Eibach issue...
Old Apr 12, 2005 | 12:33 AM
  #41
MObruin's Avatar
I'm curious as to why more people arent responding. I am pretty sure more people have eibachs than the few posting in this thread, are the others just not having any issues at all with theirs??
If it is in fact an INSTALL issue, where did the people not having any issues get them done?? Were they installed with wirewrap?
I think there are a few of us that would like advice before we buy.
thanks,
-MO-
Old Apr 12, 2005 | 05:22 AM
  #42
04 maxse's Avatar
It's not an install issue and it's not a strut issue. I have been stumped on trying to get this resolved. If anyone finds a resolution let us know.
Old Apr 12, 2005 | 06:48 AM
  #43
MaxiMiller305
well i have the same problem you are having with the popping sound. when i go slow and turn or go over bumps slow i hear it. I have a 04 maxima and put the Pro kit on it. i took it back to the place that installed it and all they had to do was lubricate the damper. apparently if it isnt properly lubricated the spring rubs against it and makes that poping sound. that took care of the drivers side, but now the passenger side does it. Time to go back to the shop!!
Good luck fixing the simple problem.
Hey i got a question... how do i put pictures in this message? i want to post pics of my car but it doesnt let me... thanks
-Johnny
Old Apr 12, 2005 | 06:51 AM
  #44
BLAXIMA2K4's Avatar
Ive got the Eibachs on also for maybe a couple months now. No issues!
Old Apr 12, 2005 | 06:55 AM
  #45
MObruin's Avatar
First off, Welcome Maximiller305!!
Blaxima, if you dont mind my asking....where did you get your springs installed?? Do you know if they added any special hardware along with your springs?? You think its just a lubrication issue after all??
-MO-
Old Apr 12, 2005 | 07:12 AM
  #46
MaxiMiller305
well lemme tell you that i had that same problem on the front driver's side and i took it back to the place, they told me what they did and that was that they lubricated the damper. now it is doing the noise from the front passenger's side. I guess i gotta take it back. I'll tell them to draw a picture for me so i can post it for all of you, lol. But na i feel you guys with the noise that caca is annoying.
another thing, lemme know how to post pics... PLEASE!!
Old Apr 12, 2005 | 07:16 AM
  #47
Mr. Black's Avatar
I had my installed by my local shop. I have had them on for about a month now and I don't hear any popping sounds or have any of the issues listed on here. I asked my guy if he used any type of lubrication and he said he didn't. He told me if others are hearing a popping sound then its definitely an install issue.
Old Apr 12, 2005 | 07:21 AM
  #48
MObruin's Avatar
I havent actually seen the springs themselves yet, but could this be caused by them installing them on the wrong side? What about upside down?? Is there a definite orientation in which they must be installed?
-MO-
Old Apr 12, 2005 | 07:28 AM
  #49
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
-MO-
no you can't install them the wrong way, there's diffrent sides to them... the top is wider than the bottom.... you can tell cause only one side fits on the strut plate..
thats for the front...
I dunno about the rear since this is my first independent susp car...
Old Apr 12, 2005 | 07:40 AM
  #50
04 maxse's Avatar
I really don't think my issue is an installation problem. I get the popping when the wheels turn and a weird popping kind of noise on some bumps. I have had shops put the springs in, I even learned how do do it now. I did it myself the last time and paid attention to every detail.. Maybe Ill try lubricating the damper.
Old Apr 12, 2005 | 07:42 AM
  #51
koreanmaximan's Avatar
lubricate the damper???
Maximiller, let me know if the passenger side works out with lubricating as well?
Old Apr 12, 2005 | 11:44 AM
  #52
Maximam's Avatar
I don't understand how lubing the damper would do anything.
If you look at my install on my 5th gen you will see I put the wrap on the lower part of the spring, I think the wrap in not that low when the shop did mine.
Old Apr 12, 2005 | 12:15 PM
  #53
KCMAXX's Avatar
KC's FINEST
Is this what the Eibachs look like?
