MAF cleaning ???
Old Nov 4, 2006 | 09:31 AM
madmik's Avatar
MAF cleaning ???
Anyone cleaned their MAF lately? Any noteable difference??
CRC has this new MAF cleaner:
http://www.crcindustries.com/files/M...heet%20Web.pdf
In the carburator days, the inside body had to be cleaned once a while to remove varnish. Wouln't a squeaky clean MAF do a better job for the ECU?
Old Nov 4, 2006 | 06:23 PM
BlueMaximus's Avatar
MAF Sensor Cleaning
I owned a '95 Tbird 4.6 L V8 for 10 years before I bought the Max. A few years ago, I installed an Amsoil permanent foam air filter in the 'bird. The MAF was just downstream of the air cleaner box. A few months after putting in the filter, I noticed a gradual decrease in performance. Since I couldn't figure out what was wrong, I took it to a mechanic, who cleaned the MAF with some kind of solvent. The power was back; problem solved. Apparently, the oil from the filter migrated into the sensor and clogged it up. Needless to say, I returned to using the stock paper filters.
Old Nov 4, 2006 | 06:37 PM
NmexMAX's Avatar
dot dot dot ...
Ok.... so is there a question here?
I use CRC MAF cleaner on mine and have yet to have problems.
Old Nov 5, 2006 | 12:46 PM
madmik's Avatar
So it does require cleaning! I had read warnings about not adding too much oil on K & N filters after cleaning. Makes sense that too much oil can contaminate the MAF. Tks.
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
