Possible Tranny Issue?
Old Dec 12, 2005 | 07:54 AM
titot4u's Avatar
My auto 04' has only 8,000 K miles and transmission seemed to be slipping around 25-30 miles per hour. I took my max to the dealership and they told me it has a bad tranny and they were going to replace it under warranty. A week later the dealership called me and told me that the tranny was replaced and problem still existed and that they were still investigating the issue. Has anyone here had similar problems or know what the problem may be?
Old Dec 12, 2005 | 11:06 AM
logik05se's Avatar
I had a similar issue with a different car, they changed all different things and nothing worked. Finnally they figured out it was some kind of fouled plug of somesort in the tranny.
Old Dec 12, 2005 | 11:58 AM
SmokeMaximus's Avatar
Plug in the tranny?
Old Jan 2, 2006 | 09:56 AM
titot4u's Avatar
Ok guys....Since my last post above, I still did not get my car back and dealership has replaced the transmission two times in four weeks. Anyone know of the possibilities on a lemon law or legal action that I may pursue on the subject?
Old Jan 2, 2006 | 10:59 AM
04WHITESE's Avatar
Loaner/Rental
Hopefully you have received a rental vehicle?
I would be curious to know.
04WHITESE
Old Jan 2, 2006 | 12:16 PM
NismoMax80's Avatar
SuPeRmOd
don't know much, but I would think that after the 2nd one (absolutely a 3rd one) a mechanic would look at other sources for the problem.
Old Jan 2, 2006 | 05:05 PM
REVOLUTIONZ's Avatar
Tell Them To Check The VALVE BODY AND VALVE ASSEMBLY
Old Jan 2, 2006 | 05:08 PM
I Had An 04 Max Before The Slipping Caused An Accident And Totaled My Car. I Went And Bought An 05 Maxima, And I Have Not Had Problems.
Old Jan 2, 2006 | 05:54 PM
Check Tsb Re: Abnormal Shifting Of Auto Transaxle-04 (a34) With 4spd A/t Only- Tsb No-(re4f04b/w)
Old Jan 4, 2006 | 08:42 AM
BLAKE0072's Avatar
5 speed A/T
my 2004 se 5 speed a/t is not right , anytime under heavy acceleration ,both from a stop or a down shift it jerks .like its tearing itself apart , its a very loud bang . Anyinsite or tsb are welcome , this could be my dismise to this car with only 40,000 miles on it .
Old Jan 4, 2006 | 09:55 AM
NismoMax80's Avatar
SuPeRmOd
^^^ TSBs are all linked in the Sticky. there. you're welcome
or you could just visit the dealer
Old Jan 4, 2006 | 10:08 AM
I posted the TSB no to your problem. If you let this probelm continue, you will end up with no reverse and your 2nd gear will slip.
Old Jan 6, 2006 | 11:06 AM
BLAKE0072's Avatar
thanks found shock shift tsb , stealership appointment made thanks again
Old Jan 6, 2006 | 12:38 PM
mkoscal's Avatar
I had a similar problem with a Ford Contour. Sometimes when it would "slip" it was as if something put the car in neutral. The period of the slip could very. Almost killed on the highway a couple times when it happened. It took several trips to dealer. The last time they were able to read the codes out of the computer and determine it was a cheap sensor that caused all the problems. I don't know why they were not able to read out the codes on the earlier visits. At least your dealer can duplicate the problem.
Old Jan 6, 2006 | 03:55 PM
jasonjm's Avatar
TSB didn't fix my problem.
Tranny was replaced.
Oh yeah, and the car is gone too. hehe
Old Jan 7, 2006 | 04:14 PM
dirtyo2000's Avatar
well i hope the 06 lasts a long time or a lot of miles which ever comes first
pktaske
May 6, 2016 07:49 AM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
