Air Box resonator
I think I might be with you depending on this weekend at the track...... I went to the track today and man my times were crap..... not from how I was driving but how the car was driving..... I mean half a sec worse than what I was doing before the intake..... I even took time out to reset my ecu..... I was highly disappointed and might go back to stock..... the sound is deffinitly not worth the power loss.... I did however run at a different track today that is why I will wait till this weekend and see what my times are at the track I normally race at are...... I was told the elevation was about 2600 ft above sea level..... and where I normally run is only 900 ft above sea level..... but half a sec damn..... doesn't sound right..... anyways sorry to get off subject..... sorry can't part with mine just yet..... if all goes well this weekend I would be willing to let her go.....
To be honest, I still have everything except that one piece... I took it off to allow for another opening so more air could get in the box with more ease. All it did was create a louder stock intake and didn't really help in any way. There's a chance that I will be selling the car, so I want to put it back to quiet just in case.
po8pim: Good luck at the track. What was the temperature difference between the last two times you hit the track? It's getting hot over here in Atlanta and everybody's times are slipping.
the reason for his lower times probably was that the intake makes the car leaner in fuel on your bottom end of the rpm's, so you don't get off the line as quick..
the more mods like y-pipe, and cattback's you get, the worse it is..
I recommend doing the ecu program, it will give you the fuel you need at the right rpm's and you won't be lean. all your tq and hp will be at the press of the pedal..
just to give you an example, a maxima with all the bolt ons ran 220hp on the dyno, just my intake and ecu did 229hp, you make the choice..
Originally Posted by Atlpinoy
so is it good to get an air intake or not? thinking of getting a nismo one for the max but will not get one if its not worth it! let me know guys! thanks!
Originally Posted by Glude
I doubt the intake had little to do with his times dropping. Weather usually plays the biggest role, as well as the 60 foot times. What were your 60 fts for both times if you got them?
On the upside, I feel a power surge above 4k rpms and it seems to pull harder once I get up into the higher rpms.
And the car does sound sweet....raaaaAAARRRE!
you can see the hp and tq drop on the low end with the intake, up top you pick some power up, but not on the low end...
all cars get lean with the intake, you can't help it unless you fix the ecu or something..
Originally Posted by Tek-Niq
have you ever dynoed your car?
Back to the main stubject:
Removing the resonator made it sound more aggressive, but not as loud as an open filter. The low end didn't drop pull like when I had my intake. I just want to quiet it back down. So if any of you have one that you're willing to get rid of, state your price... thanks
tarun900
19
Dec 20, 2021 06:57 PM
