spare button?
Old Jun 13, 2006 | 07:04 PM
aryathegreat's Avatar
spare button?
i was gunna hook up a couple floor lights i had to an on/off switch and i wanted to see if anyone knew how to take out the spare button underneath the dash (under the steering wheel), next to the TCS button. on my 05 theres a kind of button space holder and i dunno how to get that out to put in a switch. thanks guys.
-arya
Old Jun 13, 2006 | 08:29 PM
gurlie_J_gurl's Avatar
I wanna be at my maximum
wack it? i would take an educated guess and say that it probably locks in... onto the dash... so just find the lil plastic connector and there ya go.....
Old Jun 13, 2006 | 08:58 PM
problem is its impossible to see what ur doing behind it, so basically u gotta stick ur hand back there and mess around with it. b4 i did that i wanted to kno if anything has taken it out so i kno what im doing?
Old Jun 13, 2006 | 09:24 PM
jingiko's Avatar
i tried to do that to my neon lights
i know what you mean but i couldnt get it
and i have tried several times. in the end i just gave my button away
lol
Old Jun 13, 2006 | 09:41 PM
im thinking about just pushing it really hard and having the clips or w.e. holding it break, since i wont be using them, but i wanna see if any of u guys have an easier way. lol
Old Jun 13, 2006 | 10:04 PM
po8pimp's Avatar
no just take the lower part of your council off..... two screws..... one is located behind the fuse panel door under the steering column and the other is on the lower right hand side..... philips head and then pull from the bottom and sides toward you.... that's it.... comes right off and then you have access to see at least if you want to take it out just remove the screws holding the mirror controls and the cabin temp sensor on the right and you're done.... as far as removing the button I don't know and can't help without pictures or an 05 Maxima like your's in my driveway..... I don't have this spare button otherwise I would have allready used it..... I made my switches....
Old Jun 14, 2006 | 02:00 PM
kinda hard to get pics since i gotta get the camera inside the paneling, which doent really fit 2 well. ima try to take off the lower paneling to take it off. if anyone has done it yet id love to get ur input . thanks guys
-arya
Old Jun 14, 2006 | 04:54 PM
gec
Kinda confused here array --- do you just want to remove the blank?? If so undo the 2 screws that po8pimp said and unclip the harnesses and the whole piece will come out --- then there is one screw on the bottom holding that assembly in place --- undo that and the buttom assembly will come out. Each button is locked in by clips just push them out....Kenny
tarun900
19
Dec 20, 2021 06:57 PM
JonBlz
Oct 5, 2015 06:02 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
Max139617
Sep 29, 2015 06:44 PM
