New RSB
Old Jul 27, 2005 | 02:59 PM
smokey04max's Avatar
New RSB
I just recieved my new rear sway bar from Progress today, easiest install of my life.... although I used the dealership lifts and tools... hehe.
Anyway, after the install my shop Foreman Jesse asked me if I was going to take it out on the dealerships favorite curvy road (BigTree) to test it.... and hell yes I did.
As soon as I got near big tree this riced out "fast and furious" ghey-a$$ neon green eclpise GS starts mean-mugging me and pulling up and backing off, trying to taunt me. I knew he was all flash and NO dash so after handing him his a$$ he still followed me onto BigTree.......... Finally, I really get to test out this baby.
Anyway, we got up to about 75 around these turns and toward the end he started backing off because he kept breaking free around the bends as my maxima held tight to the road.
The best part was when I came to the stop sign at the end of the road, and I waited for him with my hazards on. He pulls up behind me and I can see him screaming and cursing in my rear view. I open my sunroof, showed him my phone number and sped away laughing.....
GOD I LOVE MY MAX!!!
Old Jul 27, 2005 | 03:24 PM
pae1215's Avatar
so I take it that you like the RSB? LOL
Old Jul 27, 2005 | 04:05 PM
akaxmrxhammer's Avatar
how much did that cost you? i wonder if the progress rsb's heavier than the stillen rsb
Old Jul 27, 2005 | 04:06 PM
it was around 140 shipped, I got the ORG hook-up..... and it was sssooo worth it
Old Jul 27, 2005 | 04:16 PM
i guess i'm missing out on a lot of things. 3 more months and i'll be home.
Old Jul 27, 2005 | 04:49 PM
pkane3's Avatar
I knew he was all flash and NO dash...
PRICELESS!!!
Old Jul 27, 2005 | 06:23 PM
I dunno about the progress vs the stillen, but as compared to my OEM it was WAY heavier, and a lil thicker, it has made a world of difference.
Old Jul 27, 2005 | 06:29 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
nice, can't wait to try it out myself..... mines should be in the mail as we speek since we did the same deal...
Old Jul 27, 2005 | 07:19 PM
Mystery's Avatar
My stillen RSB has been sitting in my trunk for 4 months. Never had time to put it on. Exactly how easy of an instal is it? I'd rather not pay someone to do it if i can do it myself. Hopefully i'm just as happy with it as everyone else is.
Old Jul 27, 2005 | 07:45 PM
pae1215's Avatar
you have to jack it up and remove both wheels I believe, then its a simple plug and play
Old Jul 27, 2005 | 08:02 PM
Doing it on the ground has to suck big time, we put mine on a lift and it took about 10 minutes. If you can find a lift you DO NOT have to remove the wheels at all, but it might take up to an hour w/o a lift......
pae1215's Avatar
cool, thats good info to know. thanks
Old Jul 27, 2005 | 08:18 PM
NismoMax80's Avatar
SuPeRmOd
my friend and i jacked it up at the center point, used stands on both sides. Removed both wheels, removed brackets, snake out, snake in and brackets then wheels back on.
15-20 minutes.
btw, i added a bit more detail in the sticky to help w/ comparisons.
Old Jul 27, 2005 | 08:19 PM
Mystery's Avatar
15-20 minutes.
Thanks i'll have to check that out.
Old Jul 27, 2005 | 08:42 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
15-20 minutes.
I did the exact same thing, however since you can only remove the bar from one side or the other, I only removed the passenger side rear wheel and got the sway bar out with no problem. The stillen, is an exact bolt line-up, since it did not come with instuctions, if the holes don't line up exact, it's on backwards... Damn mystery, 4 months, heck 1 day is too long for me once I get a new mod shipped in...
Anyway, good luck...
Old Jul 27, 2005 | 10:50 PM
RHMax's Avatar
Newbie just Registered
Difference between Stillen(still only for 04's!??) and Progress/Cattman is Stillen(22 mm) is hollow with thicker wall than stock and Progress/Cattman is a solid bar and thicker(24 mm) (info per their websites). As far as installation I put my car on a lift and only took off 1 wheel, about 20 minutes.
Old Jul 28, 2005 | 06:38 AM
Longhorn1's Avatar
Smokey,
Does your car have lowering springs as well? Just wondering if you noticed all that difference from just the RSB. Sounds like a pretty good deal.
Old Jul 28, 2005 | 09:23 AM
Nope... not lowered yet, and that RSB has made a WORLD of difference
Old Jul 28, 2005 | 09:31 AM
Jeff92se's Avatar
I'm needing a caw
This might help or not. On the 3-gens (irs), it's alot easier to remove/install the RSB if the suspension is compressed. So if you can back up on ramps, you get the room and the suspension is still compressed.
Old Jul 28, 2005 | 04:28 PM
Tek-Niq's Avatar
I got mines today.... WOO WOO!! install next tuesday..
Old Jul 29, 2005 | 05:18 AM
darrinps's Avatar
OK, I installed mine last night and it wasn't as easy as I had hoped, so I'm offering a little advice.
1) As Smokey04Max said, if you can use a lift DO SO!
2) Have some WD-40 handy (one of my end links was rusted tight)
3) DO NOT EVEN THINK ABOUT STARTING unlesss you have a DEEP WELL 14mm socket
4) It may help if you have someone on the other side to guide the bar when you snake it in
My time could have been cut in half if those four items had been known about before hand.
Oh, and I'd be ashamed if I were Nissan putting an anemic bar like the stock one was on this car.
Old Jul 29, 2005 | 08:01 AM
DeusExMaxima's Avatar
darrinps: How does handle now?
Old Jul 29, 2005 | 08:15 AM
darrinps's Avatar
I haven't had a chance to really test it out, but what I would describe so far is a more solid feel to the car with the front exhibiting less push.
I'm now debating my next suspension mod...don't know if a STB will do much, or if I may go the upgraded with an upgraded FSB (if it doesn't add back too much understeer).
The boss (my beautiful wife) probably won't go for aftermarket struts/springs, so those are probably my only options for now.
BTW, I meant to do this but forgot...
The next person to install this on an SE (and an SL for that matter), if you would, take the wheel/tire and place it on a scale. Those things seemed heavy to me...in the mid 40 range. Maybe a set of light weight aftermarket wheels is in order (if the boss will allow them that is!).
Old Jul 29, 2005 | 05:45 PM
Tek-Niq's Avatar
damn I can't wait, I sure need a stiffy rear..
Old Jul 29, 2005 | 06:33 PM
darrinps: I think you're right about teh weight of the stock rims. I heard stock rims weigh about 30 lbs. My rims weigh about 18 lbs and I feel the difference in off the line acceleration.
Old Jul 29, 2005 | 09:29 PM
chernmax's Avatar
We look forward to you helping the next newbie with the same question...
Old Aug 1, 2005 | 12:06 AM
RHMax's Avatar
I did the RSB first, as well. I felt that the car was stiffer in the rear w/ RSB. After the FSTB, it feels more balanced. I'm curious about the 18" non-forged Z wheels that look like SE wheels. Other than the little dimples near lug nuts and the width, are they lighter? If they're good subsitute, bosses won't noticed.
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Cumalot
Dec 16, 2000 11:55 AM
clee130
Nov 17, 2000 12:46 PM