This is just some cheap **** I found on Ebay... I wonder if these work as well
Old Apr 12, 2005 | 12:26 PM
  #54
KCMAXX's Avatar
KC's FINEST
Heh, I was just thinkin about how fools used to lower their cars back in the day....
Old Apr 12, 2005 | 01:11 PM
  #55
95Max's Avatar
Lubrication is only a temp solution. You need to find what is rubbing.
Old Apr 12, 2005 | 01:13 PM
  #56
95Max's Avatar
Not to say you didn't look at every detail but is the top mount "out" facing out? If it off even slightly you will getting popping
Old Apr 12, 2005 | 02:43 PM
  #57
Maximam's Avatar
Ya I need to take mine out and check the shops work, too bad I have to do this to get it done right.
Old Apr 12, 2005 | 07:04 PM
  #58
Maximam's Avatar
OK I took apart the front struts today and found the hats were off by a little bit (damn install shop). I dismantled the struts and put them together properly. I am pi$$ed to say it did not fix it. There is a design problem with these strut hats.
I will go coilovers before I have to deal with this $hit.
Old Apr 12, 2005 | 07:42 PM
  #59
ryanmc's Avatar
i have a prokit on 5th gen and it also makes noise on bumps and turns its been on for about 2 years i know from lowering my 4th gen that noise can come over bumps when the spring rings contact each other. the solution to that was using the stock insulator or the wire wrap as others have sugested the other noise when turning was caused by the top hat bearings not being seated properly but there would still be slight noise when the wheel would be turned fully and going over a bump the insulator /wrap helps out big time gl.
Old Apr 25, 2005 | 03:17 PM
  #60
MObruin's Avatar
Any updates??? Anyone fix their noise problem?? I'm still interested in dropping my car but I would really like to hear that this issue got resolved.
-MO-
Old Apr 25, 2005 | 03:23 PM
  #61
viguera's Avatar
-MO-
I HATE the gap, but I'll live with it rather than with noises and pops and ****...
Hopefully they can fix it without going with coilovers, because that's a rather pricey alternative.
Old Apr 26, 2005 | 11:51 AM
  #62
MObruin's Avatar
^^^ I completely agree.
Anyone??? Anyone that had the popping noise problem get it fixed??
Bueller?? Bueller??
-MO-
Old Apr 26, 2005 | 12:26 PM
  #63
Sorry bud... I'm still riding mine with the noise... I was hoping Maximam could find a solution, as he even tried dismantling it himself...
It is really annoying and tell you the truth, lost a very little tiny bit of interest in my baby...
Old Apr 26, 2005 | 04:46 PM
  #64
Maximam's Avatar
I took them apart and re-installed them, still same problem. Something I noticed, they make more noise when driven more. 1st thing in the morning they are very quiet, by the end of the day they are rediculous.
I think the top bearing is the problem but can not figure out why.
Old May 1, 2005 | 02:51 PM
  #65
JayMAX22's Avatar
Add me to the noisy Eibach list. Was riding with my wife yesterday and the popping noise started. Had the Eibachs on for about a month now. I get the noise when I'm not moving. I can be sitting still and turning my wheel back and forth and I hear the popping noise.
Old May 1, 2005 | 05:11 PM
  #66
Maximam's Avatar
Yep, same here. I am thinking either aftermarket struts? or coilovers.
Old May 1, 2005 | 08:47 PM
  #67
rabenoja's Avatar
Has anyone contacted Eibach with this issue? I would give them a call and see if they are know of this problem. I might even call tomorrow because I'd like to drop the car when I get the rims in this week.
Old May 1, 2005 | 09:03 PM
  #68
04BlackMaxx's Avatar
Do you think the springs are just sliding around on their mounts and something is popping in and out of place due to the torsional movements? Are the strut towers properly torqued?
Old May 2, 2005 | 09:06 AM
  #69
SSurfer's Avatar
Its gotta be the upper bearning. I'm changing mine, lets see.
Old May 13, 2005 | 12:19 PM
  #70
Apollos2's Avatar
Please keep us updated. I am really considering some springs, at least in the front. I contact H&R but they only sell them as a set. $369 for the set.
