I need help, kinda worried bout my car =/
Old Sep 29, 2006 | 02:34 PM
SmokeNismo's Avatar
Ok so today I took out my K&N drop in filter to clean it. I removed the MAF sensor so it would be easier to take off the top part of the airbox. When I put the air filter back I forgot to put the MAF sensor back. I started the car while the sensor wasnt in its place and as soon as I did "Service Engine Soon" light came on. I turned the engine off and put back the sensor and went to start the car again, kept it runnin for like a minute and it still tells me "Service Engine Soon" what the hell did I do? did the ECU jus reset its self or what? If I drive it around for a lil while do u think the light will turn out?
Old Sep 29, 2006 | 02:55 PM
MAX2DAMAX's Avatar
disconnect the battery for a couple of minutes, that should reset it, if not, i think there is a way to reset the ecu manually , but i dont know how, good luck. besides you shouldnt worry, you just have to clear the code.
Old Sep 29, 2006 | 03:34 PM
SmokeNismo's Avatar
hmm, I'll go try to disconnect the battery. Won't the other way of resetting the ECU( pumping the gas pedal while its in ACC mode) throw a SES light too though?
Old Sep 29, 2006 | 04:51 PM
PapaL's Avatar
HA HA - Someone else does it. Thought I was the only one. Welcome to the group. Best advise I could give you....let it be. It'll turn itself off in a few days when it realizes everything is ok. I do a fair amount of driving daily and took 3-5 days. On the 3rd day I took it to the dealer and they wanted to charge me $85 for "computer time" to clear it out. The next morning the light turned off. And yes I did try the ECU reset and it did not work for me. Must not be able to count and plug things back in.
Old Sep 29, 2006 | 05:06 PM
SmokeNismo's Avatar
lol everything is fine now thank God. I took 'MAX2DAMAX's advice, disconnected the negative terminal on the battery for a couple of minutes, put it back, then turned the ignition to ACC mode and let it sit for a minute. After that i started the car and viola no more SES. LOL. WOOHOO !! THANKS
Old Sep 29, 2006 | 09:21 PM
Killah Kane's Avatar
as long as you put the sensor back together properly, the check engine light will turn off after a certain amount of key cycles. Probably in about a week or two it will turn off. Dont worry
Lakersallday24
Jun 16, 2019 01:35 AM
stromm
Aug 27, 2015 04:13 PM
acw
Aug 13, 2015 12:50 AM
kirkhilles
Aug 8, 2015 10:53 AM
Jcof88
Aug 3, 2015 10:43 PM
