Basic Mods to see 300hp from the Max
Old Jul 30, 2005 | 11:22 AM
  #281
ramberg's Avatar
GrandPa
I wasn't going to come back on this tread until I redynoed the car. Where I had my last dyno the mustang dyno is out so I will have to wait till I get down to Florida. I will start to drive down on the 9th. one more thing when I step on my gas pedal with my mods the car is moving and I know there is more power than when there were no mods. The ecu adjusts to the mods, The proble with the ECU is that it limits how fast you can go. I think it stops at 143 mph. Right now as far as I know no one is working on this problem. I don't know to much about the Z but the money I have spend on my car is working to give my car more power. As per my last dyno even though some members are having problems with it and how it feels when I drive it, there is more power. Warren
Old Jul 30, 2005 | 02:10 PM
  #282
NmexMAX's Avatar
dot dot dot ...
Originally Posted by 04BlackMaxx
....bc if the Z can't be tuned up with bolt-ons, the max can't either.
It can be tuned more from stock form since it came from the factory de-tuned comapred to the Z.
Most with headers and some tweaking of other things are seeing dynos comparable to 350z's .. stock and lightly modified.
Old Aug 7, 2005 | 02:44 PM
  #283
joebangaa's Avatar
As far as ramberg's gains...he will be dynoing on a dynojet so we can compare apples to apples...Other than that, if anything, you'd expect the Z to respond better to mods than a max, and a respected auto tuner mag calling it a tough car to improve really makes me wonder if gains are in everyone's heads....bc if the Z can't be tuned up with bolt-ons, the max can't either.
you realize there is no logic to your statement
Old Sep 21, 2005 | 08:20 PM
  #284
george_rem's Avatar
300 hp?! I just had my stock 05 SE (AT) dyno'ed, and got horrible numbers: 212 hp, torque 224. It was run in 3rd gear, and the top speed reached before the
speed limiter kicked in was about 98 mph. Pathetic.
Old Sep 21, 2005 | 08:29 PM
  #285
blackpaladin67's Avatar
You have VDC ??? if so thats your problem ...mind your 212 = 262 at the motor...
Old Sep 21, 2005 | 08:30 PM
  #286
george_rem's Avatar
Sorry, what is "VDC" ?
Old Sep 21, 2005 | 08:51 PM
  #287
george_rem's Avatar
OK, VDC, I see, means vehicle dynamic control. The guy running the
test disabled traction control, so that's not the reason.
Old Sep 21, 2005 | 08:58 PM
  #288
The numbers are ok for a stock car and an auto at that ..
Also what fuel were you running , you can pick up a few Hp with the highest grade of fuel your 94 i think it is....
Further I do not think your speed limiters come in at such a low speed , please correct me if i am wrong..
However just pressing the off button on VDC will not shut it fully off , you have to go to a dyno shop who does a lot of 350z and they have to bypass magically somehow.. I had this issue with dynos and VDC.
Old Sep 21, 2005 | 09:04 PM
  #289
george_rem's Avatar
Thanks for letting me know that there isnt anything
wrong with my car.
I always use premium; today it was 92 grade, not 94.
Anyway, the dyno guy is a GM (Corvette) tuner, and he suggested
that I have the computer reprogrammed--he gave me a list of
makers: Superchips, Fastchips, Hypertech, TTS, Diablo, but it
seems that none of them work on the 04-05 Maxima.
Old Sep 22, 2005 | 05:35 AM
  #290
SR20DEN's Avatar
VQ Wizard
Was this done on a Dynojet 248c? And if so you should be happy with those numbers from a stock vehicle.
Old Sep 22, 2005 | 05:55 AM
  #291
george_rem's Avatar
I believe so. According to their website, it is a "DynoJet in-ground, 248 chassis dynamometer".
Thanks.
Old Sep 22, 2005 | 07:11 AM
  #292
george_rem's Avatar
Here are the dyno curves:
http://tinypic.com/dx1hmf.jpg
What is weird is that the rev/speed limiter kicked in
so early = under 100 mph!
Old Sep 22, 2005 | 07:14 AM
  #293
george_rem's Avatar
Well I saw the car kinda "buckle" suddenly, and the technician told me
that it was the speed limiter. Weird!
Old Sep 22, 2005 | 07:30 AM
  #294
NmexMAX's Avatar
dot dot dot ...
