how does this sound (ECU PRICE)
Old Apr 22, 2006 | 11:58 PM
  #41
RHMax's Avatar
Newbie just Registered
Originally Posted by cwepruk
...Does it turn of Check engine lights from exhaust mods (i.e. if headers came out, the removal of the precats would trigger a code) most aftermarket ECU's disable that code.
Not the purpose of a flash. You would need to have the tuner code off particular sensors you want inactive.
Is the transmission operation affected (auto). I would like a slightly higher redline (or shift point) and the ability to control shifting up to that point with the manumatic. Right now the manumatic won't let me past 6300.
Mine will shift at 6500 now, you can always hold the shifter down so it won't shift and hit the rev limiter. The rev limiter will be raised to 7100 RPM.
Will a dealer know you did this mod and/or be able to reflash/erase the programming?
Only if they suspect something and plug the ECU in to check codes.
WIll my ECU need to be shipped for programming or am I buying a new ECU? I can't afford any downtime so even a core program would be great.
The ECU will have to be shipped. Each ECU is key dependent, your key has a chip that send signal to ECU to deliver fuel when you start your car.
And finally, I'd just like to see the final dyno numbers. $380 is a great price IMO and I'd probably be in.
Tek has gained 17HP and 10TQ at the wheel. I'm getting dyno next week.
The down time would be minimum of 3 business days with next day air service both ways. You can send it out the afternoon of day 1 and get it back morning of day 3 at the earliest.
Old Apr 23, 2006 | 05:43 AM
  #42
swowlinc's Avatar
1993 SE
Im in, pending things going good and the down time is minimal.
Old Apr 23, 2006 | 08:13 AM
  #43
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
I would send the one you have Cwepruk, I bought a new one and installed it, but the car didn't start with it. WHY? cause the new ecu needed to be programmed to your keys cause of the chip key.
you can buy a new one still at whatever price it is, but you will have to pay another 120 to get it programmed to your keys.
my dealer installed mines at first, until I found out how to do it myself...
Old Apr 23, 2006 | 08:17 AM
  #44
Tek-Niq's Avatar
18 more, I'll get the progress started on monday..
I need about 30 cars total, but it can be anything from infiniti and nissan, since I have about half already just on this site I can get more on other sites..
so monday I'll post an update..
Old Apr 23, 2006 | 08:23 AM
  #45
ramberg's Avatar
GrandPa
I don't remember if you posted it but how much was the new ECU and were they able to program the keys with the ecu out of the car? Also do you still have the part number for the ECU.
Old Apr 23, 2006 | 08:27 AM
  #46
Tek-Niq's Avatar
I bought the ecu off a salvage maxima for 150, 120 to get it reprogrammed to the keys at the dealer.
they need the car and the ecu with all your keys there, it needs to be inside the car..
Old Apr 23, 2006 | 08:32 AM
  #47
cwepruk's Avatar
Thanks for the answers.
One question
How do you hold the shifer "down". You mean hold it back while accelerating and it will hold the gear a bit longer? If so, I never knew that. Even in manual mode, it will automatically shift at 6300.
Old Apr 23, 2006 | 08:35 AM
  #48
ramberg's Avatar
GrandPa
I quess you put the OEM one back in and drove to the dealer. How long did it take to swap out the ECU? Can you please do a write up on it?
Warren
Old Apr 23, 2006 | 08:38 AM
  #49
RHMax's Avatar
One question
Yes, pull it down like downshifting and hold it. Don;t forget to let go though!
Old Apr 23, 2006 | 08:39 AM
  #50
Tek-Niq's Avatar
Warren
I have a write up on www.6thgenmaxima.org it takes 5 minutes for me now, is very simple..
this is the link:
http://www.6thgenmaxima.org/forums/viewtopic.php?t=538
you must be registered to see it though, for those who can't
Old Apr 23, 2006 | 08:43 AM
  #51
UnMaTcHeD's Avatar
Not for rookies!!
I would be in but I have VDC
Old Apr 23, 2006 | 08:48 AM
  #52
ramberg's Avatar
GrandPa
this is the link:
It will take me all day. lol Thanks for information.
Old Apr 23, 2006 | 08:54 AM
  #53
greg hazlett's Avatar
Tek,
Add me to the list.
Did you install the UD pulley?
Greg
Old Apr 23, 2006 | 08:58 AM
  #54
Tek-Niq's Avatar
Originally Posted by greg hazlett
Tek,
Add me to the list.
Greg
17 more...
no on the udp, I'll have to get my dyno shop to do it or so. maybe next week..
Old Apr 23, 2006 | 10:32 AM
  #55
cwepruk's Avatar
So it won't just shift at 6500, it will bump the limiter if you hold it?
****, good info man (and thanks). I did not know this.
Old Apr 23, 2006 | 11:21 AM
  #56
!PrjctMax!'s Avatar
So if I were to get my ecu re-mapped and all, then I would have to take it to the stealership and have them reprogram the keys. Would they by chance erase the "modified ecu?" Or will they have a b****-fit of some sort that they can't do it since it's "aftermarket?"
Dan
Old Apr 23, 2006 | 12:53 PM
  #57
michaelnyden's Avatar
so you guys only the do the ecu's that can flashed? what about the 2000-2001 maxima ecus...which are supposedly unmoddable?
Old Apr 23, 2006 | 02:01 PM
  #58
SEBOY's Avatar
good question !PrjctMax! i hope i don't have to take my car to the dealer to reprogram my ecu
Old Apr 23, 2006 | 02:25 PM
  #59
Losito's Avatar
I'm in for it once everything has been finely tuned. Thanks for taking this effort on Tek.
