Rough Idle
Old Jan 11, 2007 | 04:38 AM
wolf2989's Avatar
Rough Idle
Anyone else experience any rough idle on their max? My idle is almost lumpy like i have some hot cams in it regardless if the engine is cold/hot.
Old Jan 11, 2007 | 06:24 AM
4MySwee's Avatar
I havent experienced rough idle. I have had a an idle that is a bit louder! It might be due to the CAI!
Old Jan 11, 2007 | 07:13 AM
!PrjctMax!'s Avatar
How many miles on the car? Maybe it's time for a tune-up. Main thing that I can think of is that your spark plugs may be bad.
Old Jan 11, 2007 | 11:47 AM
wolf2989's Avatar
Its a 2004 and i just ticked 31k. Doubt the plugs are fouled at 31k. Hell engine is barely broken in. Just wondering if i should take it to the dealer and listen to their BS.
Old Jan 11, 2007 | 03:11 PM
Lovemycar's Avatar
The last time someone had a rough idle on the 6 gens the fix was new plugs
just because you only have 31k doesn't mean nothing you could still have a faulty a plug is it just rough at idle?
Old Jan 11, 2007 | 03:31 PM
wolf2989's Avatar
Yeah it just seems rough at idle. During acceleration all is well.
Old Jan 11, 2007 | 03:38 PM
Lovemycar's Avatar
i would pull the plugs first if that doesn' t work have it checked your still under warrenty
Old Jan 13, 2007 | 05:14 AM
rottdog300's Avatar
i have the same problem it's like a lumpy idle , when spoke to them about it they said it's just the way that the 3.5's are both people i spoke with said the same thing, i just think they are blowing smoke up my ***
Old Jan 13, 2007 | 09:51 AM
Lovemycar's Avatar
bull**** my 04 has 35k and it doesn't idle like that just try changing the plugs
Old Jan 13, 2007 | 02:26 PM
bry_gator1's Avatar
I've never experienced any kind of rough idle. My 04' just about as rock solid at idle as I have seen in ANY car.
Old Jan 13, 2007 | 03:43 PM
LA02MAX's Avatar
check the idle, and let us know what the engine speed is sitting at. My idle is too low (450-500) for some reason and it's a bit rough, but I can't do anything about it without the consult and the dealer was going to charge me $90 just to raise the idle
Old Jan 13, 2007 | 04:54 PM
NmexMAX's Avatar
dot dot dot ...
If you were local, my Cipher could do the trick
Old Jan 13, 2007 | 05:04 PM
Max_Ash's Avatar
I am right there with you. I just broke 30k on my 04. it also makes a rudder noise when I start it in the morning for a sec. I'm running prem gas, full syn oil, and k&n panel filter. I haven't checked plugs yet.
Old Jan 13, 2007 | 05:37 PM
daves04smoke's Avatar
The "Other" project
mine had a little bit of a rough idle, had the f/i serviced and smooth as silk again.
Old Jan 13, 2007 | 06:19 PM
LA02MAX's Avatar
Funny you mentioned that, because I was actually just planning on waiting until Maxus, and I was going to pay someone to do it. I know you and 6spdhayes have Uprev and it would only take a couple of seconds
That's normal...after your cars sits for a while there is no oil lubricating the upper part of the engine. It takes a few seconds to build oil pressure when you first start it, so the timing chain rattles a bit. You can have the VTC sprockets replaced and that seems to do the trick...for about 2k miles....then same thing over again. The best thing to do is to just deal with it.
How many miles did your car have? And please explain the service, if you can.
Old Jan 13, 2007 | 06:39 PM
NmexMAX's Avatar
dot dot dot ...
Yup, only 2 of us that have it.
Old Jan 13, 2007 | 06:56 PM
The "Other" project
36K for miles, and they just ran the injection cleaner, don't know exactky which one. I'm sure it was probably BG or something like that
Old Jan 13, 2007 | 06:58 PM
LA02MAX's Avatar
hmm might have to look into that. I'm doing a full service tune-up soon (fuel filter, everything) so I'll add that to my list.
Old Jan 14, 2007 | 10:05 AM
Lovemycar's Avatar
hey what kind of F/I cleaner did they use and did they just add it to the tank
Old Jan 14, 2007 | 11:25 AM
The "Other" project
The injection cleaner, and also the additive to the tank I believe
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