Do you have the run files? Who said it was the speed limiter? VDC.
Old Sep 22, 2005 | 07:35 AM
  #295
george_rem's Avatar
Here are the curves:
The guy who run the test told me it was the limiter. I actually
saw the car buckling, so something did really happen.
But he only tunes Corvettes and other GM vehicles, and perhaps didnt know
what he was doing.
Old Sep 22, 2005 | 07:40 AM
  #296
NmexMAX's Avatar
dot dot dot ...
When VDC kicks in, it is like tapping the rev limiter. I know 6th gens can do more than 98 mph.
Check out the dyno forums, VDC and it's effects on dynoing is duscussed in some threads.
I saw the curves, but do you have the actual run files?
Ask some 350z guys how thy do it ..
Old Sep 22, 2005 | 07:52 AM
  #297
george_rem's Avatar
I can ask for the run files to be emailed to me.
Thanks!
Old Sep 22, 2005 | 05:10 PM
  #298
maxmale's Avatar
just out of curiousity, can you even take the 5at to redline, im thinking you hit the revlimiter not the speed limiter. and for third gear run those are the same numbers i got with out my safc II in third gear, but i have a six speed. do one in fourth is my opinion.
Old Sep 22, 2005 | 05:12 PM
  #299
maxmale's Avatar
and back on topic.
We should change the name of the thread to 400whp attainable N/A.
im thinking we can get close with the stroker kit. 300 should be no problem
Old Sep 22, 2005 | 06:38 PM
  #300
george_rem's Avatar
No. Here's what the dyno guy told me in an email today,
replying to my questions:
>>in what gear(s) where the three runs conducted?<<
3rd gear, as that is a 1:1 ratio within the transmission.
>>Did you use the shiftable feature of the AT to shift it by hand?<<
Yes, it was manually shifted into 3rd before the run was made. The PCM
of the car would NOT let the car stay in 3rd for very long, (as a safety
feature due to excessive wheel speed in that gear probably) even when put
there manually, because it shifted into 4th anyway during the end of the
run regardless if "3rd" was manually selected of not.
>>Also, my car has traction control, maybe it was on during the test?<<
No....... NO car can be pulled on the chassis dyno when the TCS system
is engaged~ the vehicle wouldn't let it even if we tried to pull the car
with it deliberately engaged.
>>I'm asking because I still don't understand why the speed limiter kicked
in.<<
As I said, there are many factors that can cause this, one of which is
the PCM electronically trying to protect the car, especially since the PCM
sees the front wheels spinning at 100+ MPH, but sees no wheel speed coming
from the rear tires at all.... As I also stated before, running a car on
the track and running a car on the dyno is two completely different,
isolated, situations that are *WORLDS* apart from each other, therefore
comparing the two is really pointless for accuracy.
Best Wishes and God Bless,
Phil Rickard- President
Dynotech Engineering, Inc.
www.dynotech-eng.com
(260)407-5455 ext. 11
Old Sep 23, 2005 | 10:03 AM
  #301
NmexMAX's Avatar
dot dot dot ...
Besides all the mumbo jumbo, there is a way around it. Ask the 350z guys.
Old Nov 29, 2006 | 07:17 PM
  #302
garose26's Avatar
Cattman Exhaust Install
Just installed the Cattman Exhaust (with resonator) on my 04' SE with 5 speed auto. I love the look and overall sound. My problem is that it has very bad resonance from 1800 to 2800 rpm under any throttle. Have others with the Cattman had similar problems. The exhaust mellows aout and is sweet above 3000 rpm. It is just annoying that it is always so loud at the normal cruise rpms. Any advice would be appreciated.
Old Nov 29, 2006 | 07:29 PM
  #303
MisterSparkle's Avatar
you could always just cut out the stock resonator...and replace it with something longer and larger. WARNING...don't make it too big cause then it would pointless cause then you won't hear anything. lolxz
Old Nov 30, 2006 | 11:53 AM
  #304
xoomer.com's Avatar
I Donate! Why Don't You?
Any sound clips? I've been looking for sound clips to compare and finally order the exhaust. Please help
Excalibur23
Oct 13, 2015 04:33 PM
ballerchris510
Sep 23, 2015 08:46 PM
Pixel
Sep 15, 2015 05:53 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
