Ugly Smell When I Accelerate Quickly..
Old Nov 4, 2006 | 11:28 PM
2LEET4U's Avatar
After Pwning a smaller BMW today, i noticed a strong burning smell coming into my car. I remember smelling this before a few days ago when driving down the freeway. I hear no strange noises. But after a few minutes and when slowing down, the smell goes away.
I am not to sure if anyone has experieced this before. It only happens when I go fast. 50+ MPH
If anyone knows, is this an easy fix? Or do I need to take my car to the stealership?
Old Nov 5, 2006 | 12:36 AM
lightonthehill's Avatar
2LEET4u - I have noticed that same strong odor about seven or eight times in the two and a half years I have had my '04 SL. It is ALWAYS just after I have performed a fairly extreme maneuver; usually a 'floorboarding' job when passing quickly in a very short passing zone.
The first time it happened, I thought I had blown the engine. But I have never actually found any problems that resulted from this almost rotten egg smell. In fact, my car has been mechanically perfect since a few glitches were adjusted right after buying it.
I have gradually gotten to the point that I simply ignore the odor.
Old Nov 5, 2006 | 01:00 AM
Ritz's Avatar
too bad we can't smell things online.. that'd make it easy..
how many miles on the car? and are your fluids up to date? tranny fluid in particular?
you sure you're not smoking the tires?
Old Nov 5, 2006 | 01:35 AM
2LEET4U's Avatar
at first i thought it was the tires, but this does not smell like buring rubber. It smells like roten egg. but again, it only last for a few minutes after stopping the car. I wonder if its the brakes???
My car has 29,700 miles on it, so the tranny service is needed. I plan on getting the Full Transmission Service and the Full Cooling System Flush this month. That will cost me close to $200.00....
No mods have been done to my engine, so im not to sure where this smell is coming from???
Old Nov 5, 2006 | 05:13 AM
4MySwee's Avatar
2Leet4u and Ritz,
It is part of your exhaust! My husband thinks it's addicting because if means you are using some hootspah!
I promise, nothing is wrong, just some unspent fuel or cat juices!
There have been other threads about this and some folks have narrowed down what it is. Maybe search for those? Forgive me, I can't remember which thread it was, nor what the party actually narrowed it down to!
All is well though, like Light, I get it when I accelerate quite quickly also.
Ritz, remember when I was following you for lunch last week? I told you that I can smell you when you punch it? (As well as see you take off like a rocket?), it's that eggy smell!
Old Nov 5, 2006 | 07:54 AM
willysmooo's Avatar
it is normal and many cars do it, although my car used to do it quite a bit on the highway.....it is your exhaust.
Old Nov 5, 2006 | 09:50 AM
2LEET4U's Avatar
hmmmm??? well i feel a little better knowing that its not just my car. im glad to know that this topic has been disscused before and nothing bad has developed from this eggy smell....
So i think its best said, when a Max takes off it uses hootspah!
SHIFT_hootspah
- thanks everyone!
Old Nov 5, 2006 | 10:02 AM
4MySwee's Avatar
You're quite welcome!
Old Nov 5, 2006 | 10:19 AM
!PrjctMax!'s Avatar
What does "hootspah" mean?
I've heard that this is due to catalytic converters. What if someone got a new cat. paired with a resonator and mufflers? Drrrrrrrr or just a whole new exhaust...?
Dan
Old Nov 5, 2006 | 05:47 PM
VigilanteMax's Avatar
catalytic
My old Q45 used to do this as well and it is the catalytic converter, which pretty much boils down to exhaust like 4myswee said. Just some rocket fuel not being spent.
Old Nov 5, 2006 | 07:20 PM
4MySwee's Avatar
"Hootspah": Lots of Cahonies, giddy up or otherwise whoop fanny juice!
Swee-ictionary
Copyrighted 2006 or whenever I think of it!
Old Nov 5, 2006 | 07:35 PM
UNFADEABLE MAX's Avatar
That's what I had when I had my WRX wagon, but then again I was catless.
Old Nov 6, 2006 | 08:15 AM
clayman88's Avatar
Do you have bladder control issues?
Maxima Power + Weak Bladder =
Old Nov 6, 2006 | 09:42 AM
Ritz's Avatar
I was going to say something about that.. now that it's been brought up (since I didn't think of it before) I had a firebird with a cat that was in need of changing, and it did smell a bit like that..
does this mean our cats are bad then?
I don't want the smell, even if it's for the people behind me.. will aftermarket exhaust fix the problem?
anyone else want Cattman to finish the headers/y-pipe as bad as me? full Cattman exhaust, here I come!
Old Nov 6, 2006 | 06:03 PM
madmik's Avatar
I have the same smell. It first smelled like hot engine oil burning, dripping on a hot exhaust manifold. So I tighten the valve covers and pressure washed the engine. No change. That's when I began to believe what everyone was saying about the catalytic converter smell.
Old Nov 7, 2006 | 12:18 AM
And this smell does not mean the catylic converter has 'run its course' and needs replacing. I first noticed the odor with only 2K on the car, and it has not grown worse in the two plus years since.
The good thing is that the odor disappears within a few moments, and never comes back unless I 'max' my Maxima again.
I consider it to be a 'normal' facet of the 6th gen Maxima.
Old Nov 7, 2006 | 06:50 PM
jsmithsole's Avatar
*moderator*
I got the smell today!!! Wait why am I excited??
Anyways I've never had this happen until now, almost 50,000 miles.
I got on it off the line to get over and waaalaaa....da stink.
(went away though shortly after)
Old Nov 15, 2006 | 12:53 PM
kamdigital's Avatar
Had the same thing happen to me a couple of months ago after I had my transmission service done, and I was suspicious also, guess it was the exhaust. But I have my own question, I bought new Xenon headlights for my Max on ebay, cuz my car has the halogen's and I need to know if the harness or the connectors have to be replaced too. I was told by someone at the dealership that an "extra" ground has to be run through the harness, but he didn't know if the Halogen and Xenon had the same one or connector. Please help!!! I would hate to have dropped $700 for 2 lamps that I can't use.
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
