Off the line car " slips "
I have noticed just recently that my car will have a funny grinding sound when I accelerate. This has only happened in the past 2 weeks. I'm not accelerating quickly, it has been extremely cold in Chicago but the streets have not been icey. I do have the VDC option so could this be the reason. Hopefully it is not a transmission issue.
Originally Posted by MAXIE06SE
I am not to sure if this is due to the cold weather or the salt on the street, but when ever i floor my car or try to go fast off the line my car slips ( TCS ).
Any one else?
Any one else?
Flooring the car from a stop will ALWAYS make your tires spin (I'm assuming this is what you mean by "slip"). You need to not get on it as hard right off the line. Flooring your car off the line will slow your acceleration considerably. By the way, I don't have TCS (Thank God)
Originally Posted by dopestar129
what, you think you can't (won't) spin the tires in a RWD car? hmmmm, okay.
When its cold out and I really push the car from a stop sometimes I get a nasty slamming coming from the front end that shakes the car....I think it must be the tires getting grip and then losing it...I would refrain from flooring the car in the cold from a stop.
I slip the tires quite often off the line. I've tested the traction control with the street wet. With the TCS off the tires just sit and spin, you don't get much anywhere. I guess the throttle pull back is just a little bit and doesn't really help when the pedal is on the floor.
What I want to know is how fat a tire an I get away with to combat this (maximize traction) without killing the power steering?
Any suggestions?
P.S..this is miami so I don't have a snow problem if that's what some were referring to...
Any suggestions?
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
cmpowell86
Aug 10, 2015 12:35 AM
