Maxi goes HID...
Old May 3, 2005 | 06:34 PM
HzMajesty's Avatar
Maxi goes HID...
Finally got some before n after pics uploaded of the halogens and HIDs...
http://www.cardomain.com/memberpage/824467/5
Those with HID experience, can you please tell me what you think of the projection on the wall?
The dealer did the leveling, but i don't trust him since he told me there are 2 HID bulbs in the headlight
Let me know if you want different pics at different distances or angles... thanks.
Btw, anyone know what percentage of tint is legal in PA???
Old May 3, 2005 | 06:57 PM
04BlackMaxx's Avatar
The cutoff line on the wall is exactly what mine looks like with factory HID...no problem.
Old May 3, 2005 | 07:01 PM
HzMajesty's Avatar
thanks bro..
the cut off line should be the same because i installed the entire OEM HID headlight assembly on both sides.
But what im worried about is if you look at the picture with the car a little far away from the wall, does it look like the cut off line is a little too low???
Old May 3, 2005 | 07:04 PM
jsmithsole's Avatar
*moderator*
It does seem a bit low in this pic, how far away from the wall were you exactly?
Old May 3, 2005 | 07:32 PM
HzMajesty's Avatar
u can fit 2 maximas between me and the yellow parking pavment.
Old May 3, 2005 | 08:31 PM
blackpaladin67's Avatar
Got dual HID in mine
I put HID's in both lower and High beam and it works a treat.
I can even have both on at the same time driving around the city and only about 1 in 100 cars will flash me.
Our lights don't have shutters like most of the US models.
Old May 3, 2005 | 08:40 PM
pae1215's Avatar
you are actually aligned well. look at the side mirrors of the ford. the cut off is at the mirrors, thats where it will shine that HID blue/purple.
How much did the dealer charge you for aiming the lights?
Old May 3, 2005 | 08:43 PM
Id liek to see a pic of a wall shot with halogens, never seen that.
Old May 3, 2005 | 08:46 PM
eLMo's Avatar
No, thats good, it looks like the right light is up to the trunk lid of that car to the left.
HzMajesty's Avatar
Dealer did it for free...
I dont have a wall shot of the halogens though... never thought of taking one...
Old May 3, 2005 | 08:49 PM
pae1215's Avatar
HzMajesty, I left you a question on hidplanet (bring12345)
Old May 3, 2005 | 08:51 PM
NismoMax80's Avatar
SuPeRmOd
the dealer only followed the aiming specs in the sticky.
I swear when I got different tires my lights are up higher. but no one has flashed me since. so it of cource may be my imagination (unless i'm pissin them off worse or they are familiar with HIDs now)
Old May 3, 2005 | 08:58 PM
pae1215's Avatar
deflate some air, your lights will then sit lower
Old May 3, 2005 | 09:02 PM
NismoMax80's Avatar
SuPeRmOd
i know, but they are each at 32psi and already look low. the Max psi on these dunlops are 55 IIRC (RSA 44), but goodyear said to run whatever Nissan recommends (32psi cold).
I'm about to take a wheel off and compare it's height with my "full size spare" (aka gouged oem rim with RSA).
Old May 3, 2005 | 09:08 PM
HzMajesty's Avatar
i think its ur mind playing tricks...
i still feel the halogens were a bit higher!
btw.. how come u guys dont put feedback on my cardomain website? only 6 ppl
Old May 3, 2005 | 09:21 PM
pae1215's Avatar
LOL dude, no one signs mine either...well hardly any max owners, I get more people with other makes and models dropping lines. They sweat the 6th gen, thats why.
hook me up with this Hz
Old May 3, 2005 | 09:28 PM
HzMajesty's Avatar
hahahah i was wondering why i had over 1K hits but only 6 in the guest book!
when i receive the assembly, test it, fix my headlight, and make sure everything is working fine... ill be in contact with ya!
Old May 3, 2005 | 11:59 PM
tototee999's Avatar
pal,
please fill me in on what that is..
thanks...
Old May 4, 2005 | 06:27 AM
pae1215's Avatar
that is the ballast. a HID bulb needs that ballast to work.
in order to have HID:
you need a HID projector, a Ballast and a D2S bulb
Old May 4, 2005 | 06:46 AM
tubs's Avatar
that's what i have!
Mar 12, 2020 12:06 AM
Cotozic
Jun 28, 2017 08:01 PM
magiconthetire
Oct 26, 2015 09:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
