Wilwood BBK completed.
Old Apr 2, 2006 | 09:52 PM
kamski's Avatar
.org extraordinaire
Hey fellas,
Remember me telling you about a BBK from Wilwood I was getting a developer to build for us.
Well he completed it!!!!
Here is the teaser shot of our kit and a kit for the 350z. Only diff is the size of hat holes for mounting.
WILWOOD BBK
Initial price is $1200 for 4 POT and $1500 for 6POT.
I'm still waiting for Slotted only rotors before he ships.
Cant wait to have thease and new shoes on my ride.
LAYTA!
Kam
Old Apr 2, 2006 | 09:53 PM
naijai's Avatar
wow and
Old Apr 2, 2006 | 10:03 PM
alpinestars™'s Avatar
THIS IS...
Must be your browser. Man those are nice! Wish I could get me some.
Old Apr 2, 2006 | 10:08 PM
RHMax's Avatar
Newbie just Registered
Hot dammmm! How wide spacers we'd need to clear w/ stock 18's?
luigi'smax's Avatar
wow i mean ..wow...did i say wow...
niiice...oh yeah...wow...
oh what is POT ?? no not e the one you smoke but the one that the first post is talking about...it says 4 POT or 6 POT....whats is that ??
Luigi
Old Apr 2, 2006 | 10:23 PM
RHMax's Avatar
Luigi
Calipers, 4 or 6.
Old Apr 2, 2006 | 10:55 PM
kamski's Avatar
.org extraordinaire
4POT or 6POT means the amount of pistons within each caliper.
The 6POTS are basically used for track to prevent the pads from tapering under extreme conditions. So unless you drive your maxima like a friggin lunatic you most likely wont need 6POT calipers.
Anywhoo, for $1200 you get some serious brakes with rotors and hats. Thats still $1100 cheaper then the APR kit with rotors and hats.
I'm eagerly waiting to have them delievered and installed.
Please dont quote me but they are supposed to fit under the stock 18"s.
Will need a small spacer for 17" OEM.
Anyone use spacers on their 6th gen?
Thanks,
Kam
Old Apr 2, 2006 | 11:14 PM
jsmithsole's Avatar
*moderator*
Wow, can't wait to see them on your car!!
Old Apr 2, 2006 | 11:17 PM
AscendantMax's Avatar
that'll look pretty damn nice, not to mention the upgraded braking performance.
Old Apr 3, 2006 | 08:54 AM
Glude's Avatar
Are those rotors any lighter than stock? I know someone made some 2 piece 6th gen rotors and they were about 6 lbs lighter per rotor.
Old Apr 3, 2006 | 02:09 PM
DeusExMaxima's Avatar
Dam Kam, I just ordered my 300zx brake conversion. I might have waited for this had I known.
Old Apr 3, 2006 | 03:06 PM
JiuJitsuThug's Avatar
Man that looks SWEET!
Too bad I just put on new rotors, pads and brake lines.
Oh well - maybe in about 15K.
Sweet looking setup and the price seems GREAT!
Old Apr 3, 2006 | 03:09 PM
jasonjm's Avatar
They look good. I think for maximum 'bling' factor the 6 pots look best. Wilwood calipers always seem to be smaller than their competitors. Both will have close stopping power to within each other so it's seriously just 'bling' going for the 6pot.
Old Apr 3, 2006 | 03:14 PM
Jeff92se's Avatar
I'm needing a caw
Rotor diameter size? What is the cost for just the rotors?
Old Apr 3, 2006 | 03:59 PM
kamski's Avatar
.org extraordinaire
Rotors are 13.6" by 1.10" while pads are 20mm per side, so less heat transfer will happen into the caliper due to thicker pads. You can also opt for the ThermaLock pistons for an additional cost or buy them direct from Wilwood.
Also the 6POT calipers are the SL6-R model and 4POT are the FSL-4 .
I'm not sure as to availability of just rotors, but from speaking with the developer he quoted me $195 per rotor not including the hat.
From what I have been told, the 12.1" rotors he had for other vehicles have lasted more then 40,000 miles under "strenous" conditions.
I'm curious to see what the larger diamater rotor does for my baby in hollerin her down to zero from stupid fast
I'm gnawing my hands off waiting.
Kam
Old Apr 3, 2006 | 04:10 PM
kamski's Avatar
.org extraordinaire
Only thing that would worry me is the loss of pressure on the booster under full brake on condition with the 6POT kit. I'm learning about brakes so if anyone knows more detailed info, please fill me in.
Thanks,
Kam
Old Apr 3, 2006 | 04:12 PM
!PrjctMax!'s Avatar
"..........developer he quoted me $195 per rotor not including the hat."
