Best way to launch 5at!!!!!!!!!!!!!
Old Apr 4, 2007 | 02:36 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
Going to the track again tonight ... have not gone for a few months but i wanted to see what people thought the best way to launch a 5at....
I was just power breaking... apply lite gas to 2k rpm or so and hold break at same time...
not sure if i just put it in tiprtronc 1 and just give it gas will be any better
i leave here in a few huors get back to me hahaha
Old Apr 4, 2007 | 04:53 PM
Albert's Avatar
And the other question is should traction control be off?
Old Apr 4, 2007 | 05:34 PM
SMOKIN'MAX's Avatar
Stang-seeking Max Missile
Power braking at 2K w/ TC OFF works pretty good for me. I still think my auto shifts faster than I do manually so I'd say keep it in D
> nail it and hold that steering wheel. Good luck and, as always, be safe.
Old Apr 4, 2007 | 06:24 PM
Pronto's Avatar
Damn I can't wait to go, of course it's snowing tonight
Old Apr 4, 2007 | 08:45 PM
mynameispee's Avatar
if you have it in tiptronic, right before redline, it'll shift for you anyway. it won't redline or bounce off. not sure if there is a power difference though, between auto and tiptronic.
Old Apr 4, 2007 | 08:47 PM
SmokeNismo's Avatar
I say put it in Manumatic, it shifts at a higher rpm or u could hold the shifter down so that it actually hits redline, but downside to that is probably by the time you hit redline it will just keep hitting fuel cut for like a second until the car shifts when u let go so might be slower shifts. But yeah, put it in manumatic and let it do its thing.
did u change ur tires btw? the other day i did a practice launch on the stock RSA's, power brake w/TCS off and i spun all the way to 5200 rpm. lol.
Old Apr 4, 2007 | 09:10 PM
logik05se's Avatar
yes there is...ive raced someone both of us had 05's one was in D one was in tip and let the car shift for itself....there is quite a diference actually.
Old Apr 4, 2007 | 09:32 PM
yeah that's what it felt like, but was never exactly sure.
Old Apr 4, 2007 | 09:53 PM
Nietzsche's Avatar
The car does NOT shift faster or later in manumatic. I have logged well over 30 runs with different techniques. In fact my two fastest runs where done in D stomping on the gas. I found manumatic and "holding it" had no effects, in fact a few times I bounced rev limit which killed me. Always turn TCS off as it retards timing and will bog you out of the hole. As for power braking I found it much harder to control wheel spin and no benefit in terms of time. Like I said my fastest times where in D and stomping the pedal; also the most consistent.
Old Apr 5, 2007 | 05:33 AM
4MySwee's Avatar
I run it in tiptronic or whatever that is called. I can maximize my pull and then shift right at/before redline. I don't let it bounce of rev limiter, because it does bog down.
Old Apr 5, 2007 | 06:31 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
I normally put a load on the vehicle (1K-1.5K rpm) then floor that b!tch in D. Since the car is Dyno tuned with an APEXi, the manumatic does not work so good for me anymore. Of course their are so many other factors to consider, like temp, humidity, elevation, weight of the car, tire pressure, engine heat soaking, and if using street tires, don't wet them, drive around the water pit!!! For weight I take everything out the car, jack, spare tire, drain washer fluid, 1/4 tank of gas, all weight savers. In between runs open the hood right away for faster cool down, ice even may help on the manifold for a faster cool down between runs...
Old Apr 5, 2007 | 07:03 AM
I VIK I's Avatar
Dry Ice FTW!
Old Apr 5, 2007 | 11:19 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
well i did a little of both D and manumatic. both test were about the same. i ran a 14.38 at best in manual matic and 14.41 in the auto d...
Old Apr 5, 2007 | 12:15 PM
RHMax's Avatar
Newbie just Registered
Which track? Let me know when you go next time...
Old Apr 5, 2007 | 01:16 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
Rhamx: Lacr... its in palmdale ... the elavation is 3000 ft so you ghave to calculate your time by .97 and it give you the accurate run.. I ran a 14.81 ..that time .97 = a 14.3.... the link to the site is
lacr.net
scroll down and around near the bottom and talks about the elavation convertion
Old Apr 5, 2007 | 01:17 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
this is from the site....
Altitude Correction
LACR is 2,710 ft. above sea level.
To figure the altitude factor the formula is as follows:
ET: multiply your et (at LACR) by .97
MPH: multiply your mph (at LACR) by 1.03
This will give you the ET & MPH at sea level.
