intake and car wash
Old Mar 20, 2005 | 05:08 PM
Roshan
intake and car wash
is it safe to power wash the engine bay with the injen cold air intake still on the car? will it suck up water when starting?
Old Mar 20, 2005 | 05:15 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
its ok, its proven already that in order for the injen intake to mess up the car with sucking water, it has to be completely underwater... not just alittle bit like a power wash.. just don't aim right at it when doing it to be safe...
Old Mar 20, 2005 | 08:51 PM
msoemax's Avatar
I was told by the dealer (and saw it with my own eyes too) that it is safe to wash under the hood. You want to use a really mild soap if you do infact use soap and you don't want to use any pressure to wash under the hood. Use as gentle as possible stream of water to wash under the hood. avoid soaking your altenator and your air box. Follow those simple rules and you'll be set
Old Mar 20, 2005 | 11:53 PM
VTmaximaVT's Avatar
I would still try to cover the filter section. you don't wanna soak the filter.
Old Mar 21, 2005 | 09:54 AM
MAJ_Jimbo's Avatar
On my 2002 Passat GLX (RIP) I used to take a bag and cover the intake filter and let spray down the engine at the car wash with the light water already coming out...without depressing the trigger for power wash. This worked great.
My question though...I ordered a Berk intake, but it's on hold cause parts are out to be polished...it comes with teh Apexi dry filter...what happens if this gets wet? Does it damage the filter since it's a dry filter that I hear can go up to 30K? Or do folks recommend getting a K&N or oil equiv. filter? The only thing I would worry about is the mass air sensor (I believe that's the correct term) getting oily...is this an issue?
Jimbo
Old Mar 21, 2005 | 02:30 PM
bigcozz's Avatar
When i got my berk it came with the K& N I have had no problems and I have been running it since december
Old Mar 21, 2005 | 07:39 PM
Maxima617's Avatar
dont let ur injen get filthy... clean it as often as possible w/ special cleaner... my filter is black and i tried to clean but is too dirty to do that... replacement filter cost $75!!!
Old Mar 21, 2005 | 07:49 PM
akaxmrxhammer's Avatar
what filter comes with injen cai?
Old Mar 21, 2005 | 09:05 PM
Maxima617's Avatar
an injen filter to fit the 3.5" piping...
Old Mar 21, 2005 | 09:36 PM
what kind of filter? is it k&n, apexi... etc?
Old Mar 22, 2005 | 08:45 AM
CanadianMoFo's Avatar
Looks like a plain K&N style/type filter. Cotton gauze inside a wire mesh screen. I use the K&N recharger kit on it.
It would be hard to get water into the filter since its in behind the wheel liner. Obviously if you blast water down the hole that the intake pases through you can get the filter wet.
Just use some caution while you are blasting around the battery area and you should be fine. Or do it by hand with a low pressure garden hose. You'd probably do a better job that way anyways. Use an old wheel brush and some degreaser.
CM
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
scarletsosa
Aug 17, 2015 09:09 PM
Maxboy23
Aug 11, 2015 11:59 AM
altome15
Aug 10, 2015 07:05 PM
