Sqeaking Suspension
Sqeaking Suspension
I posted about this in the summer, my shocks (struts?) had began sqeaking at a very high pitch when going over speed bumps instead of the initial satisfying swooshing when the car was new. I talked to a couple guys, one an ex-army helicopter mechanic and he told me not to take it too seriously, attributing it to normal wear and tear. Some people in the forums thought it might be the maxima strut problem so I took it into the dealership and they said it was some loose washer or something and replaced a screw or some dumb **** like that (said strut would cause rattling round).
Last month, after coming back from college for thanksgiving, I had my dad take it in before my warrrenty went out as the sqeaking got louder (could it be the cold?) and they said it was the brakes but the brake pads did not need changing (no clue what they were talking about). But now after the warrenty ran out (3 years the day after christmas) the car is squeaking going over anything but the smoothest pavement and even when making turns and is clearly coming from the suspension (i think the front, but maybe both ends). It is a high pitched sqeaking like an unoiled hinge. Any ideas and am I screwed since the warrenty is already gone?
Check your front stabilizer bar end links for wear. When they are worn, you will often times get a squeak or faint sound whenever going over ANYTHING but smooth road. The slightest dip will send them squeaking. Replace these first as they are relatively inexpensive. Mine is doing it NOW, and I am bringing it into the shop and throwing in OEM links with Energy Suspension bushings, also doing ES urethane bar mount bushings and lower control arm bushings while I'm there.. Hope this helps!
DJ
DJ
Yes to what everyone said. You could spray WD40 or silicone on some of the endlinks or on the lower rubber seat under the springs.
Front or back, left or right? It is a pain to identify. May need to have a passenger with you to listen for the noise.
Raise the car, remove the brackets holding the front and back sway bars. Grease the bushings (rubber piece) where they touch the sway bar. Not sure which grease is safe for those bushings. My Progress rear sway bar came with some white grease. I suspect those bushings can get noisy when dry.
I had the clunking noise on the right-front. I asked my mechanic to replace both front struts. The guy kept telling me he didnot see anything wrong, eventhough I'm paying out of my pocket and he had ordered the KYBs. Sure enough, the noise was gone afterward. But now I'm hearing some intermittent noise from the rear. I guess it's from the endlinks of the rear swaybar. I will have that checked later on.
Originally Posted by astrofil
I have clicking noise in right front side. Took the car to the mechanic and didn`t find any looses. Any suggestions ???
I just bought a set of KYB's for $195 at www.innerauto.com. Tip: Look up the part #'s on the KYB site first: http://www.kyb.com/products/ and then plug the part #'s into the site (vs. plugging in your make/model). Also, bought a set of Progress springs for $116 at www.cattman.com (call for sale price) Custom suspension for $311 - not too shabby! I'm putting everything on next weekend.
04-16-2020 05:15 AM
knight_yyz
11-01-2015 01:34 PM
