Question for lowering ONLY front end....
Old Aug 30, 2006 | 07:47 AM
PENROSE2006's Avatar
About to pull the trigger on some GR2's and Progress springs for the front only (I think the back is fine, and wouldn't care if the front ends up a little lower than the back).
My question is if I did this, would I need to adjust my headlights?? If so, how hard is it to do that?
Old Aug 30, 2006 | 07:53 AM
owais's Avatar
That's interesting, I never thought of re-aiming headlights after lowering a car. How about drawing a line where the cut-off is, and then after lowering the front of your car, see if it needs to be adjusted? Obviously, you would need to make sure everything else is still the same such as location, the wall, etc.
Old Aug 30, 2006 | 10:57 AM
MAXDOUT04's Avatar
* THIS SPACE FOR RENT *
If your lowering on progress you might as well just lower the back too it doesnt come down much at all and you shouldnt have to aim if you come down on all 4 corners but if you do fronts only you might plus you will get a floaty feel with fronts only i did then i put in rears and voila all gone and looks hott
Old Aug 30, 2006 | 11:23 AM
RHMax's Avatar
Newbie just Registered
Even if you lowered front and back with Progress or Eibach, you might want to adjust the headlights since the front is lowered more than the back.
Old Aug 30, 2006 | 12:18 PM
MisterSparkle's Avatar
well i lowwered my car and i don't really think i need to reaim my headlights...maybe after the alignment i might have to buh really doubt it.
Old Aug 30, 2006 | 12:46 PM
RHMax's Avatar
For those who live in relatively flat land, you may not notice much difference. I noticed it the first night I drove down the not-so-well-lit part of the highway through a small valley, I couldn't see crap.
Old Aug 30, 2006 | 02:35 PM
How hard is it to adjust the headlights??
Old Aug 30, 2006 | 03:23 PM
RHMax's Avatar
It's a pain to get them even; unless you have access to a clean wide wall at least 4 feet high with about a 40 feet of leveled distance from it.
homeyclaus
Sep 3, 2015 06:15 PM
twotonezed
Aug 16, 2015 11:41 AM
soon2ownmax
Aug 13, 2015 02:19 PM
classymax420
Aug 6, 2015 06:35 PM
laparka66
Aug 6, 2015 09:36 AM
