Trenz Grill & MPG
Old Sep 6, 2006 | 06:03 AM
odinala's Avatar
Trenz Grill & MPG
I'm sure this is just a coincidence, however, a month and a half ago I installed a Trenz billet grill and my gas mileage has dropped about 1.5 mpg (from an average 23.5mpg to 22mpg). I've always been **** about keeping track of my mileage on all my cars and for the last three tank fill-ups it's gone down. Temperature has been the same (hotter than hell), driving still the same and just went over 10K miles.
Old Sep 6, 2006 | 06:18 AM
04BlackMaxx's Avatar
I have the Trenz too, actually just polished it up with Mothers aluminum and mag polish and WOW it looks brand new again. As for your MPG thing...
Old Sep 6, 2006 | 07:07 AM
Greeny's Avatar
¯\(°_o)/¯
DrFuelMax should fix your problem...
Old Sep 6, 2006 | 07:12 AM
NisMoN00B's Avatar
+Cru OG
You need a new Kneutson Valve and most likely your Muffler Bearings are shot. Get that looked at ASAP...
Old Sep 6, 2006 | 07:15 AM
RHMax's Avatar
Newbie just Registered
That's a hugh different from just a grille. Have you switch gas station? Has the gas station switch distributor? Is it different formular, richer in ethanol?
Old Sep 6, 2006 | 07:26 AM
Iron Scimitar's Avatar
Tha Snatcher
Check the grille sensor...when you removed the stock grille and put the Trenz one in, the grille sensor wont detect the aftermarket grille. The grille sensor monitors how much air hits it, and then recalculates the Air/Fuel ratio...better put the stock grille back on.
You know i'm jokin', right?
Old Sep 6, 2006 | 07:28 AM
Fr33way™'s Avatar
Wild for Width
I wore a blue Polo today and the car pulled harder in 3rd.
Old Sep 6, 2006 | 07:33 AM
Nissan 6's Avatar
Must be from the awesome aerodynamics of the trenz grill
illlojik's Avatar
I C U
The lines in the Tenzo collects and holds more air therefore adding more weight, therefore crappin on your MPG. The stock is more aerodynamic and actually pushes the air out of the way due to Nissan's R&D and should therefore be placed back asap before your problem gets worse.
true story.
really it's not, I don't know what to tell you guy.
Old Sep 6, 2006 | 07:51 AM
Fr33way™'s Avatar
Wild for Width
I keep waiting to see the cat.
Old Sep 6, 2006 | 07:59 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Old Sep 6, 2006 | 08:05 AM
sonicrunch's Avatar
teh kittah has spoken
Old Sep 6, 2006 | 10:10 AM
NmexMAX's Avatar
dot dot dot ...
The grille sensor is seeing more airflow due to the added turbulence, therefore sends a false signal to the ECU requiring more fuel for the injectors.
Old Sep 6, 2006 | 10:53 AM
Glude's Avatar
What everyone else said...lol.
Old Sep 6, 2006 | 12:03 PM
NisMoN00B's Avatar
+Cru OG
So in essence, adding a Trenz grille dissipates the balancing effect of the atmospheric data collector. Can't a simulator fix the false signals being given to the ECU?
Old Sep 6, 2006 | 12:06 PM
BadBlackMaxSL's Avatar
Has the wind changed direction and is now head-on? That would account for the 1.5 MPG drop.
Another theory, the added weight of the Trenz grill over the plastic of the OEM grill. Hmmmmm.
Too confusing so I'm just gonna...
Old Sep 6, 2006 | 12:31 PM
CoolMax's Avatar
is invisible
Change the blinker fluid - it's always the blinker fluid.
Old Sep 6, 2006 | 12:54 PM
VQPRO's Avatar
oook this is new
I agree. He should chop one hand off to provide a suitable trade-off in weight.
Old Sep 6, 2006 | 01:16 PM
xorbitman's Avatar
Check your tire pressure.
Old Sep 6, 2006 | 01:36 PM
jcalabria's Avatar
NINE-time Maxima Owner
If that looks OK, I would check the charge on the flux capacitor.
Old Sep 6, 2006 | 02:09 PM
xorbitman's Avatar
Oh forgot to tell you to check your:
1. Gleaming Flinge
2. Spinger worken und spritzen sparken...but be carefull! No mitten grabben und finger gepoken!
LOL!
Old Sep 6, 2006 | 02:27 PM
Fr33way™'s Avatar
Wild for Width
Also, a little bit of Nitrous Oxide in the mix never hurts for daily excursions.
Old Sep 6, 2006 | 02:57 PM
That's alot of cat!
Old Sep 6, 2006 | 03:45 PM
Nissan 6's Avatar
This must be the largest scrolling thread eva!
Old Sep 6, 2006 | 03:49 PM
Fr33way™'s Avatar
Wild for Width
Originally Posted by Metal Maxima
That's alot of cat!
You could say that again.
Old Sep 6, 2006 | 03:50 PM
THAT'S ALOT OF CAT!!!
Old Sep 6, 2006 | 04:49 PM
Bermont's Avatar
I burnt out my scroll wheel on my mouse ... thx guys .. LOL
Old Sep 6, 2006 | 05:48 PM
Nismotic's Avatar
Always sunny in philly
This post takes the ******* cake. Jesus
Old Sep 6, 2006 | 06:08 PM
MisterSparkle's Avatar
i would never have thought a grille could make your MPG go down...unless it weights lik 300 lbs...
Old Sep 6, 2006 | 06:09 PM
well wuhs the point of putting 3 cats on?
Old Sep 6, 2006 | 06:49 PM
Old Sep 6, 2006 | 08:02 PM
NmexMAX's Avatar
dot dot dot ...
Little kittah > bigger kittah
Can't ge used to adomenless FTL :
REDinLV
Aug 15, 2024 12:30 AM
adamgalazka
Feb 5, 2023 08:24 AM
05RLS2
Nov 7, 2016 05:52 PM
ef9
Oct 4, 2015 08:43 AM
ricky7780
Sep 24, 2015 06:50 PM
