harsh downshift to first in manumatic
Old Jun 2, 2005 | 08:03 PM
Roshan
just today.. while i was driving.. using it in manual mode... the transmission harshly falls into first gear... i use manual all the time.. and this is the first time it happend.. even while goin at about 35.. and dropping it from 2nd to first... there is a harsh downshift with a loud thud.. and my 36k is almost up.. is this normal? wut should i do
Old Jun 3, 2005 | 01:21 AM
ramberg's Avatar
GrandPa
I am not a pro at this but I think that you should not be dropping from 2nd to 1st at 35 mph. Just my thought.
Old Jun 3, 2005 | 02:10 AM
SmokeMax310's Avatar
i would agree..i have a se with the sport shift also...look at your RPMs when ur in second doing 35mph...anything i believe anything above 3k rpms will do that to ya...try down shifting at a lower rpm to avoid that..i also dont think doing that is good for ur engine and tranny..i've done the same thing u've done before...just left off the gas and let the rpms drop..try it out...u can downshift pretty easy when ur in 5th for example..just keep an eye on ur rpms always
Old Jun 3, 2005 | 04:13 AM
Roshan
even when the rpms are low too.. it still does it... even if its in auto.. at times i feel the down shift to first... in automatic too.... any ideas wut it can be.. i have tried downshifting at different speeds.. from high to low.. and every time i get the harsh downshift... i tried at 10 mph.. and still....
Old Jun 3, 2005 | 05:13 AM
ramberg's Avatar
GrandPa
Check your fluid or go directly to dealer.
Old Jun 3, 2005 | 05:22 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
, you should never downshift to first..... I usually downshift to 4th or 3rd never below that.. I let the computer downshift by itself if it has to at that speed..
but, never downshift to first while rolling at that speed like that...
Old Jun 5, 2005 | 06:26 PM
Monotaur's Avatar
When was your SE built? Is it a 2004? I'm asking because there is a TSB out for harsh-shifting on early 2004's (I had it applied to mine, and it's like 98% better).
EDIT: If it only does this for shifts into 1st, then this probably isn't the problem... I'd recommend not doing that either (I've also down shifted into 1st at low speeds and even going like 5MPh, there is a small lurch - I'd just let the computer hanle it).
Old Jun 5, 2005 | 07:33 PM
Roshan
its not a small lurch.. its like hitting a pothole going 45mph and the rim hitting the side of the pothole.. its that kinda feeling.. even while goin slow... never happend before.. ..SE built 07/03
Old Jun 13, 2005 | 01:00 AM
bnote's Avatar
The reason you heard a thud is because you dont downshift to first gear ever. Let the computer do it. If you driving a 6spd of your car and you downshifted into first at too fast of a speed you will clunk into first jumping all over the road like you had hydros in you ride.
Old Jun 13, 2005 | 02:31 AM
2004 Smoke's Avatar
2004 Smoke
I thought my tranny computer would let me downshift or upshift into a gear at a speed it didn't think was safe.. (i.e. it is idiot-proof).
Old Jun 13, 2005 | 01:14 PM
Roshan
i agree with wut 2004 smoke sed... i thought its an idiotproof computer
Old Jun 13, 2005 | 02:11 PM
2004 Smoke's Avatar
2004 Smoke
Whoops - that should have said "wouldn't" let me downshift or upshift into an unsafe gear.
Old Jun 13, 2005 | 03:18 PM
carcus's Avatar
I agree 100%....also, be advised that Nissan is new to this Manumatic shift thing. BMW had problems when they first started. Downshifting to 1st should be avoided. People will do what they want though. Remember the old saying.....If you want to play, you have to pay....the old timers know from experience what I am talking about.
alahjahwan09
18
Sep 21, 2015 09:12 PM
Stock
Jun 14, 2010 09:51 PM
max2b?
Jan 15, 2001 05:59 AM
hard8
Dec 29, 2000 11:20 PM
kingocat
Dec 28, 2000 06:33 PM
