K&N Experience??
Old Apr 27, 2005 | 11:52 AM
Skylersmax's Avatar
K&N Experience??
I know this is but just wanted to know others experience with this filter. I put mine in yesterday and started it up and the ses cam on. After trying to reset with no success, went to the dealership and the service writer pratically gave me the riot act. She said that if the air sensor went that they would not cover it and it cost 500.00 to replace. Now she is got me worried to leave it in. Anyway she reset the light. Should In leave it in there and see if it comes back on? On the other hand I may have caused to light to come on. I forgot to plug that thing back into the side of the intake before I started the car. Any suggestions folks??
Old Apr 27, 2005 | 11:54 AM
Okiewan's Avatar
Problem with oiled filters can be too much oil ... if it gets on the MAS, you have problems.
Old Apr 27, 2005 | 11:57 AM
Skylersmax's Avatar
Well this was straight out of the box. I guess if I leave it in I just need to make triple sure that i dont over oil and blot excess?
Old Apr 27, 2005 | 12:37 PM
erasat's Avatar
I have heard of that in the past (here of course), mine, was installed as it should, I re-connect everything's back and after 2000 miles of that, no single issue. Matter of luck?, maybe...
Old Apr 27, 2005 | 12:54 PM
Okiewan's Avatar
I'm sure it's possible to come out of the box over-oiled... who knows?
I've used them for a while in other cars, have always been afraid to clean and oil it.. I hate to admit it, but I just buy a new one.
Old Apr 27, 2005 | 01:33 PM
Skylersmax's Avatar
The dealer reset the light and I guess I will see if it come back on. I think that I may have cause it by forgetting to plug thos wires back on. Anyone know exactly where the MAF sensor is?
Old Apr 27, 2005 | 01:38 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
MAF is inside the black elbow before the intake manifold.... you can't miss it there is a harness attached to it.
Old Apr 27, 2005 | 01:50 PM
JiuJitsuThug's Avatar
I usually do exactly what Okiwan does and just buy a new one. I'm afraid I will go "oil" crazy and have the MAF getting hit with the excess. I still keep my old ones and plan on cleaning them and just letting them dry for along time before attempting to swap...
Old Apr 27, 2005 | 02:10 PM
KCMAXX's Avatar
KC's FINEST
Theres no reason to unplug anything to put in a filter. Make sure you got the cover on right... Try reinstalling it, the light shouldnt come on. All I do is slip mine out the drivers side when I clean it. Ive never "unpluged" anything
Old Apr 27, 2005 | 02:24 PM
04BlackMaxx's Avatar
Listen man, same exact thing happened to me a few months ago...I of course flipped out and put everything back the way it was before with the old filter...and called the dealer. Wellon the 3rd day with the SES on, I start up the car and the light is nolonger on! Im like Phew....call the dealer, call off the appt. and havent seen the light since! Ill never drop a K&N in the car again bc it seriously F'd up the idle and caused the light to come on, and get this...messed up the seat egress and wheel raising when the key is removed from the car! WTF? Never again...lol
I blotted that damn filter really well...it was spotless and not oily.
Old Apr 27, 2005 | 07:25 PM
sparq's Avatar
I never had any problems with the K&N filters...on any of my cars...even cleaning and re-oiling isn't a big deal.
Also...never had to disconnect anything on the Max to replace an airfilter...maybe thats why things went wrong?
Sparq
Old Apr 27, 2005 | 07:34 PM
KCMAXX's Avatar
KC's FINEST
How exactly did installing an air filter turn off the memory wheel/seat? I dont understand how people have trouble... its an air filter. Theres no need to even remove the top of the filter box...
Old Apr 27, 2005 | 07:44 PM
Skylersmax's Avatar
I was having trouble getting the top to move because of the elbow so I loosened the clamp and disconnected the wires, did want to pull on them. I forgot to reconnect them before I started the car and it did not like it at all. Reconnected and car ran fine. I love the power, or maybe its just in my head but the throttle response seems to be faster. Has anyone had a K&N in their car for a few their a few thousand miles??? Has anyone had a MAS failure?
