Lsd
Old Jan 13, 2007 | 01:20 PM
MisterSparkle's Avatar
Lsd
hey i remember someone once bringing this up regarding LSD on our max's. i think it was kam...don't remember. buh what was the final result? and another thing i saw someone post this G Spec Performance site regarding a Phantom Grip LSD conversion kit for our cars. can anybody verify this?
https://ssl.perfora.net/www.gspec.co...dex.shopscript
Old Jan 13, 2007 | 11:10 PM
Nietzsche's Avatar
It was an option for the 6-speed. The Phantom Grip works well but can cause transmission failure.
Old Jan 14, 2007 | 08:13 AM
can you explain a bit more into it cause i'm not getting it...i thought our cars already came with LSD...
Old Jan 14, 2007 | 08:43 AM
Machinist's Avatar
As Nietzsche posted LSD is an OPTION on the 6 speed mt [not available on 6th gen w/auto trans]
Old Jan 14, 2007 | 03:06 PM
Killah Kane's Avatar
What the hell is LSD?
Old Jan 14, 2007 | 05:10 PM
I VIK I's Avatar
Limited Slip Diff
Old Jan 14, 2007 | 06:36 PM
DeusExMaxima's Avatar
How do I know if I have an LSD?
Old Jan 14, 2007 | 08:17 PM
Machinist's Avatar
If you are 6 speed & you can leave 2 strips of rubber when going WOT, then you have LSD
Old Jan 14, 2007 | 09:09 PM
I guess I have LSD!!! woohoo!!!
Old Jan 14, 2007 | 10:59 PM
marshallc's Avatar
around a turn, i have a open diff and can lay 2
Old Jan 15, 2007 | 10:07 AM
buh this still confuses me...i can leave two tire tracks on the floor and i have an auto...06...i don't get it...and plus i even tried when i had my car lifted and try holding both wheels...you can't hold either...i don't get it...can someone explain that?
Old Jan 15, 2007 | 01:03 PM
Nietzsche's Avatar
Do you ever notice when you take a corner and floor it only spins one tire . That is because you have an open diff. With a limited slip it transfers torque across to the wheel with grip allowing both tires to gain traction, hence the can you put down two treads. In a straight line though many open diffs can lay two marks so it's not a indication of a limited slip. The limited slip helps on launch a little and powering out of corners alot.
Old Jan 15, 2007 | 09:47 PM
ooo icic...now i understand...so your saying our cars are limited slip...buh not LSD...lolxz
Old Jan 16, 2007 | 12:11 AM
Altima_boy's Avatar
From my understanding only 04 6spds came with a HLSD, the 05's and up came with a open diff and traction control.. I think anyways.
Old Jan 16, 2007 | 04:42 AM
Kross's Avatar
If you open your trunk and see a Leprechaun doing it with the Smurfette...you'll know you've had LSD...
Old Jan 16, 2007 | 05:15 AM
Puppetmaster's Avatar
Here's a way to check:
http://forums.maxima.org/showpost.ph...7&postcount=14
This is the rest of the discussion:
http://forums.maxima.org/showthread....highlight=HLSD
Old Jan 16, 2007 | 06:43 PM
Nietzsche's Avatar
I'm not even even going there.
ef9
Aug 14, 2015 03:03 PM
Supragte
Aug 12, 2015 10:00 PM
wolfmanjack210
Oct 6, 2001 05:15 AM
LoveSick
58
Jul 23, 2001 01:36 PM
Omegasrk
Nov 8, 2000 03:34 PM
