in nj. They replaced the front struts with the updated ones. The service manager told me a lot of the factory struts on the '04s are defective and will fail after around 10K miles. So they replaced the struts and recalibrated the suspension.
Beware: if you are having any kind of rumbling or banging when going over small bumps at moderate speed, take it in and make sure they replace the struts with the updated ones.
UM
Old Feb 8, 2005 | 08:38 AM
msoemax's Avatar
This pisses me off to no end...WTF is up with the struts...I will find out on Feb 21. That is when the DTS from Nissan flies in to fix my car. I will make sure to get answers from him and update the ORG.
I wonder if a bad strut can lead to a hum in the rear. My rear left wheel hums at ~45 MPH. I had the tire balanced and it was fine for the first few miles. It's now humming again at that speed.
The hum is a resonating hum that only occurs at that speed, or most commonly at that speed. Any thoughts?
Old Feb 8, 2005 | 01:42 PM
unclemax's Avatar
Hey msoemax,
The front struts could very well be causing that noise.
I swear I heard rumblings and virbrations in the rear end of thr car when the front struts failed. The first thing I checked was to make sure the spare tire was secured or there wasn't any crap floating around my trunk.
Must be the way the suspension is designed with connections from front to rear?
If they won't replace your struts, maybe you should take a speed bump at around 50 that should make them fail for sure then they'll have to replace 'em.
Old Feb 8, 2005 | 02:05 PM
msoemax's Avatar
LOL, Hmm a fifth set of struts.............
Old Feb 8, 2005 | 10:54 PM
scavynger's Avatar
Any other side effects of having bad struts other than the noise? Noticible difference in suspension, etc?
Old Feb 9, 2005 | 05:32 AM
unclemax's Avatar
on a smooth road going straight with bad struts it's hard to tell. But as soon as you hit a bump or make a turn you'll hear the suspension banging and rumbling. Kinda reminds me of my father's old ****** cab over engine truck!
Old Feb 9, 2005 | 06:54 AM
VaMax04's Avatar
I started to hear the noise as of Monday and gonna take it in for service soon...Will they replace it for free?
Old Feb 9, 2005 | 11:46 AM
unclemax's Avatar
Yep, it was free and took about 2 hours. Make sure they use the "updated" struts.
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
bbsitum
Sep 11, 2015 04:55 PM