Old Apr 23, 2006 | 02:30 PM
  #60
Tek-Niq's Avatar
Dan
this is only with another ecu aside from the oem one thats installed already. if you buy another one aside from the OEM one, you will need to program it for your car, if you send the one thats in the car now, you won't have to go to the dealer..
I had my second ecu programmed by the dealer and installed also, nothing changed at all, but you don't have to worry about that..
Old Apr 23, 2006 | 02:34 PM
  #61
Tek-Niq's Avatar
they haven't done that year maxima from what's on the site, but no one has probably tried to get it flashed before. I'm not sure about the unmoddable part of it, but I did hear that you guys don't gain as much as we do with it. I'll have to check that..
Old Apr 23, 2006 | 02:39 PM
  #62
Tek-Niq's Avatar
16 more, you're welcome..
Old Apr 23, 2006 | 03:04 PM
  #63
UnMaTcHeD's Avatar
Not for rookies!!
Tek, any word when this will be available for vehicles with vdc?
Old Apr 23, 2006 | 03:09 PM
  #64
Tek-Niq's Avatar
they are working on it, I guess they are waiting on some crack program to get in for the VDC and the 4sp..
I think they said a few weeks, jaysmithsole is waiting also (4sp)..
Old Apr 23, 2006 | 03:20 PM
  #65
UnMaTcHeD's Avatar
Not for rookies!!
Thanks for the update
Old Apr 23, 2006 | 04:44 PM
  #66
6thGenMax's Avatar
id be interested in the ecu but do i have to bring the car up?
Old Apr 23, 2006 | 04:47 PM
  #67
DeusExMaxima's Avatar
Tek: U have 16 more hp than stock ECU now? What parameters are you working on? What is your estimate of total hp gain? Any idea on the comparison of your program vs. my 350z program?
Old Apr 23, 2006 | 04:54 PM
  #68
SEBOY's Avatar
i don't think so man lol just take your ecu off and send it to them.. i hope this help
Old Apr 23, 2006 | 05:07 PM
  #69
Tek-Niq's Avatar
17hp more, I started with 212, I'm at 229 now. I gained 10 ft lbs of tq. the reason I'm not happy still is cause I have a dip in my low end side that I don't like, I'm still lean on the low end.
I have no clue on how to compare it to your car Deus, I know the 350 dyno they have there didn't gain as much as my car, why? I don't know.
I keep sending it back though, Tadashi keeps working with me and doing different things, I know if I had that program here I can do way more with it.
Old Apr 23, 2006 | 05:11 PM
  #70
Tek-Niq's Avatar
no you won't have to bring your car, I'm working on the small details like this still though, I wanna make sure the shop can handle all of this before I give go, I don't wanna delay anyones ecu cause we are jammed with work.
I'll call them tomorrow and figure this whole thing out.. I know that the shop wants the business and are willing to work with me in giving you guys an awsome deal for the power.
Old Apr 23, 2006 | 05:26 PM
  #71
chernmax's Avatar
Nations 1st 6th Gen Turbo
Do your thing Tek, I personally will wait till you say **** is right. I like your high standards...
Old Apr 23, 2006 | 05:41 PM
  #72
kamski's Avatar
.org extraordinaire
I concur doctor, the sheeeet must be right before its get dumped.........
From the convo I had with Tek his ECU makes the car stupid FAST! If I could smoke my wheels throught first and second................ DAMN....
Cant wait. Tech question, I bought a used G35 ECU, can it be reflashed to the maxima specification?
Thanks,
Kam
Old Apr 23, 2006 | 06:13 PM
  #73
!PrjctMax!'s Avatar
Right next to the sign with "Nissan," put a sign of "Tek-Niq!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!"
Old Apr 23, 2006 | 06:15 PM
  #74
!PrjctMax!'s Avatar
[QUOTE=kamilkluczewski]
I should probaly know this by now considering that Tek is famous and all on this site! lol But what mods do you have Tek?
Old Apr 23, 2006 | 06:33 PM
  #75
NmexMAX's Avatar
dot dot dot ...
Why in the hell would you want to do that?
Old Apr 23, 2006 | 07:03 PM
  #76
chernmax's Avatar
[QUOTE=!PrjctMax!]
It's not important necessarily the mods that he has on his ride verse the work and research he has done for the whole 6th Gen forum...
Old Apr 23, 2006 | 08:19 PM
  #77
logik05se's Avatar
all i know is i have a 5 speed auto with tcs, and like i say in holdem.
Im all in.
Old Apr 23, 2006 | 10:18 PM
  #78
kamski's Avatar
.org extraordinaire
WHat i mean is, I have a G35 ECU, I would rather send that out and have the Maxima Program Cloned onto it as opposed to using my stock ecu.
In that I mean, take all the G35 data, wipe it, upload modded maxima data and save it on the Infinity ECU as opposed to my original one.
By that I mean, take the Infinity ECU and clone the data from the STOCK MAXIMA ecu onto it, then mod the Infinity ECU with the Maxima data so that the maxima performs like a G35 but I still have my stock ecu.
What I mean to say is............. a fak it.
Kam
Old Apr 23, 2006 | 10:39 PM
  #79
Get a Z ecu!!
Old Apr 24, 2006 | 03:59 AM
  #80
tedo007's Avatar
faster than you think
u said all maxima?? what about 99?