Eibach is scary though, especially the lack of support you all seem to be getting for this problem....And it is a problem, don't care what the installers say.
Old May 13, 2005 | 12:58 PM
  #71
JiuJitsuThug's Avatar
Maybe I will go with H&R over the Eibachs... Anyone used H&R with success or does everyone on the org ride on Eibachs???
Old May 13, 2005 | 01:47 PM
  #72
ramberg's Avatar
GrandPa
I've scheduled for a diagnosis check on the right front spring installation...
Whenever I make left or right turns and go over any size bumps, it makes a squeaking or popping sound.. It sometimes even make a rubbing sound...
The only thing I could think of is misplaced springs...
Any ideas of the problem to discuss with the technician this Saturday would be greatly appreciated...
I have had my eibachs for awhile and here in Brooklyn the street are messed up. I have not any problems with them. Just for the hell of it, do you still have your OEM rims with the tires. If you do put them on and see if you have the same problem. no harm in trying. Warren
Old May 13, 2005 | 01:51 PM
  #73
rabenoja's Avatar
Well I went with the Eibachs anyway. NO noise yet...knock on wood. I had them installed by a nissan dealer. So, hopefully they were put in right. I'll let you guys know in about a month.
Old May 13, 2005 | 02:04 PM
  #74
ramberg's Avatar
GrandPa
I am surprised that a Nissan dealer installed them. Warren
Old May 13, 2005 | 07:27 PM
  #75
rabenoja's Avatar
Yeah, I got lucky and was able to get the guy to do it for me!
Old May 13, 2005 | 07:54 PM
  #76
chernmax's Avatar
Nations 1st 6th Gen Turbo
I put my EiBachs in myself, Zero noise, Zero clunking sounds, Great feel. I suspect they are turned the wrong way or the top, maybe the mounting plates may have be turned, their are arrows on the top plate indicating which direction the plates should face. then the springs are aligned to the plates, I don't believe Eiback would make something and than expect customers to put up with a clunking sound, it's just bad business. The spring design is not defective your install was...
Old May 14, 2005 | 06:19 AM
  #77
njmaxseltd's Avatar
Over the phone, tech said it's quite normal to have such sounds when lowering springs are installed, ..
Find yourself another mechanic to work on your car. Even Eibach will tell you that their springs, installed properly wount make any noise. I've done so many installs on 4th gens, 5th gens and a few 6th gens that I can honestly tell you something is out of place or not lined up correctly. Your suspension should be silent. If the spring is twisting, then your strut bearing is binding up. The assembly should rotate freely, as a solid unit.
Old May 14, 2005 | 07:11 AM
  #78
4drsleeper's Avatar
Had Eibachs installed last week. Love the new feeling, it really handles so much better. No noise, no popping, in fact I've lost the hollow sound I used to hear when hitting big bumps. Love them so far.
Old May 20, 2005 | 12:32 PM
  #79
Apollos2's Avatar
koreanmaximan - What have you heard?
Any word on the Eibach clunk problem?
I think front springs along with painting the black portion of my bumper silver will be the next thing I do. (Almost have enough to get it all done at once now)
I am probably going to go with H&R springs
http://www.hrsprings.com/site/index.html
Interesting, H&R website quotes the price of $369 for the kit.
Tirerack quotes $229 for H&R springs
and $252 for Eibachs.
I read the Tirerack reviews for H&R springs......seem pretty decent.
The Eibachs are kinda scaring me right now because of the problems some have had. Of course I think there are more "Maxers" with Eibachs that are working than are not working, but the bad part about it is that I haven't seen one post from anyone who has the Eibach spring clunk that has found the cause and fixed the problem.
Dealer is quoting me $330 to install the front springs only and $80 more to "re-align everything".....$410 just to install two springs???
Old May 20, 2005 | 12:40 PM
  #80
MObruin's Avatar
H&R lowers the car 1.4" in the Front and 1.3" in the back.
Will this even fix the front gap issue?? And will it lower too much in the back, making the car still 'look' uneven (with the uneven wheel gaps)??
-MO-
