mirror garage door opener
Old Nov 13, 2006 | 05:13 AM
haunt14's Avatar
I need to set up my new remote with my mirror and i forgot how to do it. im not too lazy to look in the book, my book got robbed when my car got broken into two years ago. some help would be much appreciated. thanks
Old Nov 13, 2006 | 06:00 AM
!PrjctMax!'s Avatar
hold the remote a few inches away from the mirror and hold both the button that you want to program it to and the remote for about 20-30 seconds...it will flash slowly and once programmed it flashes rapidly which is when you can let go of both buttons
hope this helps
dan
Old Nov 13, 2006 | 06:40 AM
4MySwee's Avatar
Haunt, forgive me,
Prjct,
Keep your laughs to yourself, because I already know I deserve them!
I had my mirror replaced by Nissan. The Homelink button was peeling off, paint wise.
The service man said it took him a bit to get the car to me because he was calibrating the compass. Eric watched him....closely.
That was over a week ago. I was getting aggrivated because my mirror would go between 'c' and an actual direction.
Finally last night I went to a huge parking lot and spun my three circles counter clockwise and wait for it to reset.(Rather, I spun my three circles in the car, not just me outside spinning the circles mind you) It did, but I still wasn't convinced that it solved my issue, so I whipped out the manual, read it and realized the service guy may have spun circles, but he didn't select the correct region on the map! I don't live in region 8-Tennessee or GA.
SO I reset it to 9 (SC). I spun my three circles and it tracked right away, and even faster than my last mirror!
Just had to share! Promise I'm not a blonde!
Old Nov 13, 2006 | 07:48 AM
haunt14's Avatar
thanks, is there anything special i have to do if the button has been programmed already with a differant remote?
Old Nov 13, 2006 | 09:56 AM
!PrjctMax!'s Avatar
clear the memory which requires you holding the 1st and 3rd button i believe with the same process as stated before....not positive on this but i'm pretty sure that's how you clear the memory
I also don't know why you would have to clear the memory because I would assume that the new remote would jsut over-ride the signal or w/e was there before with the old remote.
Old Nov 13, 2006 | 12:11 PM
Ritz's Avatar
did the best I could with what I had.. should get the job done.
sorry for the big pictures, but it's kinda necessary
Old Nov 13, 2006 | 03:06 PM
Defiant_Max04's Avatar
I have tried so many times and it just doesn't work. Does it just not work with my garage doors? I have gotten new ones and with my previous cars, they had worked with my previous garage doors.....
Any ideas?
Old Nov 13, 2006 | 04:20 PM
Zargon's Avatar
0100011001010101
Any ideas?
Maybe. Program the homelink button on your mirror as described above. For my garage doors, I had to do some additional steps. Look on your garage door opener (the actual motor), there is probably a red button. You need to press this button and then press the homelink button in your car (for mine I had 30 seconds to do this).
Hope this helps, thats what I did and it worked for me.
Old Nov 13, 2006 | 06:51 PM
4MySwee's Avatar
I have also heard that if you have a 'rolling code' for your garage, programming can be a bear. On some older models, it isn't possible to program your Homelink.
By 'rolling' I mean that it is digitized to create new codes every so many seconds. The older garage doors allowed you to chose the code by literally entering a code in the receiver as well as the ceiling mounted motor housing!
Old Nov 13, 2006 | 11:54 PM
Ritz's Avatar
I had to do the same thing, but after that, it works great.. just have to hold the button for at least half a second.. can't just touch it and open.
Old Nov 14, 2006 | 07:48 AM
haunt14's Avatar
thanks for all your help, ritz thank for the scanned book. i feel like i never got my stolen, lol. im gonna have to get this workin after work.
Old Nov 14, 2006 | 04:09 PM
I am going to try that. Instead of using a ladder, I'll pull my max under the garage door motor, and open the sunroof. Haha.
Old Nov 14, 2006 | 04:22 PM
rabenoja's Avatar
Yeah, I've got one of those rolling code deals. It might take 2 or 3 trys but, the homelink will eventually learn.
Old Nov 14, 2006 | 09:10 PM
tubells's Avatar
mine works on normal garage doors(from 20 yr old models to new ones).... but i cant get it to work on my condo (common) garage doors.... the remote for my condo looks like a normal one... but the security folks have to "program" it.
anyone here living in a condo... managed to get theirs to work?
Old Nov 16, 2006 | 12:46 PM
kamdigital's Avatar
make sure to press the program button on the actual garage door opener if it doesn't work
REDinLV
Aug 15, 2024 12:30 AM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
magiconthetire
Oct 26, 2015 09:03 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
