Squeak after y-pipe and Greddy exhaust install
Anyone else on here notice a pretty loud squeak after installing either the Y-pipe and Greddy exhaust. It progressively gets worse after driving for a while and will only squeak while moving.
I have had the car up on a lift three times now, and unfortunately I am unable to duplicate it while on the lift. I have double-checked all the bolts and this time I even put some grease into the rubber mount for the y-pipe hangar . The hangar is actually a smaller diameter than the stock one so I thought that was the source. I'll leave this one with the guru's.
Originally Posted by maxmale
yes it is a bracket on the exhaust where the exhaust splits. the bracket is rubbing another piece of metal. your going to have to sand the piece down. that is what i did to mine and it stopped.
Originally Posted by chrisaust
Squint, how much did you pay for install of the greddy and y-pipe?
Maxmale, it looks like you used the lifts, too. Were the employees kind of arogant? Almost like they assumed you new nothing because you were utilizing the lifts and tools. The only time I asked them anything was for a tool that wasn't in the tool box.
I might contact Greddy because at least three of us encountered the squeak.
did you do it yourself then, maxmale?
If you don't want an exhaust leak, buy the new gasket for the exhaust to cat connection. I paid $10 at Nissan, but you can probably get it cheaper at Autozone or Advance.
I ordered new hangers a full set for like 30 bucks from my dealer and too the car back to the exhaust guy his mechanic installed them different guy than did the foist install and it comes down to this if the system is installed right the first time no grinding needed i was under the car and ith the hangers properly installed there is no chance of rubbing. the greddys hooks have more than enough clearence. Check your hangers because the rubber in mine were no good so i replaced them all together now Greddy is even and does not squeek and I AM HAPPY!!!!
Originally Posted by Squint
$6 dollars for the lift for 1 hour. They told me I wouldn't get it all installed in 1 hour. I proved them wrong.
PS, yes you can do it all yourself in under an hour, buy a new gasket for use between the GReddy and Y-Pipe and last, get help to lower the stock exhaust when removing, pretty damn heavy for one person...
Originally Posted by chernmax
Since Maxmale is in the military, he probably took it over to the base hobby shop where they have bays, lifts, tool boxes and other specialized equipment which is pretty much all included in the hourly use fee for the do it your selfer... It's one of the best benefits I still use also as a military retiree...
For those that have experienced the squeaking, do you have the CE y-pipe AND Greddy exhaust?
MaximaDrvr
Aug 19, 2015 08:20 PM
