has anyone recharged their a/c?
Old May 5, 2005 | 07:08 AM
maxmale's Avatar
i need to have mine done but id like to do it myself if possible i am mechanicly inclined, just have never done it before by myself. anyone have any info to help me with this process. please.
Old May 5, 2005 | 07:54 AM
Bobo's Avatar
Why would you possibly need to recharge the air conditioning in an 04 Maxima? I didn't have to do it on my 95SE until July 2003, almost 9 years after I bought the car.
Buy a Haynes manual, there is a write-up there on adding refrigerant. For models up to 2001, you have to buy an R-134a charging kit, which includes a 12-ounce can of refrigerant. I don't know what the charging kit is for a 2004 Maxima, possibly the same.
Good luck!
Old May 5, 2005 | 08:57 AM
ramberg's Avatar
GrandPa
If you need to recharge your '04 Max now, you might be having a bigger problem with the AC system. Go to the dealer to check it out. It should be covered under the warranty. Later Warren
Old May 5, 2005 | 09:31 AM
rays01se's Avatar
Ramberg beat me to it. Whether it needs recharging or something else, it should be covered under warranty so you won't have to do it yourself. Air Conditioning components and refrigerant is expensive. Let your dealership foot that bill.
Old May 5, 2005 | 03:23 PM
carcus's Avatar
I do it on my wifes car every 2 months, not a Maxima but easy to do on the low pressure side with the blue cap. Takes a minute. But first, the only reason I do this for my wife is her car, yes, it is R134, cost 5 bucks for a can with the recharge kit extra....Walmart has a cheap kit, but the only reason I do it to her car is it is pretty old, no one can find a leak in the system even with dye in it....so gave up spending 70 bucks a few times to find the leak no one could detect.
Now, on your Maxima, should not be having any HVAC problems or loss of freon. DO NOT ADD ANY YOURSELF!!! If you over charge the system....the dealer can screw you BIG TIME, than the entire HVAC system is on you. Take it to the dealer, have them check the system and you are covered. My advice....STAY AWAY FROM THE SYSTEM....take it to the dealer. If it is not blowing cold, something is not right....compressor, condenser....something, or just a leak....could even be the control unit. You are covered 100% unless you are over your warranty miles. Just my 2 cents. Hope this helps. Recharging the AC is so very easy, but do not touch it....have them deal with and diagnose the problem.
That and believe it or not, if you do not know where to add it......it is a high pressure system, you can be in for a surprise.
Old May 5, 2005 | 05:37 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
must be hot as hell down in BEAUFORT, SC huh?
Old May 5, 2005 | 08:20 PM
NismoMax80's Avatar
SuPeRmOd
funny, i just received a double coupon from my so concerned dealer: 1 for A/C recharge and another or wheel alighnment.
Old May 8, 2005 | 12:47 AM
Andrew Bubeck's Avatar
AC Problems
After winter when the weather started warming up I turned on my AC...never got cold. Just blew mildly cool air. Took it to the dealer, they found a leak somewhere. Ordered the part, installed in and recharged my system. Works perfect now. Was fully covered under warranty.
Andrew
BkGreen97
Apr 2, 2016 05:47 AM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
maxima297
Sep 24, 2015 01:18 PM
EdRomo86
Sep 12, 2015 07:49 PM