What are "hats?" is that another word for pad? sorry for noob question
Old Apr 3, 2006 | 04:50 PM
FrostMaxima's Avatar
are they for the fronts only, or is it extra for the rears?
Old Apr 3, 2006 | 05:46 PM
I would have some concerns about brake bias with large front brakes like this. Any chance of upgrading the rears? Thats another reason I went with the 300zx conversion is that its improved braking but not as radical as this. Im wondering if ur guy makes two piece rotors in stock rotor measurements? If so, I'm in for those. I love lightening unsprung weight AND rotating mass as well. Lighter rotors are of great benefit.
Old Apr 3, 2006 | 08:39 PM
kamski's Avatar
.org extraordinaire
I'm not sure about the rears as of yet.
Wilwood makes the necessary parts to snap in place of OEM but rotor size and thickness will have a lot to do with that project. (DUE SOON).
I'm going the 4POT way and seeing what develops, hopefully I wont have brake bias issues. But even for that there is a bias adjuster that I can use.
Take Care,
Kam
Old Apr 3, 2006 | 08:42 PM
kamski's Avatar
.org extraordinaire
Hats are the parts that the actual rotor ataches too.
The rears have not been built yet, I think for the rears we will use Wilwood calipers with stock rotors for best $value. But thats a whole different story.
Thanks,
Kam
Old Apr 3, 2006 | 10:00 PM
Does he make two piece stock sized rotors for front?
Old Apr 3, 2006 | 10:37 PM
RHMax's Avatar
Thanks,
Kam
You think front and rear under $1600?
Old Apr 3, 2006 | 10:55 PM
MrGone's Avatar
I <3 Wilwood stuff
I helped one of my Dad's friends install and setup his brake system. SL6/ST front and SL4/ST rear with GT rotors. Extremely nice parts to work with
over $4000 into that setup though
Old Apr 3, 2006 | 11:18 PM
Jeff92se's Avatar
I'm needing a caw
Just a note. It's the total area of the pistons, not necessarily the # of pistons that determine Master cylinder size.
And if you are thinking about actually ajusting bias with a Tilton unit or similar, it's not as easy as you think. The bias is set in the master cylinder and not in some distribution block.
What you will end up doing is just restricting the bias to the fronts. Sorta eliminating the effort.
I would highly suggest that whomever is working on the rears, set it up so the oem bias setting is again retained.
Take Care,
Kam
Old Jul 14, 2006 | 02:40 PM
kamski's Avatar
.org extraordinaire
Uhhhh ^^^ installed and working great so far.
Kamski
Old Jul 14, 2006 | 04:28 PM
MisterSparkle's Avatar
damn...i don't kno if i wanna go with brake upgrades before others...cause the thing is if i go brakes i won't have anything left for anything else!!! lolxz...buh everytime kam starts these threads about the damn wilwoods...it gets me thinkin again!!! lolxz
kam STOP IT...j/k
i wanna wait for a BBK set for front nd rear...w/slotted nd drilled rotors...4piston...either willwood or brembo...which ever comes out first!!!nd i'm tryin to keep it to $2000 or under...lolxz damn picky buh i kno wuh i'm lookin for!!! lolololxz
Old Jul 14, 2006 | 04:35 PM
kamski's Avatar
.org extraordinaire
kam STOP IT...j/k
Thats about right, 2k for front, 2k for rears.
Kamski
Old Jul 14, 2006 | 04:39 PM
NOOOOOooo not wuh i was talkin about i mean $2000 for full BBK set front AND rear...think about it...its possible...its not lik our cars are AWD...they braking force doesn't have to be the same...
lager calibers in front nd smaller ones in back...i mean if front BBK is already $1200 give or take some...$800 extra for a rear set isn't asking to give up much don't u think?
Old Jul 14, 2006 | 04:42 PM
kamski's Avatar
.org extraordinaire
www.fastbrakes.com
and check out some of the different brake sets they have. The rears should be 2 piston to keep the bias in check on a FWD car.
Kam
Old Jul 14, 2006 | 04:47 PM
Maxim(a)SerjVQ's Avatar
Nightmare = Reality
damn; I'd like those Nismo Rims and that kit fitted to my 5th Gen Pls!
Old Jul 14, 2006 | 08:38 PM
kamski's Avatar
.org extraordinaire
The kit fits the 5th gen, since u can use the 6th gen brake upgrade you can get this kit on your car also
Kam
Apr 16, 2020 05:15 AM
Matt93SE
May 24, 2019 02:58 PM
Quickgtp
Apr 13, 2017 03:30 PM
maxfever1987
Nov 19, 2016 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
