Injen CAI installed today!!!
Old Mar 1, 2006 | 07:47 PM
05MAXIJJ's Avatar
Hi i have jsut installed the Injen CAI today and i felt alot of difference.
I wanted to know if this is normal with the CAI.
When i FLOOR it at around RPM 5500~6000 the sound is VICIOUS... Very loud and mean, Is that normal ?
It sounds like a REAL loud growl.....
So far enjoying it..
Thanks. Will try to get Dynoed and will get ppics tommorow.
Old Mar 1, 2006 | 07:57 PM
VQMAX05's Avatar
welcome to the world of Injen CAI....rips! its normal, mine sounds craaazy with the Greddy..... "HELL YES"
Old Mar 2, 2006 | 12:31 AM
05MAXIJJ's Avatar
Ah.. Its normal and SAFE nice!!!! Rips...YUP couldnt have said better....Love it..
Old Mar 2, 2006 | 03:24 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
yep, its all good..
Old Mar 2, 2006 | 10:21 AM
*FleXIMA*'s Avatar
Getting mine installed today... cant wait...
Old Mar 2, 2006 | 12:30 PM
ramberg's Avatar
GrandPa
Its a blast. Welcome to the Injen family.
Old Mar 2, 2006 | 01:07 PM
DeusExMaxima's Avatar
Im curious if the sounds are different with each intake. I got the Stillen because it is easy to clean the filter and I could pick it up immediately.
Old Mar 2, 2006 | 01:33 PM
ramberg's Avatar
GrandPa
How many times have you cleaned the filter?
Old Mar 2, 2006 | 01:38 PM
i clean it about every other oil change, 6-8,000 miles. So at 26,000, I have cleaned it 3-4 times.
Old Mar 2, 2006 | 03:42 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
I personnally love the sound...
Old Mar 2, 2006 | 04:20 PM
Majestic_MAx05's Avatar
This might be a stupid question, but is there a special way of cleaning the stillen CAI filter???? I have a stillen as well, and its time to get it cleaned. Need to know how to go about it.
Old Mar 2, 2006 | 04:23 PM
05MAXIJJ's Avatar
Does the Injen need filter cleaning also???How do you clean them?
Old Mar 2, 2006 | 06:39 PM
greg hazlett's Avatar
If you have had K&N in the past it is just like them, use the cleaning solvent first and then lightly oil the filter unless you have one of the new dry filters that do not require oiling. The K&N cleaning/oiling kits are universal and you can get them at any auto parts store.
Old Mar 2, 2006 | 07:02 PM
05MAXIJJ's Avatar
So the injen needs to be cleaned also rite?
Do i need to remove the wheel and fender everyime to clean it and get to the filter?
Old Mar 2, 2006 | 07:40 PM
Thanks for the help!! Ill be doing this in the weekend.
Old Mar 2, 2006 | 08:00 PM
madmik's Avatar
It sounds loud from the inside, but when I had the car on the dyno, it was not that loud outside. Sounded just right.
Old Mar 2, 2006 | 10:51 PM
ramberg's Avatar
GrandPa
From the Injen site.
All Injen Air Filters can be cleaned using cotton gauze air filter cleaners and oil that can be purchased from most major auto part stores.
We suggest cleaning the filter every 30,000 miles or when it becomes visibly black in color. We recommend examining the filter every 9,000 miles.
I will be cleaning mine this weekend. Just take it apart from the top and pull it up.
Old Mar 2, 2006 | 11:08 PM
NismoMax80's Avatar
SuPeRmOd
any fix yet for the bracket problem?
with the RedlineMax kit, you guys could direct a lot of air from the opening beside the foglight.
Old Mar 2, 2006 | 11:28 PM
ramberg's Avatar
GrandPa
Chernmax has a fix. I can't find the thread on it. PM him for details. He fixed mine and I have had no problem since.
Old Mar 3, 2006 | 03:24 AM
Tek-Niq's Avatar
if injen hasn't come out with a fix yet, thats cause they make the intake with a stronger braket now, you guys have to look at the new ones that are out to see.
it looks real strong compair to what was there before.. i know cause I've seen it, ask joesredmax..
