When is an alignment recommended??
Old Jun 5, 2006 | 12:35 PM
silvermouse5150's Avatar
I know its best if you can get an alignment whenever you can (if you can afford to), but when is it recommended?
Brought my Max in for 15k service.
And the service guy, recommended an alignment. Didnt say i needed it, but recommended it was a good idea.
Old Jun 5, 2006 | 12:41 PM
OmarBadu's Avatar
you do it when there is a noticeable sound and/or driving line problem
Old Jun 5, 2006 | 12:46 PM
PapaL's Avatar
And/or after getting it dropped.
Old Jun 5, 2006 | 12:56 PM
Monotaur's Avatar
Like when the car pulls to one side when the wheel is straight? I have been getting this for a long time (even after getting the front wheels aligned). Also, the tires make a "wobbly" noise when I hold the wheel to the left to go straight. I'm guessing my wheel is about 5-10 degrees of center. Would a 4 wheel alignment help this or is this not the problem?
Sorry for the noob question and hijack.
Old Jun 5, 2006 | 01:20 PM
I believe a 4-wheel alignment will fix this.
Im not suffering from any type of pull, my Max drives just fine.
Old Jun 5, 2006 | 04:19 PM
Killah Kane's Avatar
You should also do an alignment anytime you replace your tires as well. Even good to do after you rotate tires. I would recommend to buy a lifetime alignment, you pay one price and get it aligned as often as you want. If you get this, I would do an alignment every 7000 miles or so, or after you hit a big pot hole in the road.
Old Jun 5, 2006 | 07:51 PM
Monotaur's Avatar
Thanks... I'll probably have this done when I replace my tires in about a month or so.
Old Jun 6, 2006 | 11:52 AM
I didnt know this existed. This is cool.
Do you know if this is offered via your dealership or is it a nissan thing?
Old Jun 6, 2006 | 03:12 PM
flaminio's Avatar
Michel Tires offer 3 yr. alignments for $110
Old Jun 7, 2006 | 07:51 AM
Thats too bad, we dont have Michel Tires down here in Atlanta.
Anyone else know of any alignment deals through the major Auto repair chains, or if Nissan has a plan?
Old Jun 8, 2006 | 07:36 AM
SLuxury's Avatar
I've had my alignment done about 5 times in the past two years... each time, they'll straighten out the steering wheel and everything will be great. Give it about 100 miles and the wheel is turned to the left and pulls to the left again. Any ideas?
As for Atlanta, Butler tire is supposed to be one of the best.
Old Aug 16, 2006 | 10:50 AM
missjane's Avatar
This same thing is happening to me. Get it aligned and right after that the wheel is turned to the left and pulling to the left. Driving me crazy!
The dealer did the last alignment, but if I could get it done cheaper and have it LAST somewhere else, that would be great.
Jane
Old Aug 16, 2006 | 06:26 PM
Monotaur's Avatar
Jane
I'm having the same issue. I replaced my times and had a 4 wheel alignment done at the same time (while doing this, the shop scratched all 4 rims... and tried to tell me that the scratches were a manufacturing defect when I called him on it ).
Anyway, my wheel now points to the left and the car doesn't quite pull in a straight line. I was wondering if the alignment job was done incorrectly, but the shop said that the machine was recently calibrated and other cars were fine. Any ideas?
Old Aug 16, 2006 | 11:20 PM
SilverMax_04's Avatar
I get my wheels (all 4) alligned once a year in late May, just before all of the summer driving. It is a lot cheaper than buying new tires -- particularly for an SE. I put between 15 K and 20 K miles a year on my Max.
Why do I recommend a 4-wheel allignment at least once a year. Well, my Max came from the factory with the rear wheels slightly out of allignment. I was rotating my tires every 7.5 K miles, and it was 1.5 years before I noticed that there were cups worn in the tread of all 4 tires. There was never any pulling or noise from the tires. These cups slowly wore into the tread (you could feel them by rubbing you hand over the surface of the tread). As the cups got deeper with time, a rumble started coming from the tires. I got the wheels alligned, but it was too late. I drove with this rumble (particularly noticable between 40 and 70 MPH) for almost a year. So I ended up replacing my tires before they were worn out to get rid of this rumble. I now get an annual allignment to save the tires.
Old Aug 17, 2006 | 05:51 AM
Lovemycar's Avatar
I Must say this must be the way you guys are driving i got an allignment about 12 hundred miles ago and my MAX is still in very good allignment
100 miles is very short for an allignment to go bad just my 2cent
Old Aug 19, 2006 | 08:12 AM
DONS459's Avatar
I haven't had front end alignments in over thirty years on any of my cars. But i don't put many miles on anymore or hit that many potholes. It must be you guys driving off road.
LOL
Old Aug 19, 2006 | 08:30 AM
SilverMaxima06's Avatar
what about a problem when you only feel the alignment issue when cruising on the highway say around 70mph and it slightly pulls to the left but other wise at lower speeds like 30-45/50 nothing is really felt
Old Aug 19, 2006 | 10:47 AM
willysmooo's Avatar
have 69k and wheel is fine..drives completely str8 never had one alignment.
Old Aug 19, 2006 | 11:06 AM
So many on this site say: "What is an extra 20 cents per gallon when I'm already paying over $3 per gallon for gasoline." To which I answer: "If you don't use the maximum performance that premium provides, why pay extra for it." This is a saving that I understand and use.
A savings I don't understand: saving $69 for a full wheel allignment that can save you improperly wearing out tires that (if you get the best ones) cost over $200 per tire. If you don't put many miles on your Max, you probably don't need to get the allignment checked every year. But at least get it checked on occasion. Improperly worn tires are a real pain -- I know because I had them.
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
MannyMonroe
Sep 25, 2015 12:38 PM
sdotcarter
Sep 2, 2015 09:53 PM
