woohoo finishd lights~ pics
Old Mar 6, 2005 | 12:42 AM
tototee999's Avatar
before:
during:
(see the white stuff.. cable ran from the right side of fuses to the left side of fuses so that i can connect both corners to work together)
Old Mar 6, 2005 | 12:43 AM
tototee999's Avatar
results:
(just lights)
(all lights)
(corners, fogs, parks)
Old Mar 6, 2005 | 12:44 AM
tototee999's Avatar
(close view)
(cool)
and:
the fogs do that.. why does the drivers fog shine out and the passenger shine down? is it suppose to do that or did i make a mistake?
Old Mar 6, 2005 | 01:13 AM
RideTuner's Avatar
thumbs up to going through with the project
Definitely unique...if I went through with the same mod, I don't think I'd use blue bulbs though. overall..cool stuff.
Old Mar 6, 2005 | 01:17 AM
NismoMax80's Avatar
SuPeRmOd
um, let us know when you get a sitation for blue lights okay? i just know around here I wouldn't make a block w/ them. very cool none the less.
i would check your fogs to see if you fully secured them. one might not be totally in.
Old Mar 6, 2005 | 05:43 AM
install30's Avatar
Looks good.....
Old Mar 6, 2005 | 06:17 AM
BLAXIMA2K4's Avatar
Good job...whats with the blue bulbs though? I think I would go for some hyperwhite or even superplasmas for the bulb.
Old Mar 6, 2005 | 06:24 AM
Tvetti's Avatar
Swwweeeeet!!! Hope it is with in legal limit!!!
Old Mar 6, 2005 | 06:32 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
I don't see the "pro" of this mod.....
Old Mar 6, 2005 | 08:14 AM
Maxima617's Avatar
Those are nasty but y blue(def. illegal- $300)? do they also turn on when u turn? They are cornering light!!!
Old Mar 6, 2005 | 08:24 AM
6thGenMax's Avatar
Good job, can you hook us up with a detailed how to on this please?
Old Mar 6, 2005 | 10:10 AM
NAGADOIT's Avatar
ticket time...
Old Mar 6, 2005 | 10:15 AM
JayMAX22's Avatar
I would have went with a different color bulb. Too many fines and too many court appearances for the blue bulbs.
Old Mar 6, 2005 | 11:52 AM
CanadianMoFo's Avatar
A "How to" write up would be much appreciated here. Looks simple enough. Wire from the battery to the relay. Run the trigger wire from the relay to a switch in the cabin. Then run a + switched line out from the relay to the cornering lights.
Did I miss anything?
CM
Old Mar 6, 2005 | 12:53 PM
6thGenMax's Avatar
will the factory cornering lights still work when blinkers are used with this mod?
Old Mar 6, 2005 | 01:00 PM
akaxmrxhammer's Avatar
it looks hot, but the blue light kinda looks out of place. definitely go with extreme white.
Old Mar 6, 2005 | 05:59 PM
Mystery's Avatar
Looks nice. I think instead of replacing the lights i would just throw some illuminators in there. Little neons that is, same effect just not as bright. I have them since i took them out of my old car. I put them in the fogs. Just been debating if i wanted them in the max, i've kinda grown out of the neon phase.
Old Mar 6, 2005 | 06:31 PM
-AoW-JP's Avatar
Thats a NYC cops dream come true. It looks cool but they crack downon that sorta stuff here. I am in court for tinted window tomorrow. The cop told me no tint is legal here anymore. You need a permit for it. i have an eye condition and had a doctors letter stating it at the last court date. The judge told me to go to DOT and file for a premit. His wife had too also. Again it looks hot but I hope your a cop .
Old Mar 6, 2005 | 09:14 PM
tototee999's Avatar
to wire it up. it is a lot more difficult to do than it is to explain..
i can give basics.. but i dont want to give too much info cuz itll confuse you and you will mess up (like me, car wouldnt start, due to electrical failure) and then the dealer will be all like
fog light wire color ~ WHITE with RED LINE
right corner ~ orange wire with blue line with 2 silver stripes
left corner ~ blue wire with orange line and 2 silver stripes
IF you know what youre doing, you should know what to do from there.
i also hooked it up to the ignition so when the key goes out, the lights go off..
i tried to write out a whole explanation but it was too confusing, and i couldnt even understand it
sorry guys, and i dont know what ima do about the blue..
maybe i will get the hyper white and stick the other bulbs in the grille or use em as the reverse lights or something ill think of something..
is it illegal to have blue reverse lights? =o
sorry i cant help out with the howto, if it were easier i would. sorry...
Old Mar 6, 2005 | 09:47 PM
ThunderMaxi's Avatar
With the blue light, it looks kind UFO... I would do hyper white to really set it off and not give any second thoughts for cops to get you in trouble.
Old Mar 6, 2005 | 10:07 PM
ch13f's Avatar
basically the law states, rear of the car: red running lights, and brake lights, turn signal can be red or amber, and reverse needs to be white. Front of the car: gotta have white headlights, blinkers gotta be amber, and running/fog lights should be amber or white or somewhere in between
Old Mar 6, 2005 | 10:27 PM
NismoMax80's Avatar
SuPeRmOd
...absolutely no red in the front and no blue anywhere. (cannot give the impression of an emergency vehicle ).
so you are required to post in this thread when you are fined.
but again I admit it looks nice, just not legal. even if it was, too flashy for my taste.
Old Mar 6, 2005 | 11:03 PM
Glude's Avatar
I like the look because it almost looks like a set of fogs on the lower part of the bumper. Man cars have fogs down low and ours are built into the headlights so you dont get the cool night driving look. I agree that some extreme whites would be nice.
Old Mar 7, 2005 | 12:41 AM
maximaman2oo4's Avatar
LOOKS AWSOME.....
What model/type bulbs go in for the fogs and signals????
Old Mar 7, 2005 | 01:04 AM
tototee999's Avatar
Originally Posted by maximaman2oo4
LOOKS AWSOME.....
ebay
if you really want them, i will sell them to you, im probably going to do the right thing and insert either yellow or hyper white
i got a pair of 25 LED blue 3156 (corners)
and
i got a pair of 24 LED blue 1157 (signal)
Old Mar 8, 2005 | 05:33 AM
wsu's Avatar
wsu
other colors and how much coin?
Originally Posted by tototee999
ebay
and
Were there other colors available? Also, if you don't mind saying, how much did the blue bulbs set you back (and how much was shipping?)?
By the way, I think the blue bulbs looks great - they make quite a statement. It's too bad they aren't legal.
Thanks.
Old Mar 8, 2005 | 06:18 PM
tototee999's Avatar
Thanks.
the guy had a few colors.. green, amber, red and white all led lights..
they are not legal i know.. but the cops round here dont seem to care.. they think that they are fog lights~ but i still turn them off when i roll next to a cop.. i just wave and when they arent looking
regardless.. they are tyte. nuff said.
A32goldylocks
Sep 2, 2015 06:39 AM
spidgeon
Aug 18, 2015 05:46 AM
MikesChevelle
Aug 6, 2015 11:36 AM