Old Apr 27, 2005 | 07:47 PM
Skylersmax's Avatar
I don't understand the seat egress thing. Did you disconnect the battery? I don't see the connection between the filter and the seat?? HUMM!!!
lol i know, i didnt expect it either...ill tell ya exactly what i did:
#1 I opened up the airbox and switched filters
#2 I got in the car and started her up
#3 I shut the car down because IMMEDIATELY following ignition the following occured:
SES light came on
Car idled 500-750RPM's too high in park
When shifted into Reverse 'thud' heard (because the motor was idleing too fast, this really broght it to my attention)
#4 I got out of the car (seat did not go back, wheel did not go up up), took out the K&N, put in the paper one.
#5 Started car, after a few moments, idle is ok, but then the automatic wheel/seat thing stops working
Bad luck?
Old Apr 27, 2005 | 07:49 PM
Skylersmax's Avatar
Sparq
I hope that you are right and the light just does not come back on and the inital light was just my screw up.
Old Apr 27, 2005 | 07:51 PM
Skylersmax's Avatar
SES light came on
Bad luck?
#5 When I got in the car,
Was your seat a temporary thing or did you have to take it in for repair?
Old Apr 27, 2005 | 07:53 PM
No, the seat thing was temporary...it just started to work again...and the light went off by itself also..strange...
Old Apr 28, 2005 | 09:03 AM
KCMAXX's Avatar
KC's FINEST
What ive noticed about these seats is if your getting in and you put pressure against it it stops moving. Like I get in start the car and try to grab my smokes out of my pocket... the seat stops. Same thing if you put it gear to fast, the wheels and seat will stop.
Old Apr 28, 2005 | 10:17 AM
NismoMax80's Avatar
SuPeRmOd
weird, my wheel continues to drop even if i start driving. i turned the seat off b/c i already have it all the way back.
w/ all the electronics, I suppose the seat and wheel not working is to help you notice something is wrong in case you ignore the light.
I still have my K&N waiting for 30k to come. I know i over-oiled my last one b/c the one sensor went bad in the buick.
Skyler: So all this started b/c you unplugged things you shouldn't have and forgot to reconnect them?
Old Apr 28, 2005 | 02:41 PM
Skylersmax's Avatar
yeah and the dealer puting the fear of God in me about how this would be a big mistake putting a K&N in my car. Just wanted to know others that have had them in for awhile experiences. If they were bad out it was coming!
Old Apr 28, 2005 | 05:22 PM
Well nismo, i dont know if this all happened to him becasue he unplugged things (im sure it didnt help though) but all I did was drop the filter in...and I got the same result he did. Furthermore, if oil got on the MAF sensor...do you thingk it would correct itself as quickly as it did? My advice in this situation is to put everything back the way it was before, and call the dealer and claim ignorance...they cant prove you caused it.
Old Apr 28, 2005 | 08:40 PM
Skylersmax's Avatar
The service chich was pretty cool about it. She reset it for me and told me it would be in my best interest to take i out. I am going to leave it in and just keep the factory one and if the MAF goes swaporoo and off to the dealer. I might get busted, I don't know.
Old Apr 30, 2005 | 03:14 AM
blackpaladin67's Avatar
Mine worked fine , just super , didn't have any of the problems as previouly described.
I was a bit worried as I had read a few threads before it arrived from over US but it droped in fired up and have not looked back since.
Old May 4, 2005 | 06:47 AM
luvmyride's Avatar
i love k&n
Old May 4, 2005 | 06:58 AM
05MAXSE's Avatar
No problems with K&N filters in 25+ years.
Old May 4, 2005 | 07:03 AM
tubs's Avatar
k&n was good for my A4 1.8T
240tomax
Tires and Wheels
Feb 10, 2016 11:01 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Pied
Sep 26, 2015 03:29 PM
TxBroncosFan
Sep 21, 2015 06:54 PM
lrb6805
Sep 18, 2015 07:07 PM