14.3 not bad for a 5at with just cai and mufflers...
Once we are done working on the cattman headers and y piep i am hoping to be in high 13's....
I only lost two races last night
1st to a 10 second volks bug that did a wheelie!!!!!!!!!!
and 2nd to a 350 z with nismo exhaust and short ram intake... he ran a 14.6 i ran a 14.8...not bad for a four door he said hahaha i lol at him
Old Apr 5, 2007 | 03:30 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
everyone talks about traction control... am i stupid or do the 05 maxi's 5at not have an option for t/c
Old Apr 5, 2007 | 07:31 PM
chernmax's Avatar
Altitude Correction
OK, post a time slip!!!
Old Apr 5, 2007 | 07:35 PM
RHMax's Avatar
I think T/C is standard for all '05s.
Old Apr 5, 2007 | 07:39 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
i dont have an option to turn it off... where would it be. if i did...???
Old Apr 5, 2007 | 07:51 PM
xoomer.com's Avatar
I Donate! Why Don't You?
Chernmax is hardcore!!!
Old Apr 5, 2007 | 09:13 PM
RHMax's Avatar
TCS button is on the left side under the steering.
Old Apr 5, 2007 | 09:54 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
yep i dotn have that option... i look... no button its just a small flat area...
Old Apr 5, 2007 | 09:58 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
hahah he just know what he is doing... yes im not new to racing but new to racing at a track w/ an auto.. usually i have a mt.... hahah ... i actually bought some ice last night on the way hahah did all the tings u said but empty washer fluid hahaha... i was actually goign to take out hte front seat tooo ahahahah ...
I need some new rims and tires ... these stocks suck PITO
Old Apr 5, 2007 | 11:08 PM
RHMax's Avatar
Interesting, I thought Nissan made TCS standard for 05's. That means you don't have TCS.
Old Apr 5, 2007 | 11:10 PM
RHMax's Avatar
What did you trap at 1/8 and 1/4?
Old Apr 5, 2007 | 11:22 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
slips are in the car... illl scan or take a pic of info tomorrow... 1/4 was a 14.839 but its at 3000 ft like i stated b4 so you take teh number and times it by .97 according to www.lacr.net .
Old Apr 5, 2007 | 11:39 PM
vQ35LIFE's Avatar
in D but dont stomp the pedal to teh floor rigth away just give it a kick , and then floor it trust me i knwo what i'm talking about , o i have a 6 speed , lol ne way im telling you , kick it , so you can feel the fast push and then floor it , ive tried on my dads benz all the time , and minivan , it works much better
Old Apr 6, 2007 | 11:03 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
it u dont floor it right away you will trap a 2.5 or 2.6 60 ft... thanks for teh advice though
Old Apr 6, 2007 | 10:04 PM
DRod's Avatar
Power brake to 2k or up to a level right below where it feels like the brakes can't hold. On the green, release the brake, but no extra gas. Ease into the gas...ease...ease...punch. The punch should come at that sweet spot. You will get virtually NO wheelspin. And I run my car in tiptronic.
You guys think this thing is hard to launch, try driving a Grand Prix GTP. Once I got the hang of that thing, I was pulling 2.0x and 1.9x 60fts in stock trim...with RS-As.
Nice times, BTW.
Old Apr 7, 2007 | 12:10 AM
RHMax's Avatar
Nice times, BTW.
I'll give that a try next time. Last time I held at about 1k and feathered the throttle and still spun all the way thru first gear. I have TS ECU with RS-A tires though, so could be a bad combination...
Old Apr 7, 2007 | 05:51 AM
Pronto's Avatar
A 60 below 2 would be great. It's quite a feeling to just pull hard out of the hole without spinning.
Old Apr 7, 2007 | 11:59 AM
DRod's Avatar
Although not the best tires, RS-As aren't as bad as people make them out to be. Like I said, I was pulling 1.9x 60fts with RS-As. Still trying to get it right with the Max though.
Old Apr 7, 2007 | 12:08 PM
RHMax's Avatar
You're right, plus they are 245 wide. I can get much better traction on the street than at the track that day, although it was windy and a little dusty.
Keven97SE
Dec 6, 2000 01:45 PM
JimW
Nov 20, 2000 05:57 AM
ZuMBLe
Nov 19, 2000 04:58 PM
ZuMBLe
Nov 17, 2000 12:20 AM
