Engine Dress Up Question
Old Apr 8, 2006 | 05:48 PM
maximob's Avatar
I bought a stainless steel sleeve kit for the engine hoses, I noticed others on the org have it. What did you use to trim the sleeves to size? I ruined 2 scissors and 3 metak shears trying to cut the braided hose!!
Old Apr 8, 2006 | 09:53 PM
SHIFT_matt's Avatar
Let me know how that install ends up going, Maximob. I am getting ready to do the same thing, it looks good. Where did you get your kit at? I saw them at Schuck's for around $50. I assume it's universal fit...
Old Apr 9, 2006 | 08:36 AM
maximob's Avatar
Well, I ended up only doing one hose right now because of how hard it was to trim. It took 1.5 hrs to do the short radiator hose. I ended up snipping the stainless steel one strand at a time...WAY time consuming. I need to find a better cutting method.
I got the kit at Autozone for $50. It is a generic sleeve kit with 5 different size sleeves and colored covers for the ends. Looks pretty cool! I need to find a way to post pics. I'm not signed up anywhere where I can post them. I used ramberg's engine as my insiration (thanks punisher!!)
Old Apr 9, 2006 | 09:28 AM
ramberg's Avatar
GrandPa
PM chernmax. He did mine.
Old Apr 9, 2006 | 10:10 AM
CanadianMoFo's Avatar
Dremel tool with a fiberglass cutoff wheel has always worked well for me. I've had to cut some rubber hoses with a steel mesh inner layer at work. The Dremel is the only tool I found that does it cleanly and precicely. Should work the same on a full mesh hose.
CM
MAXSE5SPD
Sep 17, 2022 04:00 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Hawkeye61
Aug 12, 2015 06:45 PM
