Airbag Safety System help?
Old Jun 22, 2005 | 06:41 PM
SoufSidah09's Avatar
I have an 04 SL, the driver seat was the only thing that depoyed, I'm wondering do I just need to replace the seat and just the seat module? The dealer told me I would need to replace the entire airbag modules for the whole car which would cost an arm and a leg and a kidney...
Anyone know about the Nissan airbag system? I'm wondering if I just need the driver seat module and a reset of the airbag system..
Thanks in advance...
Old Jun 22, 2005 | 06:43 PM
NismoMax80's Avatar
SuPeRmOd
i saw one on eBay. go to courtesynissan.com (in texas) or jerryromenissan.com and check prices or email them to see what needs done. 3rd option is wreck yards.
Old Jun 22, 2005 | 06:53 PM
yeah, but I'm wondering if that's all I need is the seat and the seat module, one dealer told me I needed to replace ALL modules in the car! I thought that was crazy..that's why I'm asking if anyone here actually KNOWS...
Old Jun 22, 2005 | 07:03 PM
RHMax's Avatar
Newbie just Registered
I'd go to a couple of dealers and an independent shop to see.
Old Jun 22, 2005 | 07:12 PM
NismoMax80's Avatar
SuPeRmOd
that's why i said email those dealers. since they're online resources, they can't scam you into pulling your car in for uneeded or undesireable DIY work.
The few people that have wrecked their new Max have insurance and don't worry about this. if emails/phone calls get you nowhere, hopefully RHMax cam find out.
Old Jun 22, 2005 | 07:39 PM
pae1215's Avatar
drivers seat part numbers: hope this helps u a little
Old Jun 22, 2005 | 08:00 PM
Jayzmax04's Avatar
Where does it deploy out of the seat?
Your steering wheel bag didnt go off? Was it a side wreck?
Old Jun 22, 2005 | 08:11 PM
Thanks, I'll call a few "stealers" tomorrow and see if I can get someone knoledgeable...I found a guy selling the complete seat for $400 all I needed was the module which list in the above price sheet for $181.00, so if I findout that's all I really need to reset the system I'll move in that direction and let you guys know..
Old Jun 22, 2005 | 08:40 PM
pae1215's Avatar
Curtain/Side Air Bag System
Since they're built into the front seats - not the door panels - Maxima's side-impact supplemental air bags move with you when you adjust the seat to help protect your head and chest areas in certain side impacts. And above you, roof-mounted curtain side-impact supplemental air bags help protect front and rear passengers from injuries.
Old Jun 22, 2005 | 08:52 PM
it was actually a front wreck and if you seen it you would think ALL airbags would deploy but only the driver's seat did...
It basically ripped the stiches off the side of the seat and now it just needs to be restiched..
Old Jun 22, 2005 | 09:03 PM
pae1215's Avatar
I'm sorry for not saying this sooner. Hopefully everyone involved in the accident walked away ok? also how did it happen, who's fault?
good luck though, hopefully everything comes out ok
Old Jun 22, 2005 | 09:11 PM
lightonthehill's Avatar
When looking here the next day, I realize I have confused two systems in this post, so I have deleted what I posted and replaced it with a more accurate one at 11 PM Thursday, June 23.
Old Jun 23, 2005 | 01:38 PM
luigi'smax's Avatar
SoufSidah09 - A part of the restraint system that does not use an airbag is the active head restraints. The headrest actually snaps quickly up to contact the back of the head when sensors tell it to.
This is intended for rear end collisions, but may have deployed without your knowledge. If so, the entire associated assembly (on the floorboard under the driver's seat), along with the seat belts themselves, must be replaced.
well, i was wondering about this...how does this work ?? the headrest are easily remve and i dont see any wires coming or going into the headrests...so they have their own lil brain/sensors and battery integrated into them ?? that is mad cool is if it is like that...but then...what about when one decides to install headrest monitors ?? does any one know how this system actually works ?? would be nice to know...
Old Jun 23, 2005 | 02:35 PM
RHMax's Avatar
I went for oil change today (my own mechanic, not dealer), and this is what I got on airbags. The airbag module, not the crash, determinds which bag(s) to deploy. This could effect seatbelt modules too. So try here: http://www.489parts.com . Dealers will only sell you complete set.
Old Jun 23, 2005 | 08:03 PM
Soufsidah09 and luigi'smax,
In my previous post (since deleted), I confused two safety systems.
