Want to add some HP
Old Jan 21, 2007 | 06:24 PM
  #41
xoomer.com's Avatar
I Donate! Why Don't You?
Originally Posted by 2LEET4U
buy a Maxima.org decal........... it should add at least 15HP
Any official dynos yet ??
Old Jan 21, 2007 | 06:27 PM
  #42
xoomer.com's Avatar
As stated you must have not seen the FUJITA CAI. It is one piece pipe going from the filter (inside the bumper) straight to the engine. There is no pieces, no couplers.
Old Jan 21, 2007 | 06:29 PM
  #43
NmexMAX's Avatar
dot dot dot ...
How does it connect to the maf, I need to weld a flange to connect my JWT POP.
Old Jan 21, 2007 | 06:33 PM
  #44
xoomer.com's Avatar
There is a hole right in the middle of the pipe for the MAF to slide in. It actually looks pretty neat, there isn't bunch of unions and silicone seals.
Old Jan 21, 2007 | 06:34 PM
  #45
xoomer.com's Avatar
The picture here is either and old design or not a max.
Old Jan 21, 2007 | 06:38 PM
  #46
NmexMAX's Avatar
dot dot dot ...
I guess it will only work w/ short ram set-ups.
  #47
xoomer.com's Avatar
THis should give you an idea.
http://forums.maxima.org/showthread.php?t=476150
Old Jan 21, 2007 | 06:39 PM
  #48
xoomer.com's Avatar
I guess bro...good chattin'
  #49
NmexMAX's Avatar
dot dot dot ...
I wonder if that housing is a tad larger? Hmm, and if it affects A/F...
Old Jan 21, 2007 | 06:43 PM
  #50
xoomer.com's Avatar
I have my stock still in the basement so can measure during the week.
Old Jan 22, 2007 | 06:11 PM
  #51
aryathegreat's Avatar
Originally Posted by !PrjctMax!
Get an ECU reflash from technosquare...it's $495, IF you send out your ECU and have your car decomissioned for a few days, or just buy a new ECU for aroun $200-300 and then have the stealership install it for you and reprogram your keys for an additional $200ish...ECU is the best bang for buck for our car, no matter which route you take that I jsut listed. It takes away the governor, alters the fuel/air ratio, raises the redline to 7100 rpm from the stock 6600 and it makes the throttle open all the way when you are WOT instead of it closing slightly...this is all done with the safety of the motor still in mind.
dan
IMO, after reading alot about it, it seems as if the ECU isnt that amazing of a hp inscrease mod on its own. True, it does help in accordance to other mods, but ECU should be one of the last engine mods to get the full potential of the ECU reflash. Plus gains were around mid to low teens at best in hsp and tq.
Sorry, back to the MAF chat
Old Jan 22, 2007 | 06:32 PM
  #52
!PrjctMax!'s Avatar
yes, I know that. I wasn't saying that it's TEH BESTEST OF THE BEST, but that it is one of the mods that puts out some decent numbers, unlike other mods for our car.
Old Jan 22, 2007 | 07:46 PM
  #53
NmexMAX's Avatar
dot dot dot ...
I'd rather tune my own A/F and try on adding my own timing than count on a cookie cutter to do the trick.
Fbana41
Aug 29, 2016 12:18 PM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