Old Mar 3, 2006 | 07:41 AM
chernmax's Avatar
OK, here it is again, after 14 months, still rock solid...
INJEN CAI Mounting Bracket Problems:
OK, the Injen CAI mounting SUCKS, driving vibration first took out the rubber boot mounting screw, I re-inforced the mounting and the freaken weld broke... DAMM... So some of you might have this (see pic below)
My Fix, about $20 clams:
Parts Used:
1- ROL Exhaust heavy duty tail pipe hanger.
2- 2 RE Works High Grade Aluminum Quick Release Racing Clamps
The task: Using a vice, I bent the Exhaust bracket in a 90 degree angle and attached it to the lower engine mounting bolt just below the Injen, using 1 clamp, I added a new forward midbody support clamp by hooking it around the Exhaust Hanging bracket U-hook, (The Rubber vibration spacer allowed it to twist nicely into place and is 50 times stronger than the stock shock mount).
Another benefit; the bracket is now mounted under the CAI and eliminated all stress on the mounting hardware. I also replaced the rear bracket (not required, however stronger), tightened down all. Job time, 17 minutes...
First Test Fit:
After prime and paint:
Old Mar 3, 2006 | 08:04 AM
jreilly04's Avatar
I Have heard the Injen CAI b4, cant wait to get mine on.
Old Mar 3, 2006 | 09:00 AM
ramberg's Avatar
GrandPa
[QUOTE=chernmax]
Thanks my friend for reposting this.
Old Mar 3, 2006 | 09:04 AM
NismoMax80's Avatar
SuPeRmOd
[QUOTE=ramberg]
I was just asking for other's sake. thanks guys.
I thought chris did it. Good to hear it's holding up. could you do that from the start to prevent it from braking?
Old Mar 3, 2006 | 09:26 AM
chernmax's Avatar
Absolutely, with the Injen mount, it's not a matter of if, but when. Even if Injen strengthens the bracket, it's the shock mounting bolt that is flawed and Injen is more than happy to keep charging you $10 bucks plus shipping for a new one...
Old Mar 3, 2006 | 11:19 AM
05MAXIJJ's Avatar
This happened to me in my 01 TL with the AEM intake.
The reason was that the intake were suppose to be fastened NOT SO TIGHT...
The intakes need to moeve around a little bit.. When i tightened the bracket real hard and driving fast made the bracket brake apart.
Old Mar 3, 2006 | 02:16 PM
chernmax's Avatar
If that's the case, maybe the CAI makers should specify some torque spec’s vice leaving us all holding our D!CKS...
Old Nov 1, 2006 | 09:00 AM
super6's Avatar
is this broken braket only a problem for the 6th gens? im about to get a used one for 5th gen nad kinda second guessing it now.
Old Nov 1, 2006 | 07:08 PM
Defiant_Max04's Avatar
I like my Fujita, very very loud on the outside & inside as well. When you are ripping it down a street everyone looks at you. Almost everyday when im in back of a car and they hear the Fujita, they almost always pull over and let me pass because they are afraid. No lie either.
I bet the Injen is great. I wonder what one sounds better, Injen or Fujita?
Old Nov 1, 2006 | 08:31 PM
MisterSparkle's Avatar
which injen CAI do you have? the sp 1946? MR TECH?
Old Nov 5, 2006 | 06:09 PM
still no pics?
Old Nov 5, 2006 | 09:08 PM
kamski's Avatar
.org extraordinaire
Now that I have access to a welder........ wher do I go to re-order this new rubber mount. I looked all over injens site!!
Kamski
kmitchel
Oct 28, 2015 09:46 AM
Johnny9595
Sep 3, 2015 05:18 AM
lowpost99
22
Sep 2, 2015 04:38 PM
95Maxi
35
Sep 2, 2015 10:37 AM
Trin1j23
Aug 12, 2015 08:31 PM