The Active Head Restrain System is actually a PASSIVE system. If an impact from the rear forces a person in either of the front seats backward into the seat, that force is directed against the bottom front of the two steel rods holding up the headrest.
That force backward against the bottom front of the rods causes the top of the rods to swing forward until the attached headrest contacts the back of the person's head. This reduces the distance the head travels backward, reducing the chance of whiplash, as well as reducing the chance of a cracked upper vertebra.
This is a PASSIVE system, in that there are no sensors and no electronics. After the headrests have activated in this manner, they automatically return to their original position, and require no restoring, repair, or any other action.
The system I should have been mentioning in my original post was the Seat Belt Pre-tensioner System. There is a duplicate system; one for each front seat. This system activates when a front seat belt is impacted rather forcefully by a person's body in a (usually frontal) collision.
Not all collisions activate this system, and one should have Nissan check for deployment after any firm collision. Deployment of the front air bags is by separate sensor, and not tied directly with the Seat Belt Pre-tensioner system. In any particular collision, one may come into play without the other.
The Seat Belt Pre-tensioner System is designed to instantly detect a serious impact, immediately bring the belts firm against the person in the seat, somewhat control the force the belt exerts against the body, as well as control the rate at which it is applied and allowed to ease when the pressure becomes very great.
In the event the Seat Belt Pre-tensioning System comes into play in a collision, the belt, buckle and retractor drum (on the floor under each the front seat) MUST all be replaced.
Sorry I confused these two systems. It has been over a year since I devoured the Owner's Manual, and it may be time to read it again.
Old Jun 23, 2005 | 10:37 PM
eLMo's Avatar
How does the sensor know if you get in a side wreck? Does it wait till the car gets smashed into the chair? If so what if you punch the sensor on the chair really hard, like you sitting in the back. Would that make it deploy? Like for example my friend tells me drive me home I say no and he punchs the chair real hard would it deploy? I know I sound stupid but from reading some posts thats what it seems like.
Old Jun 24, 2005 | 06:40 AM
Originally Posted by RHMax
Sorry for assuming!
Check the seatbelt modules too. With both side bags deployed, seatbelt modules are most likely blown.
Edit: If belts were worn during collision.
Just the drivers side was deployed, which includes the seat and the side curtain, the steering wheel did not. Is there a tell tale way to see if the seat was deployed? it appears to move freely like a normal seat belt..would it be locked after a collision?
Old Jun 24, 2005 | 11:10 AM
RHMax's Avatar
Once the cartridge in the seatbelt module is blown, the belt won't retract. Maybe they weren't wearing seatbelts. Or maybe it was side colission, since only the left seat and head bags deployed??????
Old Jun 24, 2005 | 04:26 PM
Great! that means the seatbelts are fine! They must not have been wearing them...
Both driver and passenger belts retract fine and lock on fast pull of the belt
Looks like all I need is the side curtain, drivers seat, and sensors!
Old Jun 24, 2005 | 10:20 PM
eLMo - No sensors are in the seats. The sensors are down near floor level, and are at several places around the car.
The main diagnosis sensor unit is underneath the console between the front seats. There are satellite sensors on the floor under the front seats near each front door. There is a crash zone sensor at the front end of the car.
Hitting or kicking the seats should not deploy any active restraint systems. But only a petulant child should ever be caught doing this to a Maxima.
SoufSidah09 - The Owner's Manual does not say if it is possible to tell visually whether the seat Belt Pretensioner System has been deployed by visual inspection.
But it may be possible to do so, as the manual states: 'If the vehicle becomes involved in a frontal collision but the pretensioner is not activated, (you should still) be sure to have the Pretensioner System checked out.' From that, it would seem that it is possible to know if the system deployed. If your belts are behaving normally, have a dealer you trust (oxymoron?) to tell you how to determine if this system has deployed. You may be OK here.
Old Jun 25, 2005 | 10:42 AM
I'm going to check this actually locations and snaps some pics I'll post them up also..
lol at stealer comment, but I've got the name of a local airbag guy that I'm going to see If I can get some valuable info from him... I may have a full airbag service manual created at the end of this thing
MichMaxFan
Sep 30, 2015 09:18 AM
uttadms31
Sep 30, 2015 05:24 AM
Socalstillen
Sep 26, 2015 12:01 PM
